Granite Stater 0 #1 Posted September 26 Hello I bought a 1994 314-8 Toro Wheel Horse and I tried to remove the Mule belt from the PTO, unlike my 312-8 which pivots and swings down out of the way the 314-8 does not pivot the same way, so I guess I have to disconnect more parts? Loyal Wheel Horse owner for 40 years Share this post Link to post Share on other sites
nylyon-(Admin) 9,196 #2 Posted September 26 Welcome to the forum, you should just need to remove the control rod and the pin on the outside of the PTO bell unless you have something different? Share this post Link to post Share on other sites
Ed Kennell 47,942 #3 Posted September 26 If your "U" clip is pinned to the PTO hoop, you will need to pull the hairpin clip at the bottom of the hoop and let the hoop drop down till the U clip clears the stub shaft. Then you should be able to swing the hoop to the rear and remove the belt. 3 Share this post Link to post Share on other sites
peter lena 10,125 #4 Posted September 26 @Granite Stater your pto lever start area is a GOLD MINE FOR FUNCTIONAL IMPROVEMENTS ! experimented on one unit . my original c-85 , then added it to my other 2 Horses . most interesting areas ? movement HAND OFF POINTS ? how easy was it to do , that inspired me to look at other areas , heim joint , replacement to sloppy trundle , easy 3/8 x 24 die nut rethread , right over original 3/8x16 , oil lube enhanced , very easy , pto cone inner needle bearing ? lubrication failure ? heat baked grease , clean out , flush , carb cleaner , very lightly regrease with ? lucas xtra hd green chassis grease , 550 deg flash point , also polyurea , anti sling , napa has the outer sealed bearing , makes for effortless engagement , walmart has the lucas grease , $ 8, also use that grease in all my , deck and mule drive bearings , never burned out a clutch disc . easy , pete Share this post Link to post Share on other sites
Ed Kennell 47,942 #5 Posted September 26 2 hours ago, Granite Stater said: Loyal Wheel Horse owner for 40 years to the Glad you found us. Share this post Link to post Share on other sites
