bo dawg 643 #1 Posted Friday at 02:02 PM The 418 just quit running, thought the carb was dirty so I cleaned it, before I cleaned it I did check to see if it was getting gas when pulled gas line, turned engine over for a second and gas shot out so I was for sure it was carb. After reinstalling carb it still doesnt run. Fill gas line with gas and hooked up to carb and runs just for a few seconds till line empties out. So pulled gas line off carb, turned over engine and again gas squirted out but when I kept turning engine over to see if it would keep squirting out there was no more gas. So must be fuel pump. The line to the pump and line filter is full of gas. So where is the best place you guys been buying replacement pumps?? Share this post Link to post Share on other sites
ebinmaine 80,967 #2 Posted Friday at 02:04 PM Go electric. I personally use and recommend Facet brand pumps. There are less expensive models of other brands. 2 Share this post Link to post Share on other sites
pfrederi 21,225 #3 Posted Friday at 02:21 PM 15 minutes ago, ebinmaine said: Go electric. I personally use and recommend Facet brand pumps. There are less expensive models of other brands. Me Too I have a Facet oin my 418A turn switch on you can hear the pump clicking after a few seconds it gets quieter then yoo will have instant start up. 2 Share this post Link to post Share on other sites
bo dawg 643 #4 Posted Friday at 05:27 PM 3 hours ago, pfrederi said: Me Too I have a Facet oin my 418A turn switch on you can hear the pump clicking after a few seconds it gets quieter then yoo will have instant start up. Show me how you have them installed and wired up if you can please 1 Share this post Link to post Share on other sites
Ed Kennell 47,612 #5 Posted Friday at 07:13 PM (edited) Here's one of many threads on e-pumps. 520H Electric fuel pump locations. - Wheel Horse Electrical - RedSquare Wheel Horse Forum I have had good service with the Carbole pumps. Do not let the pumps run dry. I like to wire mine to the hot side of the light switch. Edited Friday at 07:26 PM by Ed Kennell 3 Share this post Link to post Share on other sites
kpinnc 19,013 #6 Posted Friday at 09:13 PM (edited) I've added these on 4 tractors and they work very well. One Facet and 3 Carboyle. Just keep the psi very low (5 psi or less, lower is better) and they work great. I prefer to keep them closer to the carb myself but these tractors aren't big enough to mount outside the limit for the pump. Pretty much wherever you want is fine. Pick up a few 3/8 brass fittings and you have plenty of options. Just be sure to install the included filter to preserve the pump itself. Edited Friday at 09:28 PM by kpinnc 4 Share this post Link to post Share on other sites
wallfish 20,680 #7 Posted Friday at 10:04 PM You can easily verify if the problem is fuel related by squirting some fuel into the carb and trying to start it. If it starts, continue with diagnostics on the fuel system. If it doesn't start, take a look for ignition and spark issues. 1 Share this post Link to post Share on other sites
Easton Rich 1,272 #8 Posted Friday at 10:37 PM Sometimes the needles on the float get stuck which would explain it running off the bowl then dying. Drop the bowl off and move your float up and down to make sure the needle is moving. If that's tests out fine put on an electric pump like the others have mentioned. 1 Share this post Link to post Share on other sites
953 nut 69,827 #9 Posted Friday at 11:01 PM Best place to connect the electric supply is at the volt / hour meter feed. It is fused and turns off when the ignition is turned off. 1 1 Share this post Link to post Share on other sites
bo dawg 643 #10 Posted 12 hours ago 19 hours ago, wallfish said: You can easily verify if the problem is fuel related by squirting some fuel into the carb and trying to start it. If it starts, continue with diagnostics on the fuel system. If it doesn't start, take a look for ignition and spark issues. Oh yea its runs good as long as you squirt gas in carb 2 Share this post Link to post Share on other sites
sqrlgtr 4,111 #11 Posted 11 hours ago 19 hours ago, 953 nut said: Best place to connect the electric supply is at the volt / hour meter feed. It is fused and turns off when the ignition is turned off. The ones Ive installed was on tractors without A voltmeter but I did install a fuse in circuit and wired to hot wire key on only. 1 Share this post Link to post Share on other sites
953 nut 69,827 #12 Posted 10 hours ago That will work too. Share this post Link to post Share on other sites
