bo dawg
418 gas problem
bo dawg
The 418 just quit running, thought the carb was dirty so I cleaned it, before I cleaned it I did check to see if it was getting gas when pulled gas line, turned engine over for a second and gas shot out so I was for sure it was carb. After reinstalling carb it still doesnt run. Fill gas line with gas and hooked up to carb and runs just for a few seconds till line empties out. So pulled gas line off carb, turned over engine and again gas squirted out but when I kept turning engine over to see if it would keep squirting out there was no more gas. So must be fuel pump. The line to the pump and line filter is full of gas.
So where is the best place you guys been buying replacement pumps??
ebinmaine
Go electric.
I personally use and recommend Facet brand pumps. There are less expensive models of other brands.
pfrederi
15 minutes ago, ebinmaine said:
Go electric.
 Me Too  I have a Facet oin my 418A  turn switch on you can hear the pump clicking after a few seconds it gets quieter then yoo will have instant start up.
bo dawg
Show me how you have them installed and wired up if you can please
Ed Kennell
Here's one of many threads on e-pumps.
520H Electric fuel pump locations. - Wheel Horse Electrical - RedSquare Wheel Horse Forum
I have had good service with the Carbole pumps.
Do not let the pumps run dry.
I like to wire mine to the hot side of the light switch.
Edited by Ed Kennell
