RetroMower 350 #1 Posted September 11 Been a while since I posted here but I ran into an issue. Recently my daily mower that was a lil toro 8-32 bit the dust so rather than getting a replacement this late in the mowing season I just decided to put my c100 into service which I only ever used for knocking down high weeds or pulling a leaf sweeper. I rebuilt the motor and transmission in 2017 and I never had any trouble beyond needing to clean the points every spring. Today I was just about done with my 1 ½ acre yard and the engine began racing to the moon on the level and bogging terrible on gentle slopes. I was only able to finish mowing by barely giving it any throttle as the rpm kept increasing and was only controlled by the effort of mowing. As soon as I'd exit a run the rpm would skyrocket if I didn't throttle down completely. Share this post Link to post Share on other sites
pfrederi 21,215 #2 Posted September 11 Make sure the governor arm is not loose on the shaft you should adjust the governor per the manual. 4 Share this post Link to post Share on other sites
953 nut 69,724 #3 Posted September 11 Also, be sure the throttle cable clamp is keeping the cable jacket secured. 2 Share this post Link to post Share on other sites
