cafoose
Stuck pulley on 48 inch deck
cafoose
Working on a 48 inch deck from the 1980s or 1990s. Blade pulley is pressed on, no key, just a round shaft. Not double d. Two holes on the pulley. I tapped the holes to 5/16 x 18 NC. I used a steering wheel puller and one of the bolts pulled through the 5/16 threads. The pulley didn't move. I put flat pry bars on both sides with pressure and hit the shaft with a BFH. Nothing moved How do I get the pulley off? The other two pulleys came off. The center one just pulled off by hand. The outer one by the chute came off with the tapped holes with the steering wheel puller. Also, how do you get the bearings out of the housings? I removed a snap ring on it already.
Edited by cafoose
JCM
@peter lena    Has a procedure that seems to work well. I just received 3 spindles myself from K & B. It's on the list for an update. Good luck
oldlineman
since you will replacing the seal and bearings maybe some heat on the pully hub will expand it enough, along with your favorite penetrating oil or wax. Bob
gwest_ca
The only deck I see that did not use a bolt or nut to secure the pulley is the very first 48" deck RM-483.
The top retaining ring 936029 is 1-5/8" to hold the bearing in the spindle housing.
The second retaining ring 936126 is 3/4" to hold the spindle in the bearing or is it to hold the pulley on?
953 nut
Make four wooden wedges, place two on each side of the pulley and drive them evenly under both sides to apply upward pressure then use a piece of hardwood over the shaft and apply the BFH tool.
cafoose
It does use a nut to secure the pulley, sorry I didn't mention that I removed the nut and lock washer first.
Edited by cafoose
JoeM
Yes, you have to support the pulley, If you let the pulley hit the top bearing, you can actually drive the bottom snap rig through the groove and that will break the housing at the ring groove. Don't ask how i know!
peter lena
@cafoose  regularly  use  WONDER BARS  , for  pulley removal , 90 degree  rocker end , lets you  easily , push / pull , OUTWARD  , evenly  lifting off  pulleys https://www.walmart.com/ip/Stanley-Wonder-Bar/16913718?72Q6LiUaAo1eEALw_wcB , combine that with a related bearing  lubrication  upgrade , lucas , green chassis  , no  whyining noise or related failures , pete
cafoose
Tried that and it didn't work :(
  • Sad 1
peter lena
@cafoose  sounds interesting , figuring  pulley is  toast  , probably have a key way hang up / galling ? power band saw , cut into the hub /  spindle area , vertically  might relieve the  grab , drive in a small  flat chisel , upgraded all my  spindle / pulley set ups years ago , for lubrication failures , no issues at all . pete
cafoose
No key, just press fit with lock washer.
