FLtractor 232 #1 Posted yesterday at 02:58 AM Evening, Here is yet another Marketplace listing.. what model..what’s size deck could that be.. what’s it all worth? 2 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,965 #2 Posted yesterday at 08:59 AM Looks like a 1963 953 or a 1964 1054. 2 Share this post Link to post Share on other sites
Achto 32,765 #3 Posted yesterday at 10:08 AM (edited) With the implements, the price is not too far off if it actually runs. The only quick visual way that I can tell the difference between a 953 and a 1054 is by the drag link for the steering. 953 1054 Edited yesterday at 10:43 AM by Achto 4 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,564 #4 Posted yesterday at 11:24 AM I would think the grader blade alone worth the price of admission... 3 Share this post Link to post Share on other sites
953 nut 69,406 #5 Posted yesterday at 11:47 AM I knew that sooner or later you would find a Wheel Horse project worth bringing home.. 1 hour ago, Achto said: The only quick visual way that I can tell the difference between a 953 and a 1054 is by the drag link for the steering. Also the engine spec # will tell the truth, 953 would be 46-135A and 1054 would be 46-215A. The 1054 had a higher compression head. 3 1 Share this post Link to post Share on other sites
FLtractor 232 #6 Posted yesterday at 02:26 PM 3 hours ago, SylvanLakeWH said: I would think the grader blade alone worth the price of admission... Would the grade and or deck fit my 856? Share this post Link to post Share on other sites
rjg854 13,370 #7 Posted 23 hours ago I believe those attachments are tractor specific. The grader blade may be different. @953 nut would know for sure. 1 1 Share this post Link to post Share on other sites
c-series don 12,474 #8 Posted 20 hours ago I believe the grader blade will fit your 856, the tractor in the pictures has no mid mount Tach-A-Matic to hook the blade to. As others have mentioned, the blade alone is worth the $250 he’s asking for everything. 2 1 Share this post Link to post Share on other sites
ineedanother 2,871 #9 Posted 17 hours ago I hope someone gets it out of the woods for $250 1 1 Share this post Link to post Share on other sites
953 nut 69,406 #10 Posted 8 hours ago (edited) 21 hours ago, FLtractor said: Would the grade and or deck fit my 856? I doubt that the grader blade would work on the 856 though it may, I've never seen a grader blade mounted to a 953/1054. Your 856 is a short frame and the 953/1054 are longer than a long frame, just have to do some measuring. The mower is a 48" and would be too much for an 8 hp engine and is too big to fit under the 856. Edited 8 hours ago by 953 nut fat finger 1 1 1 Share this post Link to post Share on other sites
FLtractor 232 #11 Posted 3 hours ago 5 hours ago, 953 nut said: I doubt that the grader blade would work on the 856 though it may, I've never seen a grader blade mounted to a 953/1054. Your 856 is a short frame and the 953/1054 are longer than a long frame, just have to do some measuring. The mower is a 48" and would be too much for an 8 hp engine and is too big to fit under the 856. Oh ok. Thank you for the helpful info Share this post Link to post Share on other sites
FLtractor 232 #12 Posted 3 hours ago (edited) On 10/13/2026 at 6:08 AM, Achto said: With the implements, the price is not too far off if it actually runs. The only quick visual way that I can tell the difference between a 953 and a 1054 is by the drag link for the steering. 953 1054 Update.. I messaged the seller yesterday and he got back to me today.. this is what he said: attached screenshot.. sounds as if he didn’t take the time to set up up permantly to gravity fed run drive ect? Or this tractor has fuel tank under the seat so CANT gravity feed permanently.. I do have an aviation electric fuel pump I bought for my 856.. took it off and used a piece of rubber to elevate the fuel tank to gravity feed it.. I could use the aviation fuel pump on this 953/1054 if I get it? Edited 3 hours ago by FLtractor Share this post Link to post Share on other sites
