hotajax
Curious: Service Life of a Spindle Belt
hotajax
I use the #1594 belt on my 48" deck.  How long can I expect it to go?  Do you guys change belts just because they've been on for X number of years, or just wait til they snap?  Thanks.
ri702bill
Neither. Belts tend to fatigue when left under tension on the diameter of the pulley(s).
That is why I release the spring loaded idler on my Ariens walkbehind SnoThro in the off season AND after every storm it is used. The belt tends to "Chunk" if left in that tight radius shape for a long time and suddenly relaxed.
The deck belt unfortunately does not have an easy way to do that. I inspect the deck and PTO belt at the start of the cutting season & replace one or both if they are questionable. The old one(s) go back into the cardboard sleeve that is marked for the tractor & application. That way, there is a "spare" and a part number hanging on the wall... In the event of a duplicate, keep the better of th two & toss the other...
Edited by ri702bill
peter lena
@hotajax  why do  belts  fail?  more often than not , LUBRICATION FAILURE IN  RELATED BEARING ! incremental  bearing  freeze up , literally  stops belt , starting  reaction  WAVE , VIBRATION , sound familiar ?  bet there  are a few bearings that are rough , /noisy .  regular replacement  maint , pete
tunahead72
19 hours ago, ri702bill said:
... I inspect the deck and PTO belt at the start of the cutting season & replace one or both if they are questionable. The old one(s) go back into the cardboard sleeve that is marked for the tractor & application. That way, there is a "spare" and a part number hanging on the wall... In the event of a duplicate, keep the better of th two & toss the other...
That's pretty much exactly what I do, maybe with a couple extra inspections during the mowing season.  "Questionable" to me means numerous noticeable splits or other nasty-looking flaws on the underside of the belt.  Those two belts have typically lasted several years on my Wheel Horses.  I can only think of 2-3 times one of them has actually snapped while mowing, the timing is never good when that happens, and it can be a real pain if you don't have spares.
Releasing the tension on the PTO belt as @ri702bill suggests sounds like a really good idea, and easy to do.  I think I'll start doing that soon, at least at the end of the season. :hide:
And keep those deck spindles lubricated.
peter lena
@tunahead72 @ri702bill  did this  many years ago ,  every related , bearing , including , mule drive and pto cone , needle bearing  , has been wiped /. flushed out , carb cleaner ,  LUCAS  X TRA HD , GREEN CHASSIS GREASE ? 550 deg  flash point , also polyurea rated . anti sling , walmart , $8 , no bearing whine , or failure's , another  related failure area ?  pto  drive clutch plate ,  NEVER  BEEN REPLACED ? WHY ?   because all related , rotational  movement  areas , move with  quiet ease , 3 horses with the same upgrade  , no  failures or noise , also sun bake my mower decks , with  oil , like this , no failures / rust , pete
peter lena
@hotajax  this also refers to you !  no  bearing  noise or failures , also no  deck rot , REPEDITIVE FAILURE  ,EVOLOUTION !  make a change , have this on / in 3 decks , consistently  works for me , pete
Brockport Bill
i just had deck off to clean underneath before leaf season when deck will have heavy use -- plus we have gotten lots of rain so grass has been growing thus its thicker than when its brown, dry and thin grass mid summer - soooo - while deck was off i noticed a crack in belt -- so i changed it -- would rather be time efficient than have it snap when least convenient  - belt was from last summer so it had a good life
