702854boy 1,086 #1 Posted 23 hours ago Is type F ATF safe to use in an 875 since type A is pretty much obsolete anymore? Share this post Link to post Share on other sites
adsm08 4,988 #2 Posted 22 hours ago Type A, Type F, and the generic Dex/Merc are all pretty interchangeable these days. 5 Share this post Link to post Share on other sites
squonk 47,859 #3 Posted 22 hours ago Fill it with Dex/Merc and run it! 1 Share this post Link to post Share on other sites
702854boy 1,086 #4 Posted 19 hours ago What is the proper length for the lipstick on these? Mine is 7 inches and the fluid is just barely on the stick after putting 4 quarts of atf in Share this post Link to post Share on other sites
adsm08 4,988 #5 Posted 19 hours ago 5 minutes ago, 702854boy said: What is the proper length for the lipstick on these? I'm not very experienced with cosmetics, but I believe the average lipstick is around 2.5 to 3 inches in length. 2 Share this post Link to post Share on other sites
702854boy 1,086 #6 Posted 19 hours ago 12 minutes ago, adsm08 said: I'm not very experienced with cosmetics, but I believe the average lipstick is around 2.5 to 3 inches in length. Darn autocorrect, sometimes it does what you want and others it does this. Anyways what's the right dipstick length 1 Share this post Link to post Share on other sites
adsm08 4,988 #7 Posted 19 hours ago 1 minute ago, 702854boy said: Darn autocorrect, sometimes it does what you want and others it does this. I get it. Last night I was discussing a pop noise that my new car radio makes when you turn the key on, with my sister, and she thought it might be the amp getting an inrush spike. I said I only had three wires hooked to it from the head unit, and my phone changed "three wires hooked" to "three wife's holes". 2 Share this post Link to post Share on other sites
pfrederi 21,026 #8 Posted 16 hours ago not sure about dipstick length but fill it so there is an inch or so left under the top of the tranny housing. for expansion... 1 Share this post Link to post Share on other sites
squonk 47,859 #9 Posted 1 hour ago (edited) @702854boy Wheel a Matic dip stick length is 7" Edited 1 hour ago by squonk Share this post Link to post Share on other sites
702854boy 1,086 #10 Posted 59 minutes ago So I need to add more fluid even though the manual said 4 quarts? Share this post Link to post Share on other sites
squonk 47,859 #11 Posted 46 minutes ago Clean ATF is hard to see on the stick. I think @Achto paints his sticks white. I usually take a Q tip and starting above the full mark, dab the stick until I see fluid on the tip Share this post Link to post Share on other sites
702854boy 1,086 #12 Posted 41 minutes ago I had laid the stick on its side one a clean paper towel and nothing was on the rag Share this post Link to post Share on other sites
