702854boy
Wheel A Matic Fluid
702854boy
Is type F ATF safe to use in an 875 since type A is pretty much obsolete anymore?
adsm08
Type A, Type F, and the generic Dex/Merc are all pretty interchangeable these days.
  • Like 7
squonk
Fill it with Dex/Merc and run it!
702854boy
What is the proper length for the lipstick on these? Mine is 7 inches and the fluid is just barely on the stick after putting 4 quarts of atf in
  • Haha 1
adsm08
I'm not very experienced with cosmetics, but I believe the average lipstick is around 2.5 to 3 inches in length.
  • Haha 3
702854boy
Darn autocorrect, sometimes it does what you want and others it does this. Anyways what's the right dipstick length
  • Haha 3
adsm08
I get it. Last night I was discussing a pop noise that my new car radio makes when you turn the key on, with my sister, and she thought it might be the amp getting an inrush spike. I said I only had three wires hooked to it from the head unit, and my phone changed "three wires hooked" to "three wife's holes".
  • Haha 5
pfrederi
not sure about dipstick length but  fill it so there is an inch or so left under the top of the tranny housing.  for expansion...
squonk
@702854boy Wheel a Matic dip stick length is 7"
Edited by squonk
  • Excellent 3
702854boy
So I need to add more fluid even though the manual said 4 quarts?
squonk
Clean ATF is hard to see on the stick. I think @Achto paints his sticks white.
I usually take a Q tip and starting above the full mark, dab the stick until I see fluid on the tip
702854boy
I had laid the stick on its side one a clean paper towel and nothing was on the rag
squonk
 If you stick is the correct length Add a little at a time until it shows full
Achto
The best fix that I've found it to sandblast the lower portion of the dip stick. This makes them much easier to read.
  • Excellent 2
adsm08
I thought I had read they could use up to 5, depending on how low they got.
702854boy
I hadn't read that part yet. Might be what I need to do since I completely emptied the system to change the fluid
WHX??
Lip stick on the dip ... never mind Howard I'll clue you in 30 years... or shortly after you get your DL ... which ever comes first. :lol:
Guessing you changed the filter too that will add a bit but yes some times new fluid can be tough to read. Dan's trick sandblasting trick works but with fresh clean oil can still be abit sketchy.
875 is a bucket lister for many of us (Squonky doesn't deserve one) and I must have missed your thread with all the :text-coolphotos:
I got blind out house lucky and scored this one for chump change.
  • Like 4
702854boy
I guess tomorrow when I get a chance I need to upload some photos that I've taken since I've gotten the tractor
WHX??
That would be a REAL good idea ... :ychain:
  • Haha 1
squonk
What you talkin about Willis?
I rescued this 875. Installed the lift arm, replaced the worn out engine, fixed the tranny leak, fixed the broken frame, made the fan screen, installed Town and Country's and   front knobbies, painted the wheels and added the comfy but patched seat and springs.
Edited by squonk
  • Excellent 4
702854boy
These are the photos I have so far, I need to get another one later of how it looks after sos pad wash and marvel mystery oil rub down and sun soak
This photo is how it looked the day i brough it home.a04531a2-5a7b-4982-b5b3-c1fd8229a277.jpg.d3aa5574e1de3488aa8007463c00e7bf.jpg
This photo is how it looked after scrubbing with the sos pad while it was still damp from the water20260904_194035.jpg.f91219c2bbb01d2e4958ae2a0d435183.jpg
And the video is from the first time I drove it after getting it rewired and running and washed
  • Excellent 3
WHX??
Nice :thumbs2: looks to be all orginal.
What's with the genny light staying on?
702854boy
I had wired it up to the s and i terminal on the switch but with having a solenoid i needed to go to the solenoid instead of the switch. It was just a simple wiring mistake, charges at 13-14 volts and after I wired it correctly the light operates as it should
  • Excellent 2
