BPEisenhower
Snowthrower compatibility....
BPEisenhower
Hello all! After much debating, I'm going to give the C195 a workout.....with snowthrower. However, it's from that 520H and want to know if its going to work with my C195.. (fingers crossed).
wallfish
Yes, it will work.
Weights and chains make better traction. I even use #40 roller chain wrapped around the fronts for much better steering.
Adjust the ground speed as necessary to keep it loaded up and keep it from clogging
  • Excellent 2
ri702bill
And a quick spray down on the auger & chute with your favorite slick stuff in a can before the storm helps. I find the cheapo store brand cooking spray works fine - just don't leave the can outside in the cold!
BPEisenhower
20 hours ago, wallfish said:
Yes, it will work.
And so, I got it attached to the front of my C195 and now another problem, the lifting rod that slides in and out of the tube, where does it pin to? Plus, the drive belt needs to be changed, too short. Not sure how it went on a 520 but it's a pain...
wallfish
The flag pins to the bellcrank.
you can find the manual in the manuals section
