Charrie 22 #1 Posted Sunday at 03:53 AM I bought a 1985 416-8 a few months back and now I an ready checkout the engine. The PO said that a few years ago he parked it for the winter and when spring came around, it wouldn't start. Said that he changed point, plug, coil, and did a little more work then gave up. Said that his Father in law bought it new in 1985 and was his baby. i think it is generally in decent shape but I question what a few years really is due so some of the rust on certain unpainted parts. Anyway that's basically what I know of its history. The PO did say that it was running great when he parked it. The day I bought it, I could turn the engine over by hand and felt some compression. Today I pulled the spark plug and put about a tablespoon of transmission fluid in the cylinder and then turned the engine over by hand a few times. No sticking places but almost felt like I could feel the pressure from the valve springs as I slowly rotated the flywheel. After about an hour I connected a battery and used the starter to turn the engine to check compression. My old gauge was reading around 40psi. I removed the gauge and added another tablespoon or two of transmission fluid hoping to get some around the valves. I re-checked the compression and this time it was around 35 psi. I have 2 gauges and one is defiantly bad so I am going to do the test again tomorrow with new o-rings on the hose. So, that is where I am at right now. I do have a few miscellaneous parts and gaskets. I also have 2 new head gaskets. Am thinking right now that low compression could be stuck ring or rings, issue with one or both valves. I can get a loaner leak down compression tester if need be. Where should I go from here? Should I pull the cylinder head off to inspect the cylinder and valves or focus on getting it to run a little and re-check the compression before tearing into the engine? Haven't changed the engine oil yet. Should I go ahead and change it now or wait and see if I need to go into the engine? I actually have 5qt jug of oil with missing label. Either 5w 30 or 10w 40 that i can throw in there for now and use it while trying to get it running and then flush it out. All advice on what to do is welcome! Thanks Charrie Share this post Link to post Share on other sites
sqrlgtr 4,035 #2 Posted Sunday at 08:28 AM Hard to check compression on these old Kohlers because of the ACR (automatic compression release} design. If it where me and especially since you have head gaskets on hand I would remove head and clean everything up (decarb) good and adjust valves while I was at it. Even if it is wore pretty bad, they will run if you've got fuel, fire and compression. More than lik;y will require a carb cleaning/rebuild and I reccomend replacing all fuel line and filters. The last time I went through this the fuel pump was full of trash also. If your not worried about keeping absolutely original an electric fuel pump is a great upgrade. 1 2 Share this post Link to post Share on other sites
ri702bill 13,123 #3 Posted Sunday at 09:43 AM True about Kohlers with the ACR - that runs by centrifugal force - and is open under 700 or so RPM. That is what gives the Kohler its distinctive "putt-putt-putt" sound at low idle. Cleaning the inside of the fuel pump is an excellent recommendation - over time, the valves get crapped up and fail to seal properly.. Share this post Link to post Share on other sites
rmaynard 17,608 #4 Posted Sunday at 11:28 AM First thing I would do is try starting it with starter fluid sprayed directly onto the carb. If it fires then you don't have spark or compression problems, just a gummed up fuel system from ethanol gas sitting in the carb, fuel pump, etc 4 1 Share this post Link to post Share on other sites
Gasaholic 396 #5 Posted Sunday at 12:57 PM 1 hour ago, rmaynard said: First thing I would do is try starting it with starter fluid sprayed directly onto the carb. If it fires then you don't have spark or compression problems, just a gummed up fuel system from ethanol gas sitting in the carb, fuel pump, etc I'd use carb & choke cleaner. Starting fluid (ether) doesn't need compression to fire off.. been there done that.. plus starting fluid aggressively scrubs away lubrication.. It'd only prove you have spark enough to light it off , and it don't take much... 1 Share this post Link to post Share on other sites
rmaynard 17,608 #6 Posted Sunday at 05:34 PM 4 hours ago, Gasaholic said: I'd use carb & choke cleaner. Starting fluid (ether) doesn't need compression to fire off.. been there done that.. plus starting fluid aggressively scrubs away lubrication.. It'd only prove you have spark enough to light it off , and it don't take much... Agreed if you were trying to run the engine on ether. But if you are only momentarily proving a fuel problem and not a spark, no harm will come in that short of a time. Just my opinion. Share this post Link to post Share on other sites
Charrie 22 #7 Posted Sunday at 07:01 PM (edited) Oh yes, I forgot reading about the ACR, thanks. Was planning on taking the head off todo a cleaning and inspection but was hoping to get it to run first if possible. When I do remove the cylinder head, should I also hand lap the valves to clean the seats up a little? Yes, all new fuel lines and filter. Yes, pretty sure that the carb will need rebuilt. The choke cable seems to be stuck and i believe it's at the carb, not the cable. From what I have read, it should have a Carter #30 on it. I picked up a kohler float kit the other day that i think fits this carb. All it has is the bowl gasket, float, and needle valve. Not sure if that will be enough though. Kohler # 25-757-03-S As to fuel pump, It still has the original metal pump. I picked up 2 rebuild kits that I believe fit this pump but I have no idea what all of the parts are for. Hopefully I can find some info on rebuilding the pump. #230675 Po\O said that he couldn't get the engine to start. Yesterday when attempting to check compression, I couldn't get the starter to engage and used a screwdriver to jump out the solenoid. I need to find a wiring diagram for this tractor. 1985 would have been owned by Wheel Horse, not Toro, I believe. The diagrams that I have found are Toro and have the Magnum or twin engines. I thinking this system uses direct battery voltage from the ignition switch to the coil? Points ground the negative side of the coil causing spark? Does anyone know if this tractor uses a voltage regulator or an electronic rectifier? I haven't found either yet. But neither of those should affect the starting? Just the battery charging? Thanks Charrie EDIT I just found this file here on the forum Kohler K341S-71371 with battery ignition and 3 amp unregulated charging system Lights work off AC current from a second flywheel stator only when the engine is running 1985 416-8 model 31-16K801 Edited Sunday at 07:11 PM by Charrie Share this post Link to post Share on other sites
sqrlgtr 4,035 #8 Posted Monday at 02:20 AM 7 hours ago, Charrie said: As to fuel pump, It still has the original metal pump. I picked up 2 rebuild kits that I believe fit this pump but I have no idea what all of the parts are for. Hopefully I can find some info on rebuilding the pump. I have rebuilt 4 of the original fuel pumps and they were all different on the inside but 3 of them looked alike on the outside. You just about have to take them apart to tell which one you have but they were all pretty straight forward to rebuild and they have been doing great ever since. I did have to go back through one of them because it seeped fuel between the pump body were it went together but a little more work on flattening of the two halves of pump body took care of it. I recommend Antique Auto Parts | Weymouth, MA | 781-335-8860 for fuel pump kits not the cheapest but have been the best in my opinion, and have always helped me if/when I had ????'s. 1 Share this post Link to post Share on other sites
Charrie 22 #9 Posted Monday at 06:15 AM Thanks Sqrlgtr Both of my pump rebuild kits are Kohler. If the kits don't fit then I do have a Kohler composite/plastic replacement pump I can use but was trying to save it if possible. Does Antique Auto Parts sell other parts we need for these tractors? How many safety switches are on this tractor and are they NO or NC? When turning the ignition switch to on position, the voltage meter moved but the starter solenoid would not engage the starter. There is a wire but spliced together near the PTO lever but i can't see the switch. The wiring diagram shows a seat switch. isn't there usually a brake or clutch switch? I don't see them on the diagram. Thanks Charrie Share this post Link to post Share on other sites
Gasaholic 396 #10 Posted Monday at 01:17 PM 17 hours ago, Charrie said: Oh yes, I forgot reading about the ACR, thanks. Was planning on taking the head off todo a cleaning and inspection but was hoping to get it to run first if possible. When I do remove the cylinder head, should I also hand lap the valves to clean the seats up a little? Yes, all new fuel lines and filter. Yes, pretty sure that the carb will need rebuilt. The choke cable seems to be stuck and i believe it's at the carb, not the cable. From what I have read, it should have a Carter #30 on it. I picked up a kohler float kit the other day that i think fits this carb. All it has is the bowl gasket, float, and needle valve. Not sure if that will be enough though. Kohler # 25-757-03-S As to fuel pump, It still has the original metal pump. I picked up 2 rebuild kits that I believe fit this pump but I have no idea what all of the parts are for. Hopefully I can find some info on rebuilding the pump. #230675 Po\O said that he couldn't get the engine to start. Yesterday when attempting to check compression, I couldn't get the starter to engage and used a screwdriver to jump out the solenoid. I need to find a wiring diagram for this tractor. 1985 would have been owned by Wheel Horse, not Toro, I believe. The diagrams that I have found are Toro and have the Magnum or twin engines. I thinking this system uses direct battery voltage from the ignition switch to the coil? Points ground the negative side of the coil causing spark? First thing I would do before pulling head is to make sure it is generating a good spark - so yes points close allowing voltage to flow through coil (should be battery voltage at coil + at all times) , when points open that interrupts the voltage flow and collapses the magnetic field through primary winding of coil, it has to go somewhere so it goes into the secondary winding and produces the spark. Full voltage should be enough to generate a bright blue spark at the plug (and if it can jump a 1/4 inch gap , the spark should be enough to fire under compression) If you can get a spark then throw in a little bit of gas (teaspoon) into spark plug hole and see if it will fire - if it does you know you have enough compression and spark to at least start. So I'd start by verifying spark before pulling head. if you don't have spark it ain't gonna fire ether (starting fluid) either.. so that'd be the first thing to fix. Then I'd break down all your other issues into sequence of what's most important (spark, compression, fuel, then worry about charging, fuel delivery and wiring) 17 hours ago, Charrie said: Does anyone know if this tractor uses a voltage regulator or an electronic rectifier? I haven't found either yet. But neither of those should affect the starting? Just the battery charging? Thanks Charrie EDIT I just found this file here on the forum Kohler K341S-71371 with battery ignition and 3 amp unregulated charging system Lights work off AC current from a second flywheel stator only when the engine is running 1985 416-8 model 31-16K801 Your pictured fuel pump kit should probably work for 99% of the kohler fuel pumps out there The one-piece valves and round gaskets go to one type of valve body and the one piece gasket, 2 disks and 2 little springs go to the other type.. The one piece valves are also used in early plastic bodied fuel pumps as well. But first things first, make sure you have spark, then deal with compression issues (if such an issue exists) , then figure out carburetion (dont need fuel pump if you can rig up a gravity fed drip to the carburetor) and once those are solved, you should be able to get the engine to run. With that out of the way all the rest is just "support systems" to dial in. Lastly , for voltage regulator , look for a wrapped 2-wire harness coming from under the engine's closure plate (flywheel side) and likely routed under the starter, follow it to a connector body and you'll likely find where those wires terminates which will be a voltage regulator (for a regulated system) or solenoid or key switch (for unregulated system) Share this post Link to post Share on other sites
oliver2-44 11,765 #11 Posted Monday at 02:28 PM When you disassemble the fuel pump, some have independent small valve disc and tiny springs under the valve aluminum keeper. Be ready they jump out or be stuck in place Share this post Link to post Share on other sites
Charrie 22 #12 Posted Tuesday at 07:32 AM (edited) Thanks all. Will proceed in the order Gasaholic recommended and then follow Sqrlgtr recommendation to remove the head. Interested to see if its knocking and banging or sewing machine smooth. Oliver2-44 , I saw those 2 small springs in the kit. I have on old 10gal fish tank that is great for taking things like this apart in. at least there is a good chance to catch anything that might spring out. I put a piece of cardboard over half of the top to block some of it. I picked up a box labeled miscellaneous carburetor parts at the hardware store that's closing and the guy gave it to me. Inside was some loose parts like needle valves and ect from kits that had been opened It was all Kohler parts. I managed to piece together what I believe to be a carter #30 partial rebuild kit along with a new float kit. According to the part numbers on the packages, they should work. There was also a complete Kohler kit for a walbro 25-757-11-s. From everything I have read, my carb should be a Carter #30. Maybe one of you guys could look and see what you think? Also there are 3 different I think (main jets)? 2 are the same while one is different and I see no numbers on them. The different one is smaller than the other 2 and has a tapered tip on it. I also found a package that was mostly intact and had the smaller jet in it. That package part number is 2575701 and google search says it fits a carter #30. The float kit #2575703s also is supposed to fit a Carter #30. I know the carb parts are getting ahead as the carb may not even be any good inside but the box of parts was free. Also there were several loose gaskets and i believe they may also fit. Perhaps one of you all might know. Thanks Charrie Edited Tuesday at 07:37 AM by Charrie Share this post Link to post Share on other sites
Charrie 22 #13 Posted yesterday at 01:44 PM I am trying to understand the wiring diagram so I can test to see if I am getting spark. Right now when turning the key to the start position, nothing happens. The diagram shows a rectifier I am not sure that my 1985 has a rectifier, believe it is unregulated. I do have a Kohler 15amp 3 blade regulator but my understanding from recent reading, one would have to change the stator and do some rewiring. If it works fine like it is then why change it? But here is how I interpret the diagram. One thing that I do not understand is how the seat switch works. Why does it go to the A (Accessory) terminal on the ignition switch? How would not having power on that terminal keep one from starting the engine or kill the engine if you get off the seat? Also i found the seat and PTO switch wires to be spliced together bypassing the switches. I have no clue about the pedal switch yet. 1- The PURPLE wire goes from the S (start) terminal on the ignition switch to the S terminal on the solenoid. There is a pedal interlock switch in that circuit requiring the pedal to be pressed to close the switch. 2- The YELLOW wire runs from the I (ignition) terminal from the ignition switch to the positive terminal on the ignition coil. The negative side of the ignition coil is grounded through the breaker points and condenser.and when the breaker points are open, a spark is created at the spark plug. 3- So, how does the ignition switch receive its 12v power to power the I and S terminals? From the B (battery) terminal on the ignition switch right? From the positive on the battery a RED wire goes to the starter solenoid B terminal. A second RED wire goes from the Starter solenoid B terminal to a 15amp fuse where the RED wire splits and one side stays RED while the other becomes ORANGE. The RED terminates and turns into 2 WHITE wires. One WHITE wire going to what appears to be a diode that might come from the stator. The other WHITE goes to the PTO interlock switch. From the PTO interlock switch, the WHITE wire now turns to TAN and connects to the B (battery) terminal on the ignition switch. The ORANGE wire runs to the seat switch and then to the A (accessory) terminal on the ignition switch. To hotwire, don't I just run a wire with 12 volts to the positive on the ignition coil and then jump out the solenoid to engage the starter? That should bypass everything and i should be able to see a spark on the grounded plug? Thanks Charrie Share this post Link to post Share on other sites
rmaynard 17,608 #14 Posted yesterday at 02:45 PM My suggestion is to download the "demystification guide" from the electrical section of our manuals. Page 423 has the circuitry for your 416-8. Here is a cut from the manual for your spark circuit. 2 Share this post Link to post Share on other sites
Handy Don 17,516 #15 Posted 23 hours ago (edited) I’d love to meet over a cup of coffee with the folks who put together the demystification guide. Simply excellent work. Edited 19 hours ago by Handy Don 2 Share this post Link to post Share on other sites
oliver2-44 11,765 #16 Posted 23 hours ago 2 hours ago, Charrie said: To hotwire, don't I just run a wire with 12 volts to the positive on the ignition coil and then jump out the solenoid to engage the starter? That should bypass everything and i should be able to see a spark on the grounded plug? Thanks Charrie That is correct. One caution. Don’t leave power to the coil for an extended time when it’s no being cranked, you can burn it out 3 Share this post Link to post Share on other sites
Charrie 22 #17 Posted 8 hours ago (edited) Thanks for the replies. I just learned about the Dymysticatation guide yesterday and will be sure and download it shortly. I had ran across a page that had copied some info from that file. EDIT Was just looking at the guide and page 422 shows the main tractor wiring. Like the diagram found here on the forum, it shows a hour meter. My 416-8 never had one. So there is no spark. I have a HF Centech 11 function digital meter so it may not be the most accurate. After charging the very old battery just for testing, With the switch in the RUN position, there was 12.5 volts to the + on the ignition coil. With the switch in the START position and the starter engaged, there was like 11 volts on the + terminal of the ignition coil. I then took the + lead off of the coil and tested it as per instructions found here on the forum. The PRIMARY winding of the ignition coil was reading 3.5 ohms (acceptable 3-5 ohms) The SECONDARY windings of the ignition coil were reading 9.92 (acceptical 6000k - 10,000k ohms) That leaves me guessing that the issue may be in the breaker points? Can a bad condenser cause no spark? Hopefully this afternoon I will be able to take the hood off so I will have good access to work on the breaker points. I probably need to check the wire from the NEGATIVE on the coil to the breaker points and make sure it is not broken anywhere. So if anyone thinks of anything else, please let me know. PS That ohm reading of 9.92 is awfully close to the 10,000k limit? The PO said that he had installed a new coil. PS earlier I mentioned that the starter motor would not engage. After charging the old battery I could hear the solenoid click and then in a few tries, the starter did start engaging. instructions of checking the ignition coil Edited 4 hours ago by Charrie Share this post Link to post Share on other sites
953 nut 69,657 #18 Posted 2 hours ago 5 hours ago, Charrie said: That leaves me guessing that the issue may be in the breaker points? Can a bad condenser cause no spark? Hopefully this afternoon I will be able to take the hood off so I will have good access to work on the breaker points. I probably need to check the wire from the NEGATIVE on the coil to the breaker points and make sure it is not broken anywhere. If the condenser is in question you can disconnect the wire from the coil for testing, if the problem clears up a new condenser is called for. The points gap sets the ignition timing on these engines, best bet is to use the "Static Timing" method as shown in the Kohler Service Manual. This video is also quite good, but i prefer to use a test light rather than a meter because the light will get your attention faster. Share this post Link to post Share on other sites
rmaynard 17,608 #19 Posted 2 hours ago Just a quick point, and I am not going to read back to see if it was covered already.The points gap may be set correctly, but over a period of time just sitting, the contacts will corrode. Clean them with a piece of fine sandpaper, buff them with a piece of a business card or the edge of a dollar bill. 1 Share this post Link to post Share on other sites
Gasaholic 396 #20 Posted 2 hours ago 5 hours ago, Charrie said: So there is no spark. That leaves me guessing that the issue may be in the breaker points? Can a bad condenser cause no spark? Hopefully this afternoon I will be able to take the hood off so I will have good access to work on the breaker points. I probably need to check the wire from the NEGATIVE on the coil to the breaker points and make sure it is not broken anywhere. So if anyone thinks of anything else, please let me know. Quick and easy test on points without even pulling breaker cover: unhook all wires from Coil negative side, which takes condenser out of the equation then set DVOM to read Ohms (or use the diode test function) and test between the negative side wire (going to points) and good engine ground - then roll the engine over by hand (spark plug out makes it easier) you should see the ohms reading go from 0 (nominally, or very low resistance) to infinity (open circuit) as you roll the engine over showing that points are actually making contact and breaking contact. typically on corroded points as they close you might see *some* reading indicating a resistance to ground , but if its greater than say 200 Ohms or so (0.2 on the DVOM set at 1K) then your points are not making contact - you may find them "glazed" but smooth , or oily , in which case a simple cleaning (nail file or emery board from your wife's beauty supplies would do, or buy a cheap one at dollar general) to "sand" the faces of the points and then with points closed, a piece of lint free paper (or a dollar bill) between contacts usually would solve the issue. OTOH, you may find the points with pitted contacts (one side cratered, other side with a matching "mountain") indicating condenser failing or simple "they been there too long" failure so a set of points and new condenser set to proper .020" gap should fix ya. If you still have no spark then, you may also want to check the spark plug wire (corrosion, broken terminals, broken wire internally, etc). One way I used to use to test the whole system was after I put in the points and set the gap, then I'd roll engine to points closed and clean em with the little bit of paper (even feeler gauge can leave oily residue on points) and then turn key on and with a screwdriver blade between the engine and the movable contact arm where the push rod pushes on it, just a quick twist of the screwdriver to "snap open" the points should be enough to create a spark to jump your tester gap. - If that proves out you should be good to button 'er up and get 'er running with reasonable confidence it'll fire off. (assuming that breaker cover isn't making contact with an improperly installed/aligned wire terminal) Share this post Link to post Share on other sites
953 nut 69,657 #21 Posted 1 hour ago 20 minutes ago, Gasaholic said: showing that points are actually making contact and breaking contact. But are they doing so at the correct time? The points gap establishes the ignition timing for these engines. I have seen an engine with a good strong spark run poorly because the timing was improperly set and spark occurred slightly after top dead center. Adjusting the points using static timing solved the problem. Two little hints on finding the timing marks on the flywheel. Prior to looking for the timing marks you can remove most of the rust on the flywheel by using a wooden dowel with sandpaper wrapped over the end. With the sparkplug removed put the dowel through the timing hole and crank the engine a couple of revelations, you may need to do this several times depending on how much rust is there. The keyway on your crankshaft points up when at Top Dead Center. the marks you are looking for will be at the window around TDC so you will know you are in the correct area. 1 Share this post Link to post Share on other sites
