BPEisenhower
Progress is slow but, it's alive
BPEisenhower
Hello Horse family, cool days and short on sunlight after work but, I finally got the "scrap" Charger 12 Automatic running on its own and got the blade mounted, ready for action. Even with flat, cracked, turf tires, it still pushed millings with ease. Very Impressed!  So, since I can't bring myself to use it for parts, my plan is to first of all, get a new ignition switch since the one in it is wired directly to the battery and starter, no solenoid!  I need correct key switch part number please! And, since it's a 14HP, not a 12, will the Electric PTO from a 12 HP fit?  Definitely stopping by NAPA and grabbing a few 1410 filters and Type F ATF for a few others in the need for service. Right rear hub is loose, I have to get steel stock for new key way OR, put in new seals so both hubs can be welded (dealt with that before). And, of course, new AG tires on rear filled with beet juice will guarantee I can shove snow if we get enough. Lastly, Rust-Oleum is needed, don't care about the orange hue.. I wish Valspar still made the restoration series IH red. I think it's Almond or what used to be Navajo White for the rims..... That's it for the moment and if there's any suggestions, feel free to educate me!
  • Like 5
  • Excellent 2
rjg854
Myself, I'd leave it just like it is.  They are only original once and it appears from the picture to be in nice condition considering its age. Buff it out and give it a good wax job and it will be fine.  Of course paint the wheels and enjoy the way it is.  Make it mechanically perfect that the most important part.  Unless you want a trailer queen that you're afraid to put a scratch on.  Work it, that's what they were made for.  That's my opinion for what it's worth, it's your tractor.
peter lena
@BPEisenhower been doing  paint recovery for years , like a thorough  penetrating  oil soak down  for days  or longer , ideally  hot sun really  heats up metal and draws in  lubrication  salvation . do a multi stage , gain on it , think the neatest thing about this way  ?  once attained , a clean cloth  penetrant  wipe down  , brings it right back , perfect  patina . recently did a carb cleaner  , test  area ,  clean cloth , no effort at all , paint  just looks ]patana perfect , EXPERIMENT WITH A  SMALL AREA , , thats how I started , pete
BPEisenhower
Definitely going to be used. Don't want to be afraid to scratch it but, do like the original work clothes but minus the black stripe down the middle. LoL. Hopefully, I can use it this winter if we get snow! Plan to change fluid and filter this weekend and break out the buffer!
Pullstart
:no:
Put down the welder and slowly back away! Is all I hear Uncle Jim hollering!  We don’t ever need to weld hubs as a fix.  :handgestures-thumbupright:
Edited by Pullstart
BPEisenhower
9 hours ago, Pullstart said:
:no:
LoL. I understand that, however, I would heat the hub in an oven before welding. That's a last resort unless I can fix key way OR if I have the time, cut the splined end off and orbital weld a new shaft with a solid hub from a few DANA axles laying around. At any rate, I have to finish it so I can get another one done, then another, and get a few more 🤣
rjg854
A-Z Tractor has replacement hubs if your keyway is bad. That also may be an option.
