Sarthurs01
Key switch
Sarthurs01
I’m in need of a new key switch for my Raider 10 with Tecumseh with no starting solenoid. Any have a replace ment that worked well for them.. here’s a pic of the old one.
Achto
If you were to add a starter relay, then you will be able to use most any key switch that has an M terminal. :twocents-twocents:
Bar Nuthin
wheelhorsepartsandmore.com sells them, but the price is a bit steep.
There is a thread on here about someone converting their setup to use a starter solenoid and less expensive switch
Edited by Bar Nuthin
Achto
I thought of that too. His are for a battery ignition not a magneto.
WHX??
They are out there but yes $$. Couple of used ones on fleabay but a roll of the dice their any good.
Bar beat me to Mike's thread.
WHX??
Yeah that might take the purest right out of me ... :lol:
  • Haha 1
ri702bill
It is always better to use a solenoid in the ignition circuit - it removes the heavy amperage load from the key switch and gives it to the better suited device. High amperage thru the key switch generates arcing & excess heat - both shorten its lifespan.
  • Excellent 2
WHX??
This is true. Since the bulk of my herd is early 60s SG tractors I keep replacement switches "in stock". :)
953 nut
:text-yeahthat:
Less expensive, more reliable and gets the high amperage wires out from behind the gas tank. This drawing uses the 103991 ignition switch which can be found at any auto parts store.
  • Excellent 2
WHX??
When I restoed a 1067 PO had converted it to solenoid. I was on the fence about going back to original since I am a purist but what the heck it was considered a custom anyway so just cleaned up with new wiring. Good decision since it's a go to tractor.  Can then use the very common $10 four term switch and they last forever.
Edited by WHX??
more pics
  • Excellent 6
ri702bill
And that keeps the wiring short in length and tidy.
I added mine on the 854 by making up a plate and mounting to the tail of the S/G...
Edited by ri702bill
  • Like 6
pfrederi
If you go with an original style high amp switch i would suggest replacing the old heavy stiff cables with awg 6 welding or super flex cables.  Much easier to wire and less stress on the  ignition switch
Edited by pfrederi
  • Like 5
