bradleydavidgood
Rebuild carb Magnum Kohler 14 Wheel Horse 414–8
ineedanother
15 hours ago, bradleydavidgood said:
I'm not hearing anyone say that they needed to open the plugs to solve their carb issue.
I always do. All of the disassembly and time already invested...why not? Those drillings are critical and have to be clean. Not saying that it has to be done but I just don't want to have to go back and do it all again. I just tap a good awl in and pry them out. I've never drilled them but some original plugs are thick.
bradleydavidgood
Thanks for your input!  I already did it.
bradleydavidgood
Governor-arm adjustment
Must be done - properly - prior to starting the engine. This prevents over-revving the engine on startup.  Thank you to ri702bill for pointing this out in another thread.
bradleydavidgood
Throttle cable sheath position in the clamp
Determines throttle lever action for full throttle & max rpm.
I do not see a procedure in the service manual for this.
