ineedanother 2,803 #26 Posted yesterday at 01:16 AM 15 hours ago, bradleydavidgood said: I'm not hearing anyone say that they needed to open the plugs to solve their carb issue. I always do. All of the disassembly and time already invested...why not? Those drillings are critical and have to be clean. Not saying that it has to be done but I just don't want to have to go back and do it all again. I just tap a good awl in and pry them out. I've never drilled them but some original plugs are thick. Share this post Link to post Share on other sites
bradleydavidgood 38 #27 Posted yesterday at 09:36 AM 8 hours ago, ineedanother said: I always do. All of the disassembly and time already invested...why not? Those drillings are critical and have to be clean. Not saying that it has to be done but I just don't want to have to go back and do it all again. I just tap a good awl in and pry them out. I've never drilled them but some original plugs are thick. Thanks for your input! I already did it. 1 Share this post Link to post Share on other sites
bradleydavidgood 38 #28 Posted yesterday at 09:55 AM Governor-arm adjustment Must be done - properly - prior to starting the engine. This prevents over-revving the engine on startup. Thank you to ri702bill for pointing this out in another thread. Share this post Link to post Share on other sites
bradleydavidgood 38 #29 Posted yesterday at 10:02 AM Throttle cable sheath position in the clamp Determines throttle lever action for full throttle & max rpm. Thank you to ri702bill for pointing this out in another thread. I do not see a procedure in the service manual for this. Share this post Link to post Share on other sites
bradleydavidgood 38 #30 Posted 7 hours ago I am looking for videos of how to adjust the governor and throttle sheath position on the clamp. I think before we identified my engine as the M14S-601540. It says Kohler Magnum 14 but the ID plate is not readable. What general line does that fall into for searching purposes? Is it like the K Series as far as these things go? Thanks! Share this post Link to post Share on other sites
