squonk 48,426 #1 Posted September 18 Get out your torn up jeans,Brylcream tight white T shirts, and roll a pack of cigs into the sleeve................ No Wait! not that kind of Greaser Day. It's time to lube the fleet before the cold weather sets in. Dewalt gun works nice but it's also a pain to operate. ant to top it off, the Lock n Lube end failed. Came with a kit but the thing wouldn't come apart to repair it. So I has to get an old school gun end out. Got a leaky bucket cylinder on Elvis so got that ordered. Heard an engine running all afternoon. My retired engineer neighbor just got a new Westinghouse Genny from Amazon. The recoil was messed up so they sent him a new one. I had to wander over. His solar panels aren't charging his battery bank so he's charging it with the Genny. I mentioned $4.50 a gal gas and he could just plug the bank in to charge it He shrugged his shoulders and said "I know but I like it this way" 7 10 Share this post Link to post Share on other sites
ri702bill 13,389 #2 Posted September 18 Next up for me is to drag out the Ariens SnoThro, change the oil & the friction disc. Pull the bucket apart to inspect / relube / replace the high speed sealed ball bearing. Look at why the NLA gearbox is leaking... No fun doing all that when it is 20 degrees outside... 4 Share this post Link to post Share on other sites
Retired Wrencher 7,042 #3 Posted September 19 (edited) Mike that is nice set of tractors. I like Start/Gen the most. They just made them simple but rugged. That Economy will get the job done. Edited September 19 by Retired Wrencher Share this post Link to post Share on other sites
Achto 32,961 #4 Posted September 19 14 hours ago, squonk said: I mentioned $4.50 a gal gas and he could just plug the bank in to charge it He shrugged his shoulders and said "I know but I like it this way" Batteries work better when you use gasoline to charge them. 1 5 1 Share this post Link to post Share on other sites
Pullstart 71,561 #5 Posted September 19 35 minutes ago, Achto said: Batteries work better when you use gasoline to charge them. Unless you have a diesel, then you can put more torque in the bank! 1 1 Share this post Link to post Share on other sites
WHX?? 58,387 #6 Posted September 19 1 hour ago, Achto said: Batteries work better when you use gasoline to charge them. And usetens of thousands of gallons of diesel to make batteries 2 Share this post Link to post Share on other sites
peter lena 10,123 #7 Posted September 19 @ri702bill whats the scoop on that sealed bearing ? nothing available in a wide side seal set up ? made a regular thing of eliminating , repeditive lubrication issues , my instant go to on any lubrication , failure , is lucas x tra hd green chassis grease , walmart 8 $ , wipe out original lube , carb cleaner flush , hand pack , lucas . 550 deg flash point , polyurea rated , anti sling , this , and functional detailing makes a pto set up , come to life, just curious , pete Share this post Link to post Share on other sites
ri702bill 13,389 #8 Posted September 19 15 minutes ago, peter lena said: @ri702bill whats the scoop on that sealed bearing ? nothing available in a wide side seal set up ? made a regular thing of eliminating , repeditive lubrication issues , my instant go to on any lubrication , failure , is lucas x tra hd green chassis grease , walmart 8 $ , wipe out original lube , carb cleaner flush , hand pack , lucas . 550 deg flash point , polyurea rated , anti sling , this , and functional detailing makes a pto set up , come to life, just curious , pete It is a standard double sealed ball bearing that has miserable living conditions! Inaccessable behind the secondary impeller and gets wet constantly. I replaced it about 10 - 12 years ago... probably due for a new one. 1 Share this post Link to post Share on other sites
clueless 3,440 #9 Posted September 19 Mike, did the economy tractor come with the loader or did you buy it separately? I've been looking for that whole set up (tractor and loader) for a couple of years now. Share this post Link to post Share on other sites
squonk 48,426 #10 Posted September 19 1 hour ago, clueless said: Mike, did the economy tractor come with the loader or did you buy it separately? I've been looking for that whole set up (tractor and loader) for a couple of years now. Loader was built by my welder buddy using mostly original Economy plans. I did the hydraulics. 1 Share this post Link to post Share on other sites
