cafoose 3,817 #1 Posted Tuesday at 03:06 AM (edited) Working on a 48 inch deck from the 1980s or 1990s. Blade pulley is pressed on, no key, just a round shaft. Not double d. Two holes on the pulley. I tapped the holes to 5/16 x 18 NC. I used a steering wheel puller and one of the bolts pulled through the 5/16 threads. The pulley didn't move. I put flat pry bars on both sides with pressure and hit the shaft with a BFH. Nothing moved How do I get the pulley off? The other two pulleys came off. The center one just pulled off by hand. The outer one by the chute came off with the tapped holes with the steering wheel puller. Also, how do you get the bearings out of the housings? I removed a snap ring on it already. Edited Tuesday at 03:06 AM by cafoose Share this post Link to post Share on other sites
JCM 11,395 #2 Posted Tuesday at 09:04 AM @peter lena Has a procedure that seems to work well. I just received 3 spindles myself from K & B. It's on the list for an update. Good luck 1 Share this post Link to post Share on other sites
oldlineman 1,800 #3 Posted Tuesday at 11:28 AM since you will replacing the seal and bearings maybe some heat on the pully hub will expand it enough, along with your favorite penetrating oil or wax. Bob 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,453 #4 Posted Tuesday at 12:10 PM The only deck I see that did not use a bolt or nut to secure the pulley is the very first 48" deck RM-483. The top retaining ring 936029 is 1-5/8" to hold the bearing in the spindle housing. The second retaining ring 936126 is 3/4" to hold the spindle in the bearing or is it to hold the pulley on? Share this post Link to post Share on other sites
953 nut 68,508 #5 Posted Tuesday at 12:36 PM Make four wooden wedges, place two on each side of the pulley and drive them evenly under both sides to apply upward pressure then use a piece of hardwood over the shaft and apply the BFH tool. 1 1 1 Share this post Link to post Share on other sites
cafoose 3,817 #6 Posted Tuesday at 01:38 PM (edited) 1 hour ago, gwest_ca said: did not use a bolt or nut to secure the pulley It does use a nut to secure the pulley, sorry I didn't mention that I removed the nut and lock washer first. Edited Tuesday at 01:43 PM by cafoose Share this post Link to post Share on other sites
JoeM 10,156 #7 Posted Tuesday at 01:39 PM 3 hours ago, 953 nut said: evenly under both sides to apply upward pressure Yes, you have to support the pulley, If you let the pulley hit the top bearing, you can actually drive the bottom snap rig through the groove and that will break the housing at the ring groove. Don't ask how i know! 2 Share this post Link to post Share on other sites
peter lena 10,014 #8 Posted Tuesday at 02:00 PM @cafoose regularly use WONDER BARS , for pulley removal , 90 degree rocker end , lets you easily , push / pull , OUTWARD , evenly lifting off pulleys https://www.walmart.com/ip/Stanley-Wonder-Bar/16913718?72Q6LiUaAo1eEALw_wcB , combine that with a related bearing lubrication upgrade , lucas , green chassis , no whyining noise or related failures , pete 1 Share this post Link to post Share on other sites
cafoose 3,817 #9 Posted Tuesday at 02:29 PM 28 minutes ago, peter lena said: regularly use WONDER BARS Tried that and it didn't work 1 Share this post Link to post Share on other sites
peter lena 10,014 #10 Posted Tuesday at 02:41 PM @cafoose sounds interesting , figuring pulley is toast , probably have a key way hang up / galling ? power band saw , cut into the hub / spindle area , vertically might relieve the grab , drive in a small flat chisel , upgraded all my spindle / pulley set ups years ago , for lubrication failures , no issues at all . pete 1 Share this post Link to post Share on other sites
cafoose 3,817 #11 Posted Tuesday at 02:44 PM 2 minutes ago, peter lena said: probably have a key way hang up No key, just press fit with lock washer. Share this post Link to post Share on other sites
peter lena 10,014 #12 Posted Tuesday at 03:03 PM @cafoose you have to cut into that bind fit , couple of band saw cuts on that sleeve , should get you going , pete 1 Share this post Link to post Share on other sites
Ed Kennell 46,985 #13 Posted Tuesday at 06:16 PM Is there room to slide a couple pieces of 1/4" flat stock onder the two holes in the pulley. Mark the hole then d&t for two long threaded rods. Screw them down tight against the deck as jack screws and add the puller bar across the shaft. Get max force on the rods and use your biggest BFH. 1 1 Share this post Link to post Share on other sites
cafoose 3,817 #14 Posted Tuesday at 09:01 PM Got it off Took my BFH and whacked it a few times after soaking it a few hours in Kroil and heat with a propane torch 3 5 Share this post Link to post Share on other sites
peter lena 10,014 #15 Posted Tuesday at 10:15 PM @cafoose kroil is king for creeping penetrant , also unfortunately expensive as hell, good to have that in an intended removal spot , like an axel hub set screw , days out , regular movement will show you a rusty , drip track , regular plan for me , pete 1 Share this post Link to post Share on other sites
Brockport Bill 2,455 #16 Posted Wednesday at 01:12 AM being persistant and smart still often isnt enough - - i have done all the techniques noted in this thread and still won't budge and have had to cut a few off - - the ones that are a nightmare are usually from a deck bought used that has been outdoors and those pulleys simply get rust welded on the shaft from being in the rain. Regarding removing the bearings........ the technique i use is a socket from my socket set - - the long ones in length, and a bit smaller diamater width than the bearing hole to fit into bearing center -- I simply slide the socket down into the spindle to place on top of tube --- and hit the socket with my hammer - - it drives the tube and pushes the bearing out -- once one is out then flip over spindle and do the other bearing 1 1 Share this post Link to post Share on other sites
cafoose 3,817 #17 Posted Wednesday at 01:38 AM Pulley was a bit bent but not bad. Used sockets and long rods to get bearings out. I got a deck from @sqrlgtr that had the bad bearings so I used the bearings from my rotted deck. Had extra pulleys and stuff anyway working with two decks to make one good one. Rebuilt the tip on my Hobart mig so going to try to patch two holes in the @sqrlgtr deck 2 Share this post Link to post Share on other sites
peter lena 10,014 #18 Posted Wednesday at 12:18 PM @cafoose did you clean out the related bearings , and refill with LUCAS XTRA HD GREEN CHASSIS GREASE ? years in usage , guess what ?, no bearing whine or any failures in any deck or related rotational pto spot . 550 deg rated , also polyurea rated , stays with it , what a concept , also did my pto cone needle bearing ? have never burned out a clutch disc , these repetitive problems are starring right at you . my decks are bearing issue free , for years , also do this , pete 1 Share this post Link to post Share on other sites
cafoose 3,817 #19 Posted Wednesday at 03:45 PM @peter lena Plan on oil soaking decks but don't have any lucas grease. Gonna grease up the bearings really good though. Share this post Link to post Share on other sites
peter lena 10,014 #20 Posted Wednesday at 04:18 PM @cafoose good for you , like wide bearing side grease s\shields, easily removed with flat pocket screwdriver or small flat putty knife , wipe out bearing first , then carb cleaner aerosol , for final flush , then lucas green , made for hi temp , brutal conditions , 550 deg rated , tractor areas , that I have improved on , have long been bombproof , that hot deck oil soaking , once done is very easily retained , also stand decks up against wall stud , over winter , with a touch up if needed , haven't had to do any related deck anything , you might try something easy / simple just to encourage your interest to change / improve . that pto lever start , washer fill up , lubricated , and heim jointed end , got me going , EVERY STAGE IN ANYTHING , CAN / SHOULD BE A SMOOTH EASY HAND OFF . you know what starts the plow squeeze lever , for very easy movement ? 3/8 SHOULDER BOLT , no thread area , ensures smooth swing start , washers dial it in , red grease , secure with elastic Lok nut , years in , bombproof , pete 1 Share this post Link to post Share on other sites
cafoose 3,817 #21 Posted 7 hours ago (edited) Doing an @peter lena oil soak in the hot sun and greased up the bearings. Edited 7 hours ago by cafoose 3 Share this post Link to post Share on other sites
peter lena 10,014 #22 Posted 6 hours ago @cafoose what did you use for oil , lubrication ? did you prop it up to the sun ? the more direct sun time the better . glad you are trying something , pete 1 Share this post Link to post Share on other sites
cafoose 3,817 #23 Posted 6 hours ago 5 minutes ago, peter lena said: @cafoose what did you use for oil , lubrication ? did you prop it up to the sun ? the more direct sun time the better . glad you are trying something , pete It's in the sun, I used some drain oil, regular grease in my grease gun on the bearings. 1 Share this post Link to post Share on other sites
peter lena 10,014 #24 Posted 3 hours ago @cafoose what are you using for grease in those bearings ? do any of the related pulleys , whine . with engagement ? the more hot sun deck time the better , prop mine right up to longest time of day , good to finish the season , with a final cleaning touch up and oil soak , then propped up to a wall stud with a screw in eye bolt , heavy extension spring , make up a big S hook shape from 1/4 " steel rod . , mine are 8- 10 inches long that will let you , very easily prop up and secure that deck , with bottom side out for regular inspection status , been doing this for many years now , with no problems at all , glad you are doing something , pete Share this post Link to post Share on other sites
