mpoore 34 #1 Posted Sunday at 06:52 AM (edited) Does anyone else have this problem or better yet a confirmed solution? You will notice the foot pedal could interfere with a shield. Edited Sunday at 06:56 AM by mpoore Share this post Link to post Share on other sites
cleat 9,353 #2 Posted Sunday at 12:45 PM I have come to accept that is just how it is with leaves blowing around in the fall. I made up a holder from a bagger bracket to hold a regular car snow brush You can use anything to hold the brush. But the main point is that I can use this brush to knock leaves and debris off of the screen while running the tractor. 3 1 Share this post Link to post Share on other sites
mpoore 34 #4 Posted Sunday at 06:16 PM Thanks for the reply. How often do you have to stop and clear the debris? I had to clear it 5 times mowing 3/4 acre. Very annoying. The Kohler engine I had before did not do this. I could mow the whole yard without clearing it. Either the debris got sucked through or had less suction. The Predator engine does have a fine grill in the shroud. The front of the deck is right below the engine. I was wondering if this is a symptom of a deck issue or normal. I wonder if a plate below the shroud would do any good. It seems like the debris is floating everywhere, so I am suspecting it would do very little. 1 Share this post Link to post Share on other sites
Handy Don 17,504 #5 Posted Sunday at 06:32 PM (edited) 16 minutes ago, mpoore said: The Kohler engine I had before did not do this. I could mow the whole yard without clearing it. Either the debris got sucked through or had less suction. The volume of air pushed through by the Onans is, frankly, impressive. Consider also that two cylinders already need twice the air of a single! Edited Sunday at 06:32 PM by Handy Don 2 Share this post Link to post Share on other sites
cleat 9,353 #6 Posted Sunday at 07:48 PM (edited) 1 hour ago, mpoore said: Thanks for the reply. How often do you have to stop and clear the debris? I had to clear it 5 times mowing 3/4 acre. Very annoying. The Kohler engine I had before did not do this. I could mow the whole yard without clearing it. Either the debris got sucked through or had less suction. The Predator engine does have a fine grill in the shroud. The front of the deck is right below the engine. I was wondering if this is a symptom of a deck issue or normal. I wonder if a plate below the shroud would do any good. It seems like the debris is floating everywhere, so I am suspecting it would do very little. Mowing just grass I hardly ever need to clean it. Grinding leaves in the fall using the 48" deck, I might need to brush it as often as once a minute but with the brush in your left hand it just takes a second and you don't need to stop. The kohler screen spins so that is likely why you don't need to clear those as often. The Onan engine also has a spinning metal screen just below the stationary plastic one so I have considered removing the plastic one and run it like a Kohler to see what happens. Edited Sunday at 07:50 PM by cleat 3 Share this post Link to post Share on other sites
mpoore 34 #7 Posted Sunday at 11:39 PM I like your brush idea. I already have one of those around here somewhere. The rotating screen is not something I considered, but is probably significant. It will suck my hand toward the shroud at full throttle, so there is a lot of suction. I may experiment with a shield and see if anything makes a difference. 1 Share this post Link to post Share on other sites
lynnmor 9,042 #8 Posted yesterday at 02:15 PM Much of that debris was likely kicked up by the left front tire. Some have fashioned a fender from a cut up plastic bucket with good success. Share this post Link to post Share on other sites
cleat 9,353 #9 Posted 23 hours ago 7 minutes ago, lynnmor said: Much of that debris was likely kicked up by the left front tire. Some have fashioned a fender from a cut up plastic bucket with good success. Maybe grass, but the leaves get blown out of the front of the deck at least that is how my 48" deck seems to work. My blades are getting worn down, maybe new blades would blow better out the side where it is supposed to but I'm not sure. Share this post Link to post Share on other sites
mpoore 34 #10 Posted 23 hours ago I tried to watch while mowing, but I could not see anything. The tire is a possibility. I assumed it was the deck. I have it set high, so there is a lot of space. I think I will use some cardboard as a temporary shield to see what makes a difference. If it is the deck, maybe a rubber strip across the front would help. A fender is another good idea. Share this post Link to post Share on other sites
sqrlgtr 4,022 #11 Posted 18 hours ago (edited) I have noticed, what little I have used my 520H to mow with, is that the higher the deck is set at the more trash gets stuck on screen. I rarely mow with any of my Wheel Horses anymore but do it every once in a while just to remind me how lucky I am to have a zero-turn mower. In my own defense the zero turn is a Toro so close to being a Wheel Horse . Edited 18 hours ago by sqrlgtr Share this post Link to post Share on other sites
Handy Don 17,504 #12 Posted 15 hours ago 2 hours ago, sqrlgtr said: a zero-turn mower. No apology needed. If I had a large area to mow, I’d have a zero-turn. Limited flexibility for other chores, granted, but for mowin’ they can’t be beat. 1 Share this post Link to post Share on other sites
mpoore 34 #13 Posted 12 hours ago Zero-turns are definitely faster, but I can do 3/4 acre in an hour. That's tolerable. If there were a lot of landscaping to navigate, I am sure it would take a lot longer. Garden tractors do okay so long as you have a lot of straight lines. I use my Wheel Horse for a lot more. I have a 3pt with a 2" receiver. I have a grading blade, plow, and a ripper. Mowing is probably 50% of how I use it. It's 44 years old and will probably outlive me with the new engine. 1 Share this post Link to post Share on other sites
kpinnc 18,984 #14 Posted 11 hours ago On 10/18/2026 at 2:16 PM, mpoore said: The Kohler engine I had before did not do this. I could mow the whole yard without clearing it. Most Kohlers have the flywheel screen itself that spins, and it is on the outside. Most debris gets flung off. My 14hp Vanguards are the same. My concern would be how much debris gets past the flywheel and sticks on the coiling fins under the shroud. 1 Share this post Link to post Share on other sites
cleat 9,353 #15 Posted 3 hours ago 7 hours ago, kpinnc said: Most Kohlers have the flywheel screen itself that spins, and it is on the outside. Most debris gets flung off. My 14hp Vanguards are the same. My concern would be how much debris gets past the flywheel and sticks on the coiling fins under the shroud. That is why I have not pulled the plastic outer screen from my Onan, I'm afraid too much debris would get in 1 Share this post Link to post Share on other sites
