Wheelhorse3128
Wheelhorse 312 8 transaxle bracket cracked
sqrlgtr
21 minutes ago, oliver2-44 said:
Why the need for longer bolts?
If you are thinking of adding a plate to the transmission side of the F-Plate, that will cause the drive belt  to need to be lengthened.
Whichever ever side you decide to add plate it may still require longer bolts. Ive never seen one with a plate on trans side (because of belt length), but may be a bunch of um done that way?
Wheelhorse3128
That's what I'm thinking as the belt I have is too long anyways as I swapped the pulley to get more speed and the belt I got was too long so I put a idler pulley on that was supposed to be temporary while i got a shorter belt but it works well so I left it on
sqrlgtr
Dont forget to allow for the longer wheelbase if u go with plate between trans and frame, think shifter location and such.
Wheelhorse3128
Will probably just add a 5mm thick plate so will be able to move stuff back 5 mm I think
Handy Don
I grooved and then welded the cracks from both sides but added the reinforcement plate on the forward side of the F-plate because I didn’t want to consider any drive train mods. Looking back, I’d have also drilled the reinforcement plate to accommodate a couple of plug welds in the middle of the plate.
When welding, be sure to use good sequencing and cooling practices to avoid overheating any small area and causing either the F-plate or the reinforcement to warp.
Edited by Handy Don
Ed Kennell
5 mm should not affect the belt length, but may require a motion control linkage adjustment.
OOps, just saw it's an 8 speed.  No linkage.
Edited by Ed Kennell
Wheelhorse3128
I will actually put the plate on the inside like other pictures that have been put on here
Edited by Wheelhorse3128
ri702bill
I disagree - the plate goes on the inside - not between the frame & unidrive. Longer 3/8-16 UNC fasteners are needed - length TBD by the plate thickness.
ebinmaine
And weld the existing cracks?
Wheelhorse3128
👍Yes and I will put dome dort of bracing somwhere
sqrlgtr
This is a pic I pulled from a thread @ebinmaine had a while back and this is what my 520's plates' looks like and the way they came from factory. Just to give you an idea maybe? I always thought doubling up the side triangle pieces would really help also and still have that original look to it.
