FLtractor
856 K181 cylinder pictures. Terrible quality.. condition?
FLtractor
Evening,
Used cheap phone borescope first time ever looking at cylinder … to look into 856 K181 cylinder to see condition.. terrible quality but can someone tell me
what I’m looking at? Worth keeping this engine based on these pictures if able
to even tell that?
Edited by FLtractor
Achto
Really hard to tell through the spark plug hole, mainly because you can't look into the cylinder.
A better way to know is to take the head off. This allows you to inspect and measure the cylinder bore.
I have not encountered too many K model Kohlers that were not worth rebuilding yet.
Engine not worth rebuilding -
1 - There is a window (hole) in the side of the block where insides exited.
2 - The bore is more than .030 over sized already.
3 - Water intrusion has rusted the insides beyond repair.
Get the bore and crank pin measured before ordering any parts so you know what you will need.
One source for parts
https://www.ebay.com/itm/143366218290
You will most likely pay about the same amount for machining as you do for the parts listed above.
The Kohler manual does a great job of walking you through the rebuild process from start to finish.
https://resources.kohler.com/power/kohler/enginesUS/pdf/tp_2379.pdf
Edited by Achto
  • Like 4
FLtractor
Oh I read online that the cylinder can be looked at with borescope through spark plug hole … so then what am I lookin at.. the combustion chamber? Was hoping didn’t have to take Head off engine. Gonna have to research how to do so as never done on any engine
Achto
I added the Kohler manual to my post above. This manual has great step by step instructions for disassembly and assembly.
When you look through the pug hole on a flat head engine, you are looking at or between the valves, you can not turn the camera enough to see down the bore. Look at the pic below, the plug hole is over the two smaller holes for the valves.
Kohler k181 gravely spec engine block. It has the transmission lip machined  to the PTO side. Standard bore. No cracks or issues. Located in  Mechanicsville, VA. 50.00
Under side of the head.
Cub Cadet Original 70 71 72 73 Kohler K161 K181 Cylinder Head & Gasket 7 8  HP
Edited by Achto
  • Like 7
FLtractor
Oh ok that really helps understand what I was looking at in comparison to the cylinder.. thank you
