gwest_ca-(File Mod) 12,454 #2 Posted 11 hours ago There may be something in this service bulletin that will help. Are your cables in the correct holes at the bottom of the brackets? 1 Share this post Link to post Share on other sites
JoeM 10,157 #3 Posted 6 hours ago this is a pic of my old magnum. I am going from memory shorten the screw will increase max rpm Share this post Link to post Share on other sites
bradleydavidgood 38 #4 Posted 2 hours ago Thank you both for those. I put them next to each other and there are several things different but I think one is the same. And I see that my screw is not upside down, but I don't see how that screw contacts anything. I'm going to take a picture of mine today and put all three next to each other. I'm also going to set up 3 cameras and do a video showing the linkage moving while running and moving the throttle. Share this post Link to post Share on other sites
702854boy 1,104 #5 Posted 1 hour ago 20 minutes ago, bradleydavidgood said: . And I see that my screw is not upside down, but I don't see how that screw contacts anything. It looks like there is a little bent out tab at the bottom of the throttle pivot that would hit against the screw to prevent over revving the engine 1 Share this post Link to post Share on other sites
953 nut 68,516 #6 Posted 42 minutes ago (edited) How do I get higher RPMs governor Wheel Horse 414–8 Magnum Kohler 14 The question you are asking runs counter to the purpose of the governor. The attached manual has a step by step adjustment process. Try moving the rod that is presently in the sixth hole to the third hole and see if it becomes more responsive. To adjust the mechanical governor on a Kohler engine follow these steps. Turn off the engine: Ensure the engine is completely off and cool before working on the linkage. Set throttle to wide open: Move your equipment's speed control lever to the fast or high-speed position so the carburetor throttle butterfly is pushed completely open. the governor arm nut: Find the bolt or nut that clamps the governor arm to the metal cross shaft coming out of the engine block. Loosen it just enough so the arm can rotate freely on the shaft. Rotate the governor shaft: Hold the carburetor throttle wide open, then rotate the governor cross shaft as far as it will go in the direction that pulls the throttle open until it bottoms out and stops. Tighten the clamp nut: While holding the carburetor wide open and the governor shaft fully rotated to its stop position, securely tighten the clamping nut or bolt on the governor arm. Torque it down properly (typically around 60 inch-pounds if using a torque wrench) With this understanding, here’s how to check the governor. Manually move the governor arm/throttle lever back and forth between the stops. Observe the amount of movement and the tension on the governor spring. Detach the spring from the governor arm. Position the governor arm/throttle in the middle and start the engine. Gradually adjust the governor arm to slow down and speed up the engine. As the engine speed rises, you should notice an increase in tension on the governor arm, and as the engine speed drops, the tension should decrease. If there is no tension at all, the governor is likely faulty, and the engine will need to be disassembled for inspection. The primary purpose of the governor on a Kohler air-cooled engine is to maintain a constant engine speed (RPM) under varying workloads. It is not to speed the engine up; the governor's role is to attempt to slow the engine down. The faster the engine runs, the more pressure is exerted on the governor shaft (in the engine) and arm. The point at which the force from the governor (trying to slow the engine) matches the force from the governor spring (trying to speed the engine up) and maintains a steady engine speed is referred to as the governed speed. When you use equipment like a lawnmower, tractor, or generator, the engine encounters different levels of resistance (such as hitting tall grass or drawing an electrical load). The governor automatically adjusts the throttle to keep the engine running at its optimal speed, preventing it from stalling or over-speeding. When the governor detects Load Changes its RPM naturally starts to drop. The governor senses this drop in speed and automatically opens the throttle valve to let in more fuel and air, restoring the engine to its target speed. Conversely, if the load is suddenly removed, the engine speed will rapidly increase. The governor responds by closing the throttle to prevent catastrophic internal engine damage from over-revving. Kohler’s mechanical (Centrifugal) Governor: Uses internal flyweights attached to a gear inside the engine. As the engine spins, centrifugal force moves the weights, which act on a shaft and linkage connected to the carburetor throttle. When the engine is off, the governor spring keeps the throttle in the wide-open position. Upon starting the engine, the governor, which consists of a centrifugal weight inside the engine, begins to spin. Centrifugal force pushes a weight outward, applying pressure on the governor shaft and causing it to turn. The governor arm, connected to the governor shaft outside the engine, also moves. With this understanding, here’s how to check the governor. Manually move the governor arm/throttle lever back and forth between the stops. Observe the amount of movement and the tension on the governor spring. Detach the spring from the governor arm. Position the governor arm/throttle in the middle and start the engine. Gradually adjust the governor arm to slow down and speed up the engine. As the engine speed rises, you should notice an increase in tension on the governor arm, and as the engine speed drops, the tension should decrease. If there is no tension at all, the governor is likely faulty, and the engine will need to be disassembled for inspection. Edited 23 minutes ago by 953 nut 1 Share this post Link to post Share on other sites
bradleydavidgood 38 #7 Posted 19 minutes ago 16 minutes ago, 953 nut said: How do I get higher RPMs governor Wheel Horse 414–8 Magnum Kohler 14 The question you are asking runs counter to the purpose of the governor. The attached manual has a step by step adjustment process. The primary purpose of the governor on a Kohler air-cooled engine is to maintain a constant engine speed (RPM) under varying workloads. It is not to speed the engine up; the governor's role is to attempt to slow the engine down. The faster the engine runs, the more pressure is exerted on the governor shaft (in the engine) and arm. The point at which the force from the governor (trying to slow the engine) matches the force from the governor spring (trying to speed the engine up) and maintains a steady engine speed is referred to as the governed speed. When you use equipment like a lawnmower, tractor, or generator, the engine encounters different levels of resistance (such as hitting tall grass or drawing an electrical load). The governor automatically adjusts the throttle to keep the engine running at its optimal speed, preventing it from stalling or over-speeding. When the governor detects Load Changes its RPM naturally starts to drop. The governor senses this drop in speed and automatically opens the throttle valve to let in more fuel and air, restoring the engine to its target speed. Conversely, if the load is suddenly removed, the engine speed will rapidly increase. The governor responds by closing the throttle to prevent catastrophic internal engine damage from over-revving. Kohler’s mechanical (Centrifugal) Governor: Uses internal flyweights attached to a gear inside the engine. As the engine spins, centrifugal force moves the weights, which act on a shaft and linkage connected to the carburetor throttle. When the engine is off, the governor spring keeps the throttle in the wide-open position. Upon starting the engine, the governor, which consists of a centrifugal weight inside the engine, begins to spin. Centrifugal force pushes a weight outward, applying pressure on the governor shaft and causing it to turn. The governor arm, connected to the governor shaft outside the engine, also moves. With this understanding, here’s how to check the governor. Manually move the governor arm/throttle lever back and forth between the stops. Observe the amount of movement and the tension on the governor spring. Detach the spring from the governor arm. Position the governor arm/throttle in the middle and start the engine. Gradually adjust the governor arm to slow down and speed up the engine. As the engine speed rises, you should notice an increase in tension on the governor arm, and as the engine speed drops, the tension should decrease. If there is no tension at all, the governor is likely faulty, and the engine will need to be disassembled for inspection. How does the question I am asking run counter to the purpose of the governor if as the service manual says, the max RPM is 3600, the engine is running way below that, and the service manual gives instructions on how to raise the RPM by adjusting the high speed adjusting screw? It says: The primary purpose of the governor on a Kohler air-cooled engine is to maintain a constant engine speed (RPM) under varying workloads. Therefore, if the governor is not maintaining a high enough engine speed, it needs to be adjusted higher. And the RPM can be adjusted higher or lower which is the purpose of the high speed adjusting screw. Thanks! Share this post Link to post Share on other sites
bradleydavidgood 38 #8 Posted 9 minutes ago (edited) Thank you for the other manual. While it is not the same engine or linkage, it is helpful. See below screenshots. It also has wording confirming the ability to increase engine speed by adjusting, which is my question. And I will try the adjustment method below. However, I'm first more interested in the linkage on the front right side of the motor, where the high speed adjustment screw is as in post #4. I think my linkage is different than both in that post. I don't think we have established the correct initial linkage setup for that front right side and I'd like to do that. Thanks! Edited 2 minutes ago by bradleydavidgood Share this post Link to post Share on other sites
bradleydavidgood 38 #9 Posted 6 minutes ago 2 hours ago, bradleydavidgood said: Thank you both for those. I put them next to each other and there are several things different but I think one is the same. And I see that my screw is not upside down, but I don't see how that screw contacts anything. I'm going to take a picture of mine today and put all three next to each other. I'm also going to set up 3 cameras and do a video showing the linkage moving while running and moving the throttle. I would love to see more pics of this area on tractors that are known to have this linkage set up correctly. Maybe if we see a lot the same way we can determine the proper initial set up. Thanks! Share this post Link to post Share on other sites
