Jeremy J 7 #1 Posted September 3 I've had a 414 - 8 for several years and have just begun giving it an overhaul. The things in pieces getting cleaned up and different parts are getting the attention they have need for some time. So I was considering a new wiring harness. I'm certainly not finding one in my internet searches, but I had a feeling that someone in this forum would be able to point me in the right direction or bring me into reality as to what I should expect. Do I just need to fabricate the connections? Am I wasting my time trying to find some used rat's nest off of somebody's old tractor? I'd appreciate any feedback. I'm hoping to get this thing put back together soon. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #2 Posted September 3 Welcome to Red Square. Why do you think you need a new wiring harness? Have never seen new ones available. They can be easily taken apart and cleaned or repaired if necessary. Post your tractor's model and serial numbers so we can link you to the correct wiring diagrams. 2 1 1 Share this post Link to post Share on other sites
Achto 32,842 #3 Posted September 3 I usually make a new harness, if one is needed. 2 1 Share this post Link to post Share on other sites
953 nut 69,802 #4 Posted September 3 The likelihood of finding a new wiring harness for a nearly four decade old Wheel Horse is remote. There could be one out there but do you really need one? We can help you identify any problems and correct them. As far as I know the 414 model was made from 1987 to 1989. The 1987 (model # 31-14K802) wiring is not the same as the 1988 and 1989 (model # 31-14K803 or 31-14K804) because of the charging system being used. Though the wiring diagram may look like a multicolored bowl of spaghettis it can be understood if taken in small bytes (pun intended) and we have that resource available. Let us know the model number and the wiring difficulties you have experienced and we will help you overcome them. 2 1 Share this post Link to post Share on other sites
WHX?? 58,302 #5 Posted September 4 I'm with Dan on making a new one. 'Bout the only damn thing I'm good at. Lots of times you can inspect and reuse some of the old one. provided the wires weren't cut too short. 1 1 Share this post Link to post Share on other sites
wallfish 20,658 #6 Posted September 4 1 minute ago, WHX?? said: 'Bout the only damn thing I'm good at. Well then, You should'a been over there wiring that giveaway tractor at the BS so we could'a avoided the big smoke show I provided. LOL 4 Share this post Link to post Share on other sites
Jeremy J 7 #7 Posted September 4 I'm going to find the serial numbers. I'm working with my 2 teenage boys on it. 15 &17 years old. They are pretty good welders and already fixed the lift arm assembly that was broken off. And they wire wheeled the thing down and repaired the foot rest that was broken into 3 pieces. It still needs a lot of help, but it's been a nice project. 2 1 2 Share this post Link to post Share on other sites
WHX?? 58,302 #8 Posted September 4 10 hours ago, wallfish said: wiring that giveaway tractor at the BS I did a drive by and saw the Pullstart was involved so for my own safety ... 2 Share this post Link to post Share on other sites
Bill D 3,168 #9 Posted September 4 Not sure where you are in NY, but I may have a wiring harness from a 310-8 that had a Magnum engine and the two circuit stator with the 3 amp charging circuit and separate AC lighting circuit. I also have a shed full of spare parts if you're looking for something. 1 1 Share this post Link to post Share on other sites
953 nut 69,802 #10 Posted September 4 1 hour ago, Bill D said: Magnum engine and the two circuit stator with the 3 amp charging circuit and separate AC lighting circuit That is a 1987 only wiring, Model # 31-10K804 and should work in a 31-14K802. Share this post Link to post Share on other sites
