Bar Nuthin
My first starter-generator. Is it loud?
Bar Nuthin
1 hour ago, ri702bill said:
If you remove the guard (for test purpose only) is it still loud??
The belt noise goes away. And I can hear that the majority of the whine is from the pulley side bearing.
ri702bill
That there is a two-fer. ID'd the belt rub and the bad bearing. Win-win.:handgestures-thumbupleft:
Bar Nuthin
Getting the belt guard aligned is a tricky proposition. There's very little clearance overall so a gain at one spot creates a tight spot somewhere else.
Ended up bolting down the guard and running the engine, then tapping around with small rubber mallet until I found the sweet spot where the noises disappeared.
Sometimes you just gotta go with what works. :confusion-shrug:
  • Excellent 2
Bar Nuthin
Update - so the belt guard gradually went back to its rubbing and belt slapping.
The only way I could get the proper clearance was to remove the front bracket bolt. Seems great now, except the front bracket is about an 1/4" above the hole it bolts into.
I tried bending it but that wasn't working out. The only solution I can think of is to separate the spot welds and relocate the bracket.
Anyone here ever experienced this anomoly?
IMG_6075.jpg.554c1c4da94f67a6245f5f8c8a5de788.jpg  IMG_6076.jpg.cea9dea9ab4c5fe65f21ee9fff2f6246.jpg
  • Sad 1
WHX??
Welcome to my world. :lol:
Any chance you got the wrong belt guard? There was one with three lines on it and one plain and they are definitely different. Apparently 7 & 8 HP.  One is larger on the SG pulley end for a larger pulley and more clearance overall. I think its the one with the lines. Looks like you have the plain one.
We was just yakin about this i was having a fit trying to get one to quit rattlin. Here I had the wrong one.
Edited by WHX??
Bar Nuthin
For the K161 alone there are 3 variants, depending on the spec number. My spec calls for variant 77 - part# 231835.
Good grief!
Bar Nuthin
6 actually
Bar Nuthin
Now that I've eliminated the hot spots and the belt slap. I think I'll go with the plan to separate the spot welds and relocate the bracket.
