WHX?? 58,339 #1 Posted September 6 (edited) This may be better posted in other brands since I an working on a customer's Ariens GT-20. if so mods can move it. Magnum 20 in this one and a rat's mess of the wiring. Haven't really got into it yet but wiring diagrams show this relay in the magneto ground to kill circuit. It's not listed in the parts manual either with no part id number. . I have no idea what's it for but when I get into the re-wiring it's probably gonna go if it is there. Same with all the safety switches they been hacked up so bad. Should be just a common magneto ground to kill through the switch right? I will put this in other brands you guys may want more pics. Did I mention the wiring? It's really bad. Edited September 7 by WHX?? 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,524 #2 Posted September 6 The kill relay is necessary because the ignition switch has an "I" terminal intended for battery style ignition. The M-Series have magneto ignition so the battery style of ignition switch is necessary to control the magneto ignition by the use of a relay. Wheel Horse/Toro also use this configuation. The relay illustration is poor. When the relay coil is energized the relay contacts are open. When the relay coil is not energized the ignition wire is grounded. 6 1 Share this post Link to post Share on other sites
WHX?? 58,339 #3 Posted September 7 (edited) 17 minutes ago, gwest_ca said: "I" terminal intended for battery style ignition. I might have added this is not the original motor but it appears the original motor was magneto too per the wiring diagram. The switch is probably not original either then the way this wiring was hacked on. Note that the I term on the switch has two fuses running right from the battery. Switch will most definitely replaced with one we use on horses for magnetos. Right now the kill switch is a hacked on grounding toggle switch. Edited September 7 by WHX?? 1 Share this post Link to post Share on other sites
ri702bill 13,281 #4 Posted September 7 Is it possible to change the ignition switch to the magneto style & loose the relay and its related wiring?? 1 Share this post Link to post Share on other sites
WHX?? 58,339 #5 Posted September 7 16 minutes ago, ri702bill said: change the ignition switch to the magneto style & loose the relay and its related wiring?? 41 minutes ago, WHX?? said: when I get into the re-wiring it's probably gonna go 17 minutes ago, WHX?? said: Switch will most definitely replaced with one we use on horses for magnetos. 3 Share this post Link to post Share on other sites
wallfish 20,725 #6 Posted September 7 1 hour ago, WHX?? said: since I an working on a customer's Ariens GT-20. Since when did you come out of retirement and start a small engine business? 5 Share this post Link to post Share on other sites
WHX?? 58,339 #7 Posted September 7 1 minute ago, wallfish said: start a small engine business? Since the neighbor has got good booze among other adult partakings ... 2 5 Share this post Link to post Share on other sites
wallfish 20,725 #8 Posted September 7 3 minutes ago, WHX?? said: Since the neighbor has got good booze among other adult partakings ... 1 Share this post Link to post Share on other sites
c-series don 12,622 #9 Posted September 7 Another classic line from @WHX?? !! 1 6 Share this post Link to post Share on other sites
JoeM 10,317 #10 Posted September 7 Have to admit until the 80's, WH wiring was pretty simple. 1 Share this post Link to post Share on other sites
squonk 48,295 #11 Posted September 7 9 hours ago, WHX?? said: Since the neighbor has got good booze among other adult partakings ... Translation: He's got cheap wine and still thinks it's the 60's! 3 Share this post Link to post Share on other sites
Bill D 3,179 #12 Posted September 7 (edited) Personally, any time I rewire a tractor I like to wire it for a powered ignition. This give the most options for engine swaps. Adding a kill relay in place of a coil is very easy. Also, if a newer motor is installed power may need to be supplied to the solenoid on the carb. This can be done from the ignition wire that powers kill relay. I can keep just one 103990 ignition switch in stock this way. I based my harness builds off an early 80's C-165 that I fixed for another member. Very basic wiring with what I consider the essential safety switches. Edited September 7 by Bill D 4 Share this post Link to post Share on other sites
953 nut 70,130 #13 Posted September 7 Converting from battery ignition to magneto is very straight forward but going from magneto to battery ignition and having the safety switches work is much more involved. I'm sure you have seen this before but here it is again. 2 1 Share this post Link to post Share on other sites
