slk 36 #1 Posted 23 hours ago The lift arm on the right side of the tractor looks like it needs a spacer that raises the deck. Is that suppose to be like that?? Share this post Link to post Share on other sites
Bar Nuthin 3,193 #2 Posted 23 hours ago Should be tightened, but just enough to still allow the front bracket to pivot. Share this post Link to post Share on other sites
slk 36 #3 Posted 23 hours ago It would have to be tightened about 3/4” to even come close. Share this post Link to post Share on other sites
ri702bill 13,027 #4 Posted 22 hours ago Download the manual for the deck - there is a steel bushing as npart of that linkage - yours seems to be missing. Share this post Link to post Share on other sites
slk 36 #5 Posted 22 hours ago I do not even know what deck i have but I was thinking there should be a bushing of sorts in there as well. Are there manuals for the decks here on the site? Share this post Link to post Share on other sites
ri702bill 13,027 #6 Posted 22 hours ago Absolutely - all free to download. In the Manuals section. under Implements - Mower Decks and Reels. A storehouse of knowledge there. There may also be notes of interest on the download page - NLA parts and superceeded P/N's - those kinds of helpful things. Disassemble one of the other ends of the linkage - check out the bushing... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #7 Posted 21 hours ago Will guess this is a 42" side discharge deck. Here is a list of the possible candidates so you have model numbers to search. Decks are sized by their width of cut - not the width of the deck. If you want to check enter a model number as written here and it will quickly show an illustrated parts list without downloading anything. Then you can search for manuals in our library. https://www.partstree.com/ Mower DNA 42" side discharge 1966-1967 model RL-426 (Have operator manual) replaced by 1968 model 5-1421 (Have operator manual) 1969 model 5-1422 (Have operator manual) 1970 model 5-1423 (Have operator manual) 1971 model 5-1000 (Have operator manual) 1971-1972 model 5-1001 (Have operator manual) 1973-1974 model 5-1010 (Have operator manual) 1975 model 5-1011 (Have operator manual) 1975 model 5-1012 (Have operator manual) 1976 model 65-42MS01 (Have operator manual) - Online Toro parts illustration is the 48" SD deck 1976 model 65-42MS02 (Do not have operator manual) - Online Toro parts illustration is the 48" SD deck 1977 model 75-42MS01 - (Do not have operator manual) These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- These decks all use blades with a 3/4" center hole. 1977 model 75-42MS02 replaced by (Do not have operator manual) 1978 model 85-42MS01 (Do not have operator manual) 1979 model 95-42MS00 (Do not have operator manual) 1979 model 95-42MS01 (Do not have operator manual) 1980 model 05-42MS01 (Have operator manual) 1981-1983 model 05-42MS02 (Have operator manual) 1984 model 05-42MS03 (Have operator manual) - Last year for bearings with 3/4" ID 1985 model 05-42MS04 (Do not have operator manual) - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MS05 (Have operator manual) 1989 model 15-42SC01 (Do not have operator manual) 1990 model 15-42SC02 (Have operator manual) 1990-1992 model 15-42SC03 (Have operator manual) 1993-2007 and 2009-2012 model 78345 (Have operator manuals) These decks all use blades with a 3/4" center hole. Note - 17mm is .669" Share this post Link to post Share on other sites
slk 36 #8 Posted 19 hours ago Ok From what I saw there is a bushing on both sides of that mower deck. One side is bolted with just a washers clearance leaving the side in the pic with a 1” gap. So if I make up 2 bushings that will give me a 1/2” spacing that should equal out the deck alignment pretty good. So allowing the 1/8” thickness of the inside bracket and the 1/2” space I will make some up that are 5/8” long by 5/8” diameter. That should align the deck up pretty good. BTW my deck is a 42MS01 Steve 2 Share this post Link to post Share on other sites
Rick3478 467 #9 Posted 6 hours ago No, It's not supposed to be like that. There are some parts missing. Should be a shoulder bolt or bolt and bushing. Find the exploded parts list for your deck model. If you have any trouble sourcing the parts, I probably have some used ones. - Rick Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #10 Posted 5 hours ago 14 hours ago, slk said: BTW my deck is a 42MS01 Steve Do you know what the first number is? The 2nd number will be a 5 for mower decks. A second set of numbers will be the serial number and if there is a 3rd set it will be the Julian build date. Share this post Link to post Share on other sites
slk 36 #11 Posted 2 hours ago Here is a pic that might help Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #12 Posted 7 minutes ago With a build date of October 12, 1976 will guess the deck is a 1977 model 75-42MS01 Share this post Link to post Share on other sites
