bradleydavidgood
Installing exhaust/muffler: Wheel Horse 414–8
bradleydavidgood
ri702bill
Nice to see that the support strap is in good condition - it is required!.
Do you have experience setting the governor arm position & throttle??
It is rather basic, but needs to be done properly...
bradleydavidgood
Thanks!
No, I don't have experience with that.  I made sure I put everything back together the way it was, and I was going to start it up and address the carb adjustments before getting into that, if that makes sense.  One thing at a time.
But yea, thanks for bringing it up.  I need to look that up sometime soon.
ri702bill
There Is a procedure to reinstall the lever correctly on the governor shaft that must be done - properly - prior to starting the engine. It is covered in the Kohler manual. This prevents over-revving the engine on startup... did you note the link position in the set of holes on the arm & carb? It is always best to take a couple of phone pictures any time there are multiple possible settings. again, the manual should have linkage diagrams...
bradleydavidgood
Yes I noted all the positions on video and used a paint pen on the shaft and connection of the thing on the exhaust side that I had to take off to install the exhaust.  I guess that's the governor shaft?
I then went thru my previous videos and took screenshots and had 6-8 print outs at the tractor while reinstalling.  So I'm certain everything is in its same position.  If you still think it needs this procedure I'll do it.
