Sparky-(Admin) 26,515 #1 Posted Friday at 10:38 PM I know the WH isn’t a bulldozer (no I don’t) Just driving around looking at flowers (no I wasn’t) So there I was pushing railroad ties with my GT-1600 when it made a weird noise, moved forward another foot and then she went into “infinite neutral mode” . Towed her into the ER and the hubs are good, the trans drive pulley and keyway are good and of course the fluid is clean/full. Jack up and it makes some weird and horrible noises when it’s spun. And one time it actually locked up. Have a few (4 spares) transmissions here so it’ll get a new trans. Busted one is the original 1” axle unit with 4 pinions. I’ll install a trans with a 1-1/8” axles and 8 pinions. 1 7 Share this post Link to post Share on other sites
Easton Rich 1,272 #2 Posted Friday at 10:44 PM 8 speed are no longer indestructible I take it? Share this post Link to post Share on other sites
Sparky-(Admin) 26,515 #3 Posted Friday at 10:47 PM 1 minute ago, Easton Rich said: 8 speed are no longer indestructible I take it? I think I might have been asking to much of it. I have owned this one for at least 15 years and it’s been worked hard! Never was used for easy leisurely mowing. Always towing and plowing snow dirt and stone (and today it was railroad ties). It does have the weaker of the 8 speeds so it’ll be getting an upgrade with the new trans. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,967 #4 Posted yesterday at 01:06 AM 2 hours ago, Easton Rich said: 8 speed are no longer indestructible I take it? A 4 pinion transmission is VERY different from the heavy duty 8 pinion version. 1 1 Share this post Link to post Share on other sites
Easton Rich 1,272 #5 Posted yesterday at 02:10 AM Never broke one, but I only have 1, 1" 4 pinion 8spd that doesn't get worked. 1 Share this post Link to post Share on other sites
wallfish 20,680 #6 Posted yesterday at 03:13 AM 4 hours ago, Sparky said: And one time it actually locked up. Something got caught in the gear teeth. Open it up because you can't break it any more than all ready broke. Interested to know what let go. 7 Share this post Link to post Share on other sites
Bill D 3,173 #7 Posted 21 hours ago While you have the transmission out, check the mounting plate for cracks. 3 2 Share this post Link to post Share on other sites
ri702bill 13,200 #8 Posted 20 hours ago My money is on the differential - as in one or more of the pinions decided enough is enough. You did not drop the plow first before all this? Very optomistic of you! 1 1 Share this post Link to post Share on other sites
ebinmaine 80,967 #9 Posted 19 hours ago 1 hour ago, ri702bill said: Very optomistic of you! @Sparky doesn't need to be optimistic. He has several spares. Share this post Link to post Share on other sites
Sparky-(Admin) 26,515 #10 Posted 18 hours ago 1 hour ago, ri702bill said: My money is on the differential - as in one or more of the pinions decided enough is enough. You did not drop the plow first before all this? Very optomistic of you! Haha! Good eye Bill. Actually was just running it on jackstands to see what the transmission would do and how it sounded (both were bad). Was hoping to find a sheared key on the drive pulley. It’s “plowless” now while it awaits surgery. 1 1 Share this post Link to post Share on other sites
953 nut 69,827 #11 Posted 17 hours ago 1 hour ago, Sparky said: It’s “plowless” now while it awaits surgery. 1 hour ago, ebinmaine said: He has several spares. Gotta open her up just to entertain us, we all need a little tractor porn to start the day. We want to see Mike up to his elbows in gear oil and parts and pieces. 2 5 Share this post Link to post Share on other sites
ri702bill 13,200 #12 Posted 15 hours ago 2 hours ago, Sparky said: It’s “plowless” now while it awaits surgery. Surgery, no... transplant, yes. A much easier task when dealing with an early one pedal short frame tractor. To switch yours, you will fill a coffee can with fasteners & small parts - not counting the small trophy fiddely-bits inside the Unidrive... 1 Share this post Link to post Share on other sites
squonk 48,229 #13 Posted 15 hours ago Gear oil smell wafting into the house! WHO'S WITH ME!!!! 6 Share this post Link to post Share on other sites
ri702bill 13,200 #14 Posted 15 hours ago 6 minutes ago, squonk said: Gear oil smell wafting into the house! WHO'S WITH ME!!!! Ah, yes, the unmistakeable lingering fragrance of 90 weight in the drain pan & on the parts! BT, DT. 3 Share this post Link to post Share on other sites
peter lena 10,091 #15 Posted 15 hours ago @Sparky having a hi / low range set up , quickly lightens the loading on the trans , 3 gear , low range , is an effortless mover , also have driven around and put miles on high milage atf fluid for flushing, since doing that years ago , its easy to refresh your set up , have local cul de sacs , for road gear time , every gear / range , the flush out effects are very thorough , also like a climbing gear oil , read specs , my shift boots are all , greased underside , to enhance slide ability over irregularities' , like a large tie wrap , at happy spot , look for usage movement . most of my , mods are based on , REPEDITIVE FAILURE , regularly , try anything to improve function . pete 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,515 #16 Posted 12 hours ago 2 hours ago, peter lena said: @Sparky having a hi / low range set up , quickly lightens the loading on the trans , 3 gear , low range , is an effortless mover , also have driven around and put miles on high milage atf fluid for flushing, since doing that years ago , its easy to refresh your set up , have local cul de sacs , for road gear time , every gear / range , the flush out effects are very thorough , also like a climbing gear oil , read specs , my shift boots are all , greased underside , to enhance slide ability over irregularities' , like a large tie wrap , at happy spot , look for usage movement . most of my , mods are based on , REPEDITIVE FAILURE , regularly , try anything to improve function . pete No idea what all that nonsense (and difficult to read I might add) has to do with me swapping a manual transmission out? 3 1 1 Share this post Link to post Share on other sites
