8ntruck 9,314 #1 Posted Friday at 12:34 AM I've had the check engine light come on a couple of times in our 2019 Jeep Cherokee. This has happened after the car has been unused for several weeks. The volt gage says 14.3 volts when running and 12.3 or 4 after shutting the car off, indicating a low charge to me. I suspect that the 'idle' electronics draw is what is draining the (AGM) battery. I'm going to put a battery charger on it tomorrow for a few hours to see if I can get a fuller charge on it. I think i have 2 preventative choices. 1) install a battery shut off to disconnect the battery when the car sits idle, or 2) put a solar powered battery tender on it when it is idle. Comments? Recommendations on a solar charger? Thanks. Share this post Link to post Share on other sites
adsm08 5,164 #2 Posted Friday at 01:18 AM (edited) 44 minutes ago, 8ntruck said: Comments 1) 12.3V is slightly to somewhat discharged, but not enough to cause problems. If the amperage is low enough to cause issues that indicates the battery may not be holding enough charge and needs replaced. 2) Do not install a battery disconnect, it will cause other issues. Particularly if you are in a jurisdiction that has emissions testing. Disconnecting the battery will reset the computer's memory, this means you are also wiping out learned adaptations that make it run smoother and shift better. 3) Modern vehicles are not meant to sit for weeks at a time not being driven. You either need to drive it at least once a week, keep it on a proper tender (not solar, 110 outlet) that is hooked up correctly to allow the battery monitor to see the proper power flow (the ground side of your tender needs to be hooked up on the body, not directly to the battery), or get rid of it and get something older with less constant draw on the system (I would suggest a brand not owned by Stellantis). 4) This vehicle is, by default, equipped with a fairly high amp battery. High amp batteries sulfate and die faster when sitting than low amp batteries do. 5) Have you actually checked to see what the codes are, or are you just assuming they two things are related? Edited Friday at 01:19 AM by adsm08 1 1 Share this post Link to post Share on other sites
8ntruck 9,314 #3 Posted Friday at 02:57 AM No, I haven't checked what the code is. Making a semi-educated guess here. The check light seems to go out after driving the car a bit. Probably left something in the memory, though. Good point on the disconnect - I hadn't thought of that. 1 Share this post Link to post Share on other sites
squonk 48,164 #4 Posted Friday at 09:43 AM Are the batteries original? If so one may be junk and drawing off the good one. Share this post Link to post Share on other sites
ri702bill 13,096 #5 Posted Friday at 09:47 AM 8 hours ago, adsm08 said: (I would suggest a brand not owned by Stellantis). Ah, yes. Since Jeep's acquisition by Stellantis, they use their less than spectacular Fiat Electronics - that have proven to be a major source of their drivability and breakdown issues.... 1 Share this post Link to post Share on other sites
WHX?? 58,231 #6 Posted Friday at 11:24 AM Read the engine codes that might yield some info. Share this post Link to post Share on other sites
Handy Don 17,497 #7 Posted Friday at 02:38 PM (edited) Good thread. My ’22 Volvo had a “low battery” message for me when I returned from a 10-day trip. Service team gave me @adsm08’s advice about the tender and so I’ve done that whenever the car will be unused for than a few days. I also learned that this car “stays awake” for a time after shut down that depends on a slew of sensors--one being that the hood is open and another that it is unlocked! So, once the tender is on, I must close and latch the hood and lock the car lest the car’s “thinking” draw more current than the tender is providing! Edited Friday at 03:18 PM by Handy Don 2 Share this post Link to post Share on other sites
ML3 2,523 #8 Posted Friday at 03:01 PM For sure the new vehicles after sitting a few weeks will cause a battery to go dead. If vehicle was originally equipped with an AGM battery be sure to replace it with the same. Most newer vehicles now have keyless remotes w/push button start. Be sure keyfobs are far enough away from vehicle, definitely not being left inside it. Whenever they are "in range" they will be transmitting/communicating with vehicle theft/start modules therefore increasing battery draw. 2 Share this post Link to post Share on other sites
My_horse 133 #9 Posted Friday at 08:51 PM Some cars with auto start/stop have 2 batteries. A regular sized one and a smaller one. Share this post Link to post Share on other sites
ranger 1,862 #10 Posted Friday at 08:52 PM If you use a solar panel with one of the separate controllers, you might need to fit a switch between the Panel and the controller, the eBay controllers I use require the battery to be connected to the controller first, then the panel. Disconnection needs the panel disconnecting first to prevent the panel from damaging the controller if no battery is connected. I think that this applies to most of the Chinese controllers? My wife’s old Peugeot had an airbag fault which showed on startup. It also locked all the doors. Every internet source said that one of the computers was at fault. The car always started first time on the key no problem? What it turned out to be was the battery voltage dropped when the starter operated to below the voltage threshold of whichever module which controls the central locking, and airbags. The car had been sitting doing nothing for quite a while, (Covld). About a year later, I fitted a new battery, problem solved👍👍👍 Before I retired, I used to get similar issues with VM diesel engines, they would spin over normally on the key, but would not fire. Crank position sensor faulty would display on the diagnostics. VM technicians stripped the engine, new wiring loom, sensors, ecu, everything, no joy? Turned out to be the starter motor. Although the old original turned the engine over as fast as the new one, it pulled the voltage down and the CPS was the first sender to drop out. A machine that had been in our workshop for a month, and had been virtually rebuilt, without a single pop from the exhaust, fired up on the first turn😵💫 Share this post Link to post Share on other sites
adsm08 5,164 #11 Posted Friday at 08:59 PM 6 hours ago, Handy Don said: Good thread. My ’22 Volvo had a “low battery” message for me when I returned from a 10-day trip. Service team gave me @adsm08’s advice about the tender and so I’ve done that whenever the car will be unused for than a few days. I also learned that this car “stays awake” for a time after shut down that depends on a slew of sensors--one being that the hood is open and another that it is unlocked! So, once the tender is on, I must close and latch the hood and lock the car lest the car’s “thinking” draw more current than the tender is providing! I like to install tenders with two-pin bullet connectors with rings on the other end, and run the connector out through the grill, so that you can plug in without ever opening the hood. 5 minutes ago, My_horse said: Some cars with auto start/stop have 2 batteries. A regular sized one and a smaller one. Both should be replaced as a set. Also, cars with this set up need a reset of the battery monitor when replacing the batteries so the charging profile updates and doesn't over-charge. 2 Share this post Link to post Share on other sites
ML3 2,523 #12 Posted Friday at 09:35 PM 40 minutes ago, My_horse said: Some cars with auto start/stop have 2 batteries. A regular sized one and a smaller one. True. My last Cadillac had 2 AGM batteries & it was $600 3yrs ago to replace them. It had the stupid start/stop. New Cadillac has 2 AGM batteries as well but I purchased a plug in bypass harness to permanently turn off start/stop. 1 Share this post Link to post Share on other sites
Handy Don 17,497 #13 Posted Friday at 10:04 PM 54 minutes ago, My_horse said: Some cars with auto start/stop have 2 batteries. A regular sized one and a smaller one. Mine does, too. The 48v “starter" battery’s only jobs are: a) spinning the engine at startup, 2) adding some noticeable torque at launch and acceleration, and 3) spinning the supercharger (when needed 😉). Charging is via brake-triggered regeneration. (I’ve wondered if there was ever any value in kicking a Kohler S/G to “starter” mode for a horsepower boost 🤣.) Everything else, e.g. ignition, electrics, and electronics, is off the 12v AGM. 2 Share this post Link to post Share on other sites
squonk 48,164 #14 Posted Saturday at 10:25 AM Stupid cars! 2 1 Share this post Link to post Share on other sites
adsm08 5,164 #15 Posted Saturday at 01:38 PM (edited) 16 hours ago, ML3 said: True. My last Cadillac had 2 AGM batteries & it was $600 3yrs ago to replace them. It had the stupid start/stop. New Cadillac has 2 AGM batteries as well but I purchased a plug in bypass harness to permanently turn off start/stop. A few years ago my parents bought a brand new vehicle for my mom when she retired. They did a custom order and got it with the stop/start delete, took $50 off the price. Edited Saturday at 01:39 PM by adsm08 Share this post Link to post Share on other sites
Handy Don 17,497 #16 Posted Saturday at 06:11 PM (edited) If you hate auto shutoff/restart, skip this post, please. Personally, I’ve experienced this system in two family cars and several rentals--some implementations are better than others. I’ve gotten used to it and I appreciate its value. Here is the Wikipedia assessment. The US Department of Energy has reported that fuel savings range from 3-5% and, in some cases, up to 12%. Argonne Labs has one study that addresses added component wear and so far, no safety issues have been raised (if there were, insurers would be all over this and they are not). IMHO, frustration with this system is similar to that which goes with CVTs and EVs in general--there is a significant impact on previously learned driving habits and sensations rather than on any significant performance, engineering, economic, or environmental issues. My son's 2026 Honda minivan monitors brake pedal pressure to determine whether or not to shut the engine at stop. Restart takes less than a second and faint starter noise can be heard. My 2022 Volvo V90 monitors numerous situations, including outside/inside temp difference to keep heat or AC running and, I strongly suspect, if the battery is needing charging. Restart is extremely smooth, sub-second, and quiet since the S/G is continuously engaged and belt driven. Frankly, having a vehicle with cameras recording and potentially sharing video with unknown entities for unknown reasons without my knowledge is more troubling. Edited Saturday at 06:12 PM by Handy Don Share this post Link to post Share on other sites
wh500special 2,465 #17 Posted yesterday at 06:04 AM 11 hours ago, Handy Don said: … IMHO, frustration with this system is similar to that which goes with CVTs and EVs in general--there is a significant impact on previously learned driving habits and sensations rather than on any significant performance, engineering, economic, or environmental issues. My son's 2026 Honda minivan monitors brake pedal pressure… My 2022 Volvo V90 monitors numerous situations, including outside/inside temp difference to keep heat or AC running and, I strongly suspect, if the battery is needing charging. …. agreed. FWIW, Honda’s logic also looks at a long list of criteria when it’s deciding whether or not to shut off the engine. Brake pressure is one of them and I use that to game the system when I want the engines in my Hondas to stay on at a light I know is turning, I’m in traffic, etc. The Honda system isn’t particularly smooth, but it’s not too bad compared to the dozens of other cars I’ve had as rentals. Some of them feel like you’ve been rear ended when the engine wakes up. I think (not completely sure) that it also looks at the rate of change of the brake pressure when the pedal is being released to predict if the driver intends to allow the car to move. Very slowly ease off the brake and the engine stays shut down until threshold pressure is hit, back off fast and it lights up the engine even if I don’t release the brake all the way. They also look at demand for steering, battery charge, climate control settings, and if the engine is warmed up. I sometimes vacillate about whether I like the feature or not. I track my fuel economy fastidiously and it’s quite clear it makes a difference. I bought the same make and model vehicle two times in a row with essentially the only difference being this one has a different transmission that accommodates Start/stop and the last one didn’t. This one is getting 1 mpg better overall on the same driving loop as before. In 80000 miles, that’s 144 gallons better. I also appreciate the quiet when sitting at a light. The starters are rated for over 40000 cycles and I don’t keep a car forever, so this is worthwhile to me. Your mileage may vary Steve 1 Share this post Link to post Share on other sites
squonk 48,164 #18 Posted yesterday at 09:50 AM After you buy 2 batteries, possibly a starter and the countless times the car is in the shop for stupid comm codes is the fuel savings worth it? Share this post Link to post Share on other sites
My_horse 133 #19 Posted 22 hours ago 5 hours ago, squonk said: After you buy 2 batteries, possibly a starter and the countless times the car is in the shop for stupid comm codes is the fuel savings worth it? Not for me, it isn’t. Nor is cylinder deactivation, by whatever means they choose. Same with removing 2 cylinders and replacing them with a turbo. Share this post Link to post Share on other sites
Handy Don 17,497 #20 Posted 19 hours ago 8 hours ago, squonk said: After you buy 2 batteries, possibly a starter and the countless times the car is in the shop for stupid comm codes is the fuel savings worth it? 3 hours ago, My_horse said: Not for me, it isn’t. Nor is cylinder deactivation, by whatever means they choose. Same with removing 2 cylinders and replacing them with a turbo. Not interested in an anecdotal back and forth, gents. Cite some research that shows I can expect shorter battery or starter component life to cost more than the fuel savings ($80-90 per year for me) and reduced pollution and I’ll consider changing my mind. Share this post Link to post Share on other sites
squonk 48,164 #21 Posted 18 hours ago I worked on enough vehicles in my lifetime and sold enough batteries and starters to know the costs involved in these systems. I follow a somewhat local shop on YT that deals with this needless crap on a daily basis. His own wife's van left her stranded because the back up camera failed for pete sake. The more complicated the machine, the more prone they are to failure. Share this post Link to post Share on other sites
squonk 48,164 #22 Posted 18 hours ago Here's a semi unrelated example of today's vehicle systems being overly complicated: My own 2011 Honda Ridgeline. Bought it used. one dome light went out so I brought it back as it quit the day after I bought it. The garage looked at it told me it was fixed and guess what? Now no dome lights work with the doors! They tell me they have to order the whole lamp assembly. I doubt their word but ok it's under warranty. I wait 3 weeks. I secure the wiring diagram and it's an overcomplicated mess. I determine the body computer is at fault as it's what supplies the ground for the circuit. Well the lamp comes in and they install it and of course it doesn't fix it. I tell the store owner his guys must have smoked something in the body ECU when they tested it the first time. He relents and orders the $400 ECU and when it arrives they have to get it programmed. The ECU fixes the lights. All this so the dome lights dim slowly and stay on for 30 seconds when the key is turned off. In the old days the lights grounded right at the door jamb switch. Share this post Link to post Share on other sites
squonk 48,164 #23 Posted 18 hours ago Another thing to consider with the fuel savings. How much does the start stop system add tothe cost of the car when you buy it? Let alone the extra cost getting repairs done. Share this post Link to post Share on other sites
adsm08 5,164 #24 Posted 15 hours ago 3 hours ago, squonk said: Let alone the extra cost getting repairs done. Aside from the cancel button the whole system is software. Nothing to replace. 1 Share this post Link to post Share on other sites
squonk 48,164 #25 Posted 13 hours ago Batteries, starter motors, more wires don't need replacing or repairs? Yeah right. The manufacturers didn't come up with all this to save you gas. They did it to make the fuel mileage mandates. How much cheaper would cars be without all of this crap. Same thing in the field I was in before retirement. Used to be able to replace an HVAC blower for about a hundred. Now it's all electronically controlled motors with their own chips. Alot of them fail in a couple of years. Then there ate control boards on top of control boards. All to save a kilowatt here or there to get a better efficiency rating. Costing consumers thousands in the end. Share this post Link to post Share on other sites
