702854boy 1,103 #1 Posted Sunday at 07:17 PM Is type F ATF safe to use in an 875 since type A is pretty much obsolete anymore? Share this post Link to post Share on other sites
adsm08 5,006 #2 Posted Sunday at 07:43 PM Type A, Type F, and the generic Dex/Merc are all pretty interchangeable these days. 7 Share this post Link to post Share on other sites
squonk 47,887 #3 Posted Sunday at 07:57 PM Fill it with Dex/Merc and run it! 2 1 Share this post Link to post Share on other sites
702854boy 1,103 #4 Posted Sunday at 10:33 PM What is the proper length for the lipstick on these? Mine is 7 inches and the fluid is just barely on the stick after putting 4 quarts of atf in 1 Share this post Link to post Share on other sites
adsm08 5,006 #5 Posted Sunday at 10:39 PM 5 minutes ago, 702854boy said: What is the proper length for the lipstick on these? I'm not very experienced with cosmetics, but I believe the average lipstick is around 2.5 to 3 inches in length. 3 Share this post Link to post Share on other sites
702854boy 1,103 #6 Posted Sunday at 10:52 PM 12 minutes ago, adsm08 said: I'm not very experienced with cosmetics, but I believe the average lipstick is around 2.5 to 3 inches in length. Darn autocorrect, sometimes it does what you want and others it does this. Anyways what's the right dipstick length 3 Share this post Link to post Share on other sites
adsm08 5,006 #7 Posted Sunday at 10:56 PM 1 minute ago, 702854boy said: Darn autocorrect, sometimes it does what you want and others it does this. I get it. Last night I was discussing a pop noise that my new car radio makes when you turn the key on, with my sister, and she thought it might be the amp getting an inrush spike. I said I only had three wires hooked to it from the head unit, and my phone changed "three wires hooked" to "three wife's holes". 5 Share this post Link to post Share on other sites
pfrederi 21,049 #8 Posted Monday at 01:43 AM not sure about dipstick length but fill it so there is an inch or so left under the top of the tranny housing. for expansion... 1 Share this post Link to post Share on other sites
squonk 47,887 #9 Posted Monday at 05:12 PM (edited) @702854boy Wheel a Matic dip stick length is 7" Edited Monday at 05:13 PM by squonk 3 Share this post Link to post Share on other sites
702854boy 1,103 #10 Posted Monday at 05:32 PM So I need to add more fluid even though the manual said 4 quarts? Share this post Link to post Share on other sites
squonk 47,887 #11 Posted Monday at 05:45 PM Clean ATF is hard to see on the stick. I think @Achto paints his sticks white. I usually take a Q tip and starting above the full mark, dab the stick until I see fluid on the tip 1 Share this post Link to post Share on other sites
702854boy 1,103 #12 Posted Monday at 05:50 PM I had laid the stick on its side one a clean paper towel and nothing was on the rag 1 Share this post Link to post Share on other sites
squonk 47,887 #13 Posted Monday at 07:35 PM 1 hour ago, 702854boy said: I had laid the stick on its side one a clean paper towel and nothing was on the rag If you stick is the correct length Add a little at a time until it shows full 2 Share this post Link to post Share on other sites
Achto 32,347 #14 Posted Tuesday at 12:18 AM 6 hours ago, squonk said: I think @Achto paints his sticks white. The best fix that I've found it to sandblast the lower portion of the dip stick. This makes them much easier to read. 1 2 Share this post Link to post Share on other sites
adsm08 5,006 #15 Posted Tuesday at 12:29 AM 6 hours ago, 702854boy said: So I need to add more fluid even though the manual said 4 quarts? I thought I had read they could use up to 5, depending on how low they got. Share this post Link to post Share on other sites
702854boy 1,103 #16 Posted Tuesday at 12:32 AM 2 minutes ago, adsm08 said: I thought I had read they could use up to 5, depending on how low they got. I hadn't read that part yet. Might be what I need to do since I completely emptied the system to change the fluid 1 Share this post Link to post Share on other sites
WHX?? 57,804 #17 Posted Tuesday at 12:34 AM Lip stick on the dip ... never mind Howard I'll clue you in 30 years... or shortly after you get your DL ... which ever comes first. Guessing you changed the filter too that will add a bit but yes some times new fluid can be tough to read. Dan's trick sandblasting trick works but with fresh clean oil can still be abit sketchy. 875 is a bucket lister for many of us (Squonky doesn't deserve one) and I must have missed your thread with all the I got blind out house lucky and scored this one for chump change. 4 Share this post Link to post Share on other sites
702854boy 1,103 #18 Posted Tuesday at 12:36 AM I guess tomorrow when I get a chance I need to upload some photos that I've taken since I've gotten the tractor 2 Share this post Link to post Share on other sites
WHX?? 57,804 #19 Posted Tuesday at 12:40 AM 3 minutes ago, 702854boy said: I guess tomorrow when I get a chance I need to upload some photos that I've taken since I've gotten the tractor That would be a REAL good idea ... 1 Share this post Link to post Share on other sites
squonk 47,887 #20 Posted Tuesday at 10:51 AM (edited) 10 hours ago, WHX?? said: (Squonky doesn't deserve one) What you talkin about Willis? I rescued this 875. Installed the lift arm, replaced the worn out engine, fixed the tranny leak, fixed the broken frame, made the fan screen, installed Town and Country's and front knobbies, painted the wheels and added the comfy but patched seat and springs. Edited Tuesday at 10:53 AM by squonk 5 Share this post Link to post Share on other sites
702854boy 1,103 #21 Posted Tuesday at 05:57 PM These are the photos I have so far, I need to get another one later of how it looks after sos pad wash and marvel mystery oil rub down and sun soak This photo is how it looked the day i brough it home. This photo is how it looked after scrubbing with the sos pad while it was still damp from the water And the video is from the first time I drove it after getting it rewired and running and washed 20260904_193920.mp4 1 3 1 Share this post Link to post Share on other sites
WHX?? 57,804 #22 Posted Tuesday at 10:05 PM Nice looks to be all orginal. What's with the genny light staying on? Share this post Link to post Share on other sites
702854boy 1,103 #23 Posted Tuesday at 10:08 PM 1 minute ago, WHX?? said: What's with the genny light staying on? I had wired it up to the s and i terminal on the switch but with having a solenoid i needed to go to the solenoid instead of the switch. It was just a simple wiring mistake, charges at 13-14 volts and after I wired it correctly the light operates as it should 2 1 Share this post Link to post Share on other sites
702854boy 1,103 #24 Posted 6 hours ago (edited) Is everything put together right in here? The springs are in spring bind and if I go out any further they'll rub on the motion mechanism. I'm wanting to fix this before my new cam plate comes in/gets installed Edited 2 hours ago by 702854boy Share this post Link to post Share on other sites
adsm08 5,006 #25 Posted 3 hours ago 3 hours ago, 702854boy said: Is everything put together right in here? The springs are in spring bind and if I go out any further they'll rub on the motion mechanism. I'm wanting to fix this before my new cam plate comes in/gets installed Pictures? Share this post Link to post Share on other sites
