Retired Wrencher 6,954 #1 Posted 12 hours ago Hi I am looking for info on b-60 interlocking system. If anybody has this model with experience do you really need those interlocking switches? I’ve had this for a couple months, but I never really took a look at it to see if the switches are actually there. It’s pretty dirty so I clean this over the winter time.There is no engine on it know. The tranny has blown out seals. So that will be first. then disassemble the rest. Hang frame a clean every inch. That way I can see what is there. I found a switch for it but no key. Thanks for any help. Share this post Link to post Share on other sites
Racinbob 13,119 #2 Posted 11 hours ago You didn't mention what year but they are likely the same. It couldn't get much more basic other than an older model with nothing. Here's the wiring for a 76 B. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,262 #3 Posted 6 hours ago Never seen a real B-60 in person. So you have to press the clutch pedal while pull starting it? Interesting, hopefully you have good balance and she fires up in a pull or two. Share this post Link to post Share on other sites
squonk 47,989 #4 Posted 6 hours ago 7 minutes ago, Sparky said: Never seen a real B-60 in person. So you have to press the clutch pedal while pull starting it? Interesting, hopefully you have good balance and she fires up in a pull or two. Imagine yanking it without pushing in the clutch and it's in 3rd with a wide open throttle and it fires up! That would be a hoot! Share this post Link to post Share on other sites
rjg854 13,330 #5 Posted 5 hours ago 33 minutes ago, squonk said: Imagine yanking it without pushing in the clutch and it's in 3rd with a wide open throttle and it fires up! That would be a hoot! Video please Share this post Link to post Share on other sites
