JOEPOE1977
Carburetor
JOEPOE1977
Good afternoon on a beautiful Sunday afternoon. I have a 1990 Wheel Horse 310-8 tractor. I got it running. I ran it for ten shut it off went to restart it again no luck. I took off the air cleaner put a little gas in the the carburetor it ran again. Shut it off same thing will not start until I put gas in the carburetor. All help again will be much appreciated from all of you.
ineedanother
You can probably resolve that by replacing the fuel line which should be done every few years. Run non-ethanol fuel if you have access to it. Another option would be to add a primer bulb or electric fuel pump. Lots of threads on here about any of those.
pfrederi
Take the fuel line off the carb crank the engine does gas spurt out???
953 nut
An old fuel line can have minute cracks in it that won't leak gas yet but will allow air into the line and the fuel pump can't pump air.
JOEPOE1977
Yes pulled the gas line off the carb and the gas spurts out. I will get fuel line tomorrow.
lynnmor
While fuel line is a good idea, the fact that gas is getting to the carburetor indicates that the problem is within the carburetor.
