bradleydavidgood 31 #1 Posted yesterday at 01:28 AM (edited) Documenting the carb rebuild: Edited yesterday at 01:29 AM by bradleydavidgood Share this post Link to post Share on other sites
bradleydavidgood 31 #2 Posted yesterday at 01:29 AM https://youtube.com/shorts/1txHhDb37-0?si=2KYvXb-Tli_g0D9K Share this post Link to post Share on other sites
bradleydavidgood 31 #3 Posted yesterday at 01:32 AM https://youtube.com/shorts/-naV6L0UDGw?si=WVhngGZdXBrj9-8K Share this post Link to post Share on other sites
bradleydavidgood 31 #4 Posted yesterday at 01:35 AM https://youtube.com/shorts/HPdzENHqmwk?si=ZHiSmjqhj1mCWbrd Share this post Link to post Share on other sites
bradleydavidgood 31 #5 Posted yesterday at 01:38 AM https://youtube.com/shorts/B5bUHWaRIwY?si=XHdl5JQcW7QChDJB Share this post Link to post Share on other sites
bradleydavidgood 31 #6 Posted yesterday at 01:42 AM Do you think I need to remove these plugs and clean in there more? And if so, how do you remove them and reinstall the new ones? Thanks! https://youtube.com/shorts/pdnbI8F5Y1w?si=gKAmXrNJJqzEyqVq Share this post Link to post Share on other sites
pfrederi 21,043 #7 Posted 16 hours ago I don't unless the carb still has issues after a couple cleanings 1 Share this post Link to post Share on other sites
bradleydavidgood 31 #8 Posted 15 hours ago 31 minutes ago, pfrederi said: I don't unless the carb still has issues after a couple cleanings Thank you! Anyone else have an opinion about those? I'm most concerned with how easily the new ones go back in. Would hate to get them out and not be able to get the new ones in, or they don't seal properly. Anyone have experience with that? Thanks! Share this post Link to post Share on other sites
ebinmaine 80,253 #9 Posted 5 hours ago 9 hours ago, bradleydavidgood said: Thank you! Anyone else have an opinion about those? I'm most concerned with how easily the new ones go back in. Would hate to get them out and not be able to get the new ones in, or they don't seal properly. Anyone have experience with that? Thanks! 10 hours ago, pfrederi said: I don't unless the carb still has issues after a couple cleanings Seconded. 1 Share this post Link to post Share on other sites
lynnmor 9,004 #10 Posted 4 hours ago 21 hours ago, bradleydavidgood said: Do you think I need to remove these plugs and clean in there more? And if so, how do you remove them and reinstall the new ones? Thanks! https://youtube.com/shorts/pdnbI8F5Y1w?si=gKAmXrNJJqzEyqVq There are a number of YouTube videos showing the process. I watched a couple and would add a few points. Use a drill press with a down stop to prevent going too deep, it is easy to suddenly go too far with a hand drill. I use a very small amount of fuel resistant sealer on the edge, it acts as a lubricant and helps seal. Do not hammer in too far, it will begin to come loose when you go beyond flat. 2 Share this post Link to post Share on other sites
