Thegearhead0324 1,862 #1 Posted October 30 (edited) Good morning everyone. I just purchased a HY kit, probably over payed, but I saw it and noticed everything looked like it was there. I’ve always wanted to make my 1257 hydro lift. Description stated it will need a rebuild, I think @wheelhorseman sells these kits? Possibly new hoses as well? I’ve seen a few folks on here who have put them on their tractors with some modifications like shifter and mounting and cylinder, engine pulley/pto, and such, mostly intrigued about how to put some kind of double pulley behind the pto?. I guess I’m just asking for some suggestions and what you’ve done to make it all work. Thank you. Edited October 30 by Thegearhead0324 1 Share this post Link to post Share on other sites
adsm08 5,219 #2 Posted October 31 My 855 came to me with one of these on it. I'm not sure how to set up your pulley at the engine since the K181 is pretty different from the 10 and 12HP engines. I will say that the hoses from WheelHorsePartsandmore are a little problematic with a manual transmission. Unless I remove the shifter knob they interfere with being able to use 2nd gear, and are still hair short, meaning I had to do some abrasion mitigation at the edge of the fender pan. The originals were hose crimped onto brake line and much thinner than the ones Lowell sells, which is why his can be an issue. The originals were also not built as robustly. 1 Share this post Link to post Share on other sites
953 nut 69,958 #3 Posted October 31 @WHX?? and @sqrlgtr should be able to shed some light on the situation. They both have HY on their 1257s. 2 Share this post Link to post Share on other sites
Thegearhead0324 1,862 #4 Posted October 31 I appreciate the reply’s back, in the middle of doing leaves this morning I was eyeballing my tractor and I think I may have figured out the pulley/pto situation, as I don’t want to hack and disturb too much, we will see. I won’t be starting this project for a bit since I bought the HY unit online and waiting to be shipped to me. Also I will be needing to rebuild it before mounting to the tractor. Share this post Link to post Share on other sites
adsm08 5,219 #5 Posted October 31 When you buy the seal kit get extra pulley shaft seals. They are hard to install and easy to damage. 2 Share this post Link to post Share on other sites
sqrlgtr 4,128 #6 Posted October 31 5 hours ago, 953 nut said: @WHX?? and @sqrlgtr should be able to shed some light on the situation. They both have HY on their 1257s. 2 owners one mochine. @WHX?? is the one who adapted the HY2 unit to the 1257, all Ive done is use it. Was my bestest snow pusher last winter and would be hard to go back to manual lift now. I did make a new handle for lift, had a custom decal from redo your horse made and rebent the shifter for it though. Here is a few pics that might help ya along the way. 3 1 Share this post Link to post Share on other sites
peter lena 10,100 #7 Posted Monday at 12:43 PM @Thegearhead0324 use SUPER LUBE on all related o rings ? a dry ring will ROLL TO A SMALLER DIAMETER , if dry , causing related leakage , another thing about seating , tightening connections , go at it EASILY to sense , make up . the O ring is the binder , pete 1 Share this post Link to post Share on other sites
Thegearhead0324 1,862 #8 Posted Thursday at 09:37 AM I received the unit yesterday, pretty rough shape but I’m sure after going through it it’ll be ok, the very first thing I did was take the pump all apart, of course the return spring is broke and fought a little to get the pieces out of the holes, gears and everything else look ok, it looked like it sat for a while with water in it as it has some pitting but nothing crazy. At least I know what I’m working with now. 1 Share this post Link to post Share on other sites
Thegearhead0324 1,862 #9 Posted 21 hours ago A quick question about the pump, I’ve seen the same thing on a couple other pics of pumps on here, but is it normal for the roll pin to be poking out that far? When I turned the control valve, it was hitting in the long threaded shaft and gear cover. Share this post Link to post Share on other sites
adsm08 5,219 #10 Posted 20 hours ago It needs to stick out some,because the hole is not blind so it has to be pulled out, but it should not hit the gear cover IIRC. I had issues with mine only working in one direction that drove me nuts for a while, and that was the problem. 1 Share this post Link to post Share on other sites
Thegearhead0324 1,862 #11 Posted 11 hours ago Ok I appreciate it @adsm08 , I knew it needed to be poking out some because of removal, but thought that was kind of far since it was hitting when turning one direction. 1 Share this post Link to post Share on other sites
Thegearhead0324 1,862 #12 Posted 4 hours ago (edited) This is what I got going on so far, basically cleaned everything up except the cylinder which I still need to take apart. Also, someone decided to either over tighten a bolt or drop the unit because one of the bolt holes the pulley cover bolts to, well a piece of the cast is broke off. There’s still threads in it but I think I’m gonna make a small bracket and use another hole since the pulley will be in the way. And speaking of holes, there are a few extra drilled holes on the cover as well, and someone grinded a square hole on the corner of the tower mounting plate🤦🏻♂️. Yikes. Edited 4 hours ago by Thegearhead0324 Share this post Link to post Share on other sites
