pfrederi 21,222 #1 Posted September 5 Have a few maple trees I grew from seed in 1 gallon pots sitting in the garden decided to plant some. 35 minutes later I got one hole. Note the rock pile that came from the hole. I always get chuckle when I see your pictures of big gardens you rototilled no stones and the plow day pictures let alone a double bottom plow for a WH 2 4 Share this post Link to post Share on other sites
adsm08 5,195 #2 Posted September 5 5 minutes ago, pfrederi said: Have a few maple trees I grew from seed in 1 gallon pots sitting in the garden decided to plant some. 35 minutes later I got one hole. Note the rock pile that came from the hole. I always get chuckle when I see your pictures of big gardens you rototilled no stones and the plow day pictures let alone a double bottom plow for a WH The whole eastern half of the state is that way Paul. My house in Northumberland had all sorts of rocks growing out of the ground, and this place, when they dug the footer for the garage, we hauled out a few loads of stone just like the ones you dug up. 4 Share this post Link to post Share on other sites
ebinmaine 80,930 #3 Posted September 5 Our property is exceptionally rocky even for New England. At least you can dig a hole 🕳 3 Share this post Link to post Share on other sites
CCW 1,519 #4 Posted September 5 Where as I can did a 48 inch hole for a footing and not hit a single stone. 2 1 1 Share this post Link to post Share on other sites
JimSraj 585 #5 Posted September 5 Mostly open shale here in Northampton County PA. Not a picnic digging in it either. 2 Share this post Link to post Share on other sites
Handy Don 17,560 #6 Posted September 5 I’ve come to learn that there are no “natural” parts of our 0.6 acre property. Most of it was the formal gardens for a large estate that had been heavily landscaped. At one point i tried to dig up a section of lawn for a rasberry patch and found what must have been a low spot in the original surface that had been filled in with stones and covered with 6” of soil. I still don’t know how deep the stones go! 2 Share this post Link to post Share on other sites
953 nut 69,810 #7 Posted September 5 If I want a large rock all I need do is buy a plant in that size pot and ask my wife where it should be planted. Guaranteed there will be a rock about the size of that pot. 10 Share this post Link to post Share on other sites
oliver2-44 11,782 #8 Posted September 5 (edited) https://en.wikipedia.org/wiki/Granite_Mountain_(Texas) My yard is a mixture of decomposed which is granite gravel/sand/clay. I'm lucky there are just a few granite bolding balls randomly in it. Some short distance under it is solid red granite. A few houses over - slightly down hill their back yard has a lot of exposed solid granite. This picture is the "backside of Granite Mountain where they have been quarrying granite (from the front side ) since the Texas Capitol was built in 1882. One you get a way from the granite the Texas Hill Country is thin soil with limestone . They have been hauling thousands of truck loads of roughly 3x3x3 chunks down to the coast for several Harbor breakwater projects at Galveston, Matagorda and Corpus Christi. Each semi- truck carries 3-4 chunks. There are several quarries in about a 20 mile area that each have a different shade of rock from light pink to dark red. Back in the 70's and again in the 2010's An oil drill bit manufacture set up a drill rig and tested various experimental drill bits. Rumor has it they went down over 10,000 feet of solid granite and never ran out of it. Edited September 5 by oliver2-44 6 Share this post Link to post Share on other sites
Wayne0 1,648 #9 Posted September 6 In this neck of the woods it's like trying to dig in a barrel of bowling balls! 1 3 Share this post Link to post Share on other sites
ebinmaine 80,930 #10 Posted September 6 Some o' you would het a kick outta this video. Some have seen it. The boulders in the wall are all from the base ground level. Notice that the front of the wall is about 3 feet tall and the rear is over 7. There's over 800 cubic yards of fill above the original ground level. 2 Share this post Link to post Share on other sites
adsm08 5,195 #11 Posted September 6 21 hours ago, Handy Don said: I’ve come to learn that there are no “natural” parts of our 0.6 acre property. Most of it was the formal gardens for a large estate that had been heavily landscaped. At one point i tried to dig up a section of lawn for a rasberry patch and found what must have been a low spot in the original surface that had been filled in with stones and covered with 6” of soil. I still don’t know how deep the stones go! My yard is similar. The Dillsburg Brick Co. operated on and off for roughly a century. A house about 1/8 mile up from me was the main office. A 1/2 mile in the other direction is the quarry where they got the clay, on the ground of Camp Tuckahoe. Best I can figure from the maps I have my yard was in the brick drying yard. 4 Share this post Link to post Share on other sites
Beap52 2,516 #12 Posted September 7 I live in south Missouri and sympathize with guys dealing with rocks. Not much need of just packing a shovel to dig a hole, need a rock bar to go with it. Our farm in north Missouri where the power line is passing through is another story. The machine in the video below is boring a 6' to 8' wide by 33' deep hole that will hold 66 yards of concrete. Never found a rock. They bored 5 holes--no rocks but in one place 4' of black dirt. In another hole, my brother text me, that it started with black dirt, then red dirt then back to black dirt again. Two miles away where the power plant is going in, they hit 13 feet thick rock twenty feet below the surface. The only rocks we have to deal with on the farm are what I call "store-bought rocks". When they put a oil line through the farm a few years ago they hauled in ~6" rocks and every spring we get to pick a wheel barrow full of them up that end up on the surface. 20260513_082543_2046688a-9618-4802-b97b-0ea296230eaa.mp4 5 Share this post Link to post Share on other sites
ebinmaine 80,930 #13 Posted September 7 9 hours ago, Beap52 said: The machine in the video below is Very cool!! Never seen the like. 1 Share this post Link to post Share on other sites
953 nut 69,810 #14 Posted September 7 When our well was being drilled the first 50 feet was red clay, the next 200 feet was granite. Being at the end of a valley with mountains on three sides the sound echoed for miles. We apologized to everyone on the road, most of them were folks who had also had deed wells drilled and understood it had to be done. On the bright side the amount of clay soil confirmed the geological survey indicating this is not a site prone to landslides. 3 Share this post Link to post Share on other sites
