pfrederi 21,018 #1 Posted 5 hours ago Have a few maple trees I grew from seed in 1 gallon pots sitting in the garden decided to plant some. 35 minutes later I got one hole. Note the rock pile that came from the hole. I always get chuckle when I see your pictures of big gardens you rototilled no stones and the plow day pictures let alone a double bottom plow for a WH 2 3 Share this post Link to post Share on other sites
adsm08 4,960 #2 Posted 5 hours ago 5 minutes ago, pfrederi said: Have a few maple trees I grew from seed in 1 gallon pots sitting in the garden decided to plant some. 35 minutes later I got one hole. Note the rock pile that came from the hole. I always get chuckle when I see your pictures of big gardens you rototilled no stones and the plow day pictures let alone a double bottom plow for a WH The whole eastern half of the state is that way Paul. My house in Northumberland had all sorts of rocks growing out of the ground, and this place, when they dug the footer for the garage, we hauled out a few loads of stone just like the ones you dug up. 4 Share this post Link to post Share on other sites
ebinmaine 80,193 #3 Posted 4 hours ago Our property is exceptionally rocky even for New England. At least you can dig a hole 🕳 2 Share this post Link to post Share on other sites
CCW 1,518 #4 Posted 3 hours ago Where as I can did a 48 inch hole for a footing and not hit a single stone. 1 1 1 Share this post Link to post Share on other sites
JimSraj 585 #5 Posted 3 hours ago Mostly open shale here in Northampton County PA. Not a picnic digging in it either. 2 Share this post Link to post Share on other sites
Handy Don 17,265 #6 Posted 2 hours ago I’ve come to learn that there are no “natural” parts of our 0.6 acre property. Most of it was the formal gardens for a large estate that had been heavily landscaped. At one point i tried to dig up a section of lawn for a rasberry patch and found what must have been a low spot in the original surface that had been filled in with stones and covered with 6” of soil. I still don’t know how deep the stones go! 2 Share this post Link to post Share on other sites
953 nut 68,363 #7 Posted 2 hours ago If I want a large rock all I need do is buy a plant in that size pot and ask my wife where it should be planted. Guaranteed there will be a rock about the size of that pot. 5 Share this post Link to post Share on other sites
oliver2-44 11,675 #8 Posted 1 hour ago (edited) https://en.wikipedia.org/wiki/Granite_Mountain_(Texas) My yard is a mixture of decomposed which is granite gravel/sand/clay. I'm lucky there are just a few granite bolding balls randomly in it. Some short distance under it is solid red granite. A few houses over - slightly down hill their back yard has a lot of exposed solid granite. This picture is the "backside of Granite Mountain where they have been quarrying granite (from the front side ) since the Texas Capitol was built in 1882. One you get a way from the granite the Texas Hill Country is thin soil with limestone . They have been hauling thousands of truck loads of roughly 3x3x3 chunks down to the coast for several Harbor breakwater projects at Galveston, Matagorda and Corpus Christi. Each semi- truck carries 3-4 chunks. There are several quarries in about a 20 mile area that each have a different shade of rock from light pink to dark red. Back in the 70's and again in the 2010's An oil drill bit manufacture set up a drill rig and tested various experimental drill bits. Rumor has it they went down over 10,000 feet of solid granite and never ran out of it. Edited 58 minutes ago by oliver2-44 1 Share this post Link to post Share on other sites
