BPEisenhower 738 #1 Posted October 13 (edited) VID_20261013_170841.mp4 Good evening Horse Family 😀. So, I finally got time to see what is what with the two more I just adopted and the good news is that the 14 HP was rebuilt as the tag says. The key switch needs replacement badly since no starter solenoid so, I jumped a wire from positive to coil and fired immediately. Hydraulic lift and drive work with no issues. However, the 12 HP with electric PTO needs rebuilding as the tape from previous owner says but that's not the issue. It has the electric magneto ignition 😭. However, I do see spots where if I want to, I can put the plunger and points in 😃. Since I know that is the route I'm going, any idea what size threads are for the points and the points cover? Should I use the plunger from a used motor? And lastly, are Kohler overhaul kits still available? Last time a year ago I went through NAPA and had to order rings, gaskets, seals and bearings all separate.... I can't remember the number but, I know there was a kit offered years ago with everything in it. Thank you all for the help so far and eager to get at least these 3 ready to go again 😁 Edited October 13 by BPEisenhower Video upload 2 1 Share this post Link to post Share on other sites
953 nut 70,647 #2 Posted October 13 Check out this post, has all the information you will need. 1 Share this post Link to post Share on other sites
Achto 32,961 #3 Posted October 13 (edited) 12 hours ago, BPEisenhower said: are Kohler overhaul kits still available? https://www.ebay.com/itm/380510134569 Edited October 14 by Achto 1 Share this post Link to post Share on other sites
