cafoose 3,802 #1 Posted 18 hours ago (edited) Working on a 48 inch deck from the 1980s or 1990s. Blade pulley is pressed on, no key, just a round shaft. Not double d. Two holes on the pulley. I tapped the holes to 5/16 x 18 NC. I used a steering wheel puller and one of the bolts pulled through the 5/16 threads. The pulley didn't move. I put flat pry bars on both sides with pressure and hit the shaft with a BFH. Nothing moved How do I get the pulley off? The other two pulleys came off. The center one just pulled off by hand. The outer one by the chute came off with the tapped holes with the steering wheel puller. Also, how do you get the bearings out of the housings? I removed a snap ring on it already. Edited 18 hours ago by cafoose Share this post Link to post Share on other sites
JCM 11,393 #2 Posted 12 hours ago @peter lena Has a procedure that seems to work well. I just received 3 spindles myself from K & B. It's on the list for an update. Good luck 1 Share this post Link to post Share on other sites
oldlineman 1,800 #3 Posted 10 hours ago since you will replacing the seal and bearings maybe some heat on the pully hub will expand it enough, along with your favorite penetrating oil or wax. Bob 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,446 #4 Posted 9 hours ago The only deck I see that did not use a bolt or nut to secure the pulley is the very first 48" deck RM-483. The top retaining ring 936029 is 1-5/8" to hold the bearing in the spindle housing. The second retaining ring 936126 is 3/4" to hold the spindle in the bearing or is it to hold the pulley on? Share this post Link to post Share on other sites
953 nut 68,419 #5 Posted 9 hours ago Make four wooden wedges, place two on each side of the pulley and drive them evenly under both sides to apply upward pressure then use a piece of hardwood over the shaft and apply the BFH tool. 1 1 Share this post Link to post Share on other sites
cafoose 3,802 #6 Posted 8 hours ago (edited) 1 hour ago, gwest_ca said: did not use a bolt or nut to secure the pulley It does use a nut to secure the pulley, sorry I didn't mention that I removed the nut and lock washer first. Edited 7 hours ago by cafoose Share this post Link to post Share on other sites
JoeM 10,139 #7 Posted 8 hours ago 3 hours ago, 953 nut said: evenly under both sides to apply upward pressure Yes, you have to support the pulley, If you let the pulley hit the top bearing, you can actually drive the bottom snap rig through the groove and that will break the housing at the ring groove. Don't ask how i know! 1 Share this post Link to post Share on other sites
peter lena 10,007 #8 Posted 7 hours ago @cafoose regularly use WONDER BARS , for pulley removal , 90 degree rocker end , lets you easily , push / pull , OUTWARD , evenly lifting off pulleys https://www.walmart.com/ip/Stanley-Wonder-Bar/16913718?72Q6LiUaAo1eEALw_wcB , combine that with a related bearing lubrication upgrade , lucas , green chassis , no whyining noise or related failures , pete 1 Share this post Link to post Share on other sites
cafoose 3,802 #9 Posted 7 hours ago 28 minutes ago, peter lena said: regularly use WONDER BARS Tried that and it didn't work 1 Share this post Link to post Share on other sites
peter lena 10,007 #10 Posted 7 hours ago @cafoose sounds interesting , figuring pulley is toast , probably have a key way hang up / galling ? power band saw , cut into the hub / spindle area , vertically might relieve the grab , drive in a small flat chisel , upgraded all my spindle / pulley set ups years ago , for lubrication failures , no issues at all . pete 1 Share this post Link to post Share on other sites
cafoose 3,802 #11 Posted 6 hours ago 2 minutes ago, peter lena said: probably have a key way hang up No key, just press fit with lock washer. Share this post Link to post Share on other sites
peter lena 10,007 #12 Posted 6 hours ago @cafoose you have to cut into that bind fit , couple of band saw cuts on that sleeve , should get you going , pete 1 Share this post Link to post Share on other sites
Ed Kennell 46,939 #13 Posted 3 hours ago Is there room to slide a couple pieces of 1/4" flat stock onder the two holes in the pulley. Mark the hole then d&t for two long threaded rods. Screw them down tight against the deck as jack screws and add the puller bar across the shaft. Get max force on the rods and use your biggest BFH. 1 Share this post Link to post Share on other sites
cafoose 3,802 #14 Posted 41 minutes ago Got it off Took my BFH and whacked it a few times after soaking it a few hours in Kroil and heat with a propane torch 2 Share this post Link to post Share on other sites
