1054 Project
1054 (953) Hydraulic Unit Rebuild
1054 Project
OK, I have my new return spring. As you can see the overall length of the replacement spring is much taller than the old one. I assume I'll need to shorten the spring so that it engages with the outboard holes and at the same time have the "U" sit behind the roll pin. Or am I looking at this all wrong?
Thanks in advance!
ri702bill
If you bought that part from Lowell, ask him...
702854boy
That might mean the ends of the original spring broke off in the holes on the pump and you get to go fishin
1054 Project
So.....drill them out? I assume the "U" bend in the spring needs to sit under the roll pin?
8ntruck
I just looked at the picture again.  Looks to me like there might be something in the holes on either end of the groove.
1054 Project
Agreed. Can these be drilled out?
Handy Don
Hmmm. Spring steel embedded in a casting, Beyond my skills.
Hoping someone who’s been there can offer a suggestion or two!
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
