bradleydavidgood 44 #1 Posted 15 hours ago (edited) Edited 15 hours ago by bradleydavidgood 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,502 #2 Posted 4 hours ago When I do this I use are longer bolt with about 3/8" of unthreaded rod below the head. This way the rotating parts are not pivoting on bolt threads which will cause wear. The unthreaded part extends through the complete assembly plus a bit. Add enough flat washers below the nut so there is room for future adjustment. Cut off the threads that are not used. Reaching in with two wrenches to make future adjustments is a breeze. 2 Share this post Link to post Share on other sites
peter lena 10,081 #3 Posted 3 hours ago @bradleydavidgood personally have added a light / medium extension spring to all my , choke / throttle cables , at the opposite end , to pull it closed / stop ? that way you always have a MOVEMENT ASSIST , to any cable movement , of course ,all my cables are lubricated for movement function , https://www.google.com/search?q=light+extension+spring&rlz=1C1CHBF_enUS866US866&oq=light+extension+spring+&gs_lcrp=EgZjaHJvbWUyCggAEEUYFhge like 3-1 penetrating oil , easy to experiment on this , years in usage , consistently work . pete 1 Share this post Link to post Share on other sites
peter lena 10,081 #4 Posted just now @Ed Kennell https://www.google.com/search?q=perforated+sheet+metal+scraps&sca_esv=45ae86a590fa11da&rlz=1C1CHBF_enUS866US866&sxsrf=APpeQnvdKUkfxV8ca_3s8axk8QKGXaPLlA%3A1792942279273&ei=xyDeapbpD- reference area , often suggest a spring pull assist , probably have a related bolt / screw point in the area ? have s/s perforated scrap , very easy , remove , screw , bolt , bolt on related scrap , for a flat straight line spring pull , very strong , that spring quickly enhances closure to cable ? so there is always , smooth / easy lubricated function . in usage stage , like pull assist . many years in use , another , REPEDITIVE ISSUE , eliminated , love those , very easy to do a trial , local bone yard , might have a pile of perforated , steel scrap , pete Share this post Link to post Share on other sites
