Maeves horse 0 #1 Posted Thursday at 10:03 PM I e never been able to get the throttle cable bracket to stay secure behind the throttle plate. Ive looked at countless shop manuals and photographs and can’t keep the bracket from popping out from behind the throttle plate. Any advice would be appreciated. Share this post Link to post Share on other sites
ri702bill 12,933 #2 Posted Thursday at 10:48 PM Welcome! More info is needed here. What year & model tractor? Is that engine original to that tractor? I ask because 30 plus years of use, a lot can change (or be changed)... Share this post Link to post Share on other sites
953 nut 68,895 #3 Posted Thursday at 11:10 PM This thre3ad can probably be helpful. 1 Share this post Link to post Share on other sites
Maeves horse 0 #4 Posted 10 hours ago The 855 is from the mid sixties and to my knowledge, it’s the original 8hp k181. It was purchased from the original owner 40 years ago. At one time the throttle cable was a generic after market type. When I rebuilt the tractor years ago I bought an oem cable. I’ve never been able to get it to work properly by attaching the cable to the throttle plate as indicated in the shop manual. Out of desperation, I put the cable in the hole on the throttle arm. This was done mainly because the cable bracket won’t stay put behind the throttle plate. Share this post Link to post Share on other sites
953 nut 68,895 #5 Posted 10 hours ago The cable should be going to the governor and the governor adjusted for operating RPMs. 1 Share this post Link to post Share on other sites
sqrlgtr 3,813 #6 Posted 5 hours ago 4 hours ago, Maeves horse said: The 855 is from the mid sixties and to my knowledge, it’s the original 8hp k181. It was purchased from the original owner 40 years ago. At one time the throttle cable was a generic after market type. When I rebuilt the tractor years ago I bought an oem cable. I’ve never been able to get it to work properly by attaching the cable to the throttle plate as indicated in the shop manual. Out of desperation, I put the cable in the hole on the throttle arm. This was done mainly because the cable bracket won’t stay put behind the throttle plate. You should be able to "snug up" the bushing that holds the disc that is behind the governor arm. I may not be understanding problem though. Its the big nut right behind the arm thats in pic of thread that @953 nut linked to above. Share this post Link to post Share on other sites
Maeves horse 0 #7 Posted 4 hours ago If I put the bracket where it belongs and I tighten the big brass governor nut too much, the cable bracket won’t fall out. However, if I loosen the throttle plate moves as it should, the bracket falls off i also see photos where the bracket is set at 12 o’clock even though the shop manual indicates a 9 o’clock mounting. Share this post Link to post Share on other sites
sqrlgtr 3,813 #8 Posted 3 hours ago 34 minutes ago, Maeves horse said: If I put the bracket where it belongs and I tighten the big brass governor nut too much, the cable bracket won’t fall out. However, if I loosen the throttle plate moves as it should, the bracket falls off i also see photos where the bracket is set at 12 o’clock even though the shop manual indicates a 9 o’clock mounting. Ok the tractor in pic below had almost same problem. When I got it, the disc was stuck and would not move. It ran great but had no governor . PO had throttle hooked directly to carb butterfly, not good. I had to take bushing apart and clean/deburr everything up. After doing this and setting everything back up the way it was supposed to be it works great. You may be able to do the same and if anything is messed up someone may have a replacement bushing/nut they would part with. . 1 Share this post Link to post Share on other sites
