1054 Project 63 #1 Posted Tuesday at 07:21 PM For some time now I have needed to manually move the hydraulic lift lever back to neutral. I know there are rebuild kits available. So now that I have the unit on the bench (for a different issue) would you recommend diving into the pump? Is it a complicated process? Should I leave well-enough-alone? Share this post Link to post Share on other sites
ri702bill 12,754 #2 Posted Tuesday at 08:10 PM It is not a big deal to change. I believe Lowell has the Spring & gaskets... 3 1 Share this post Link to post Share on other sites
953 nut 68,330 #3 Posted Tuesday at 10:43 PM There are two kinds of springs used in the 1054 pumps. Open it up to see what spring you need prior to calling Lowell. https://wheelhorsepartsandmore.com/product-category/hydraulics/page/2/ 3 1 Share this post Link to post Share on other sites
adsm08 4,949 #4 Posted Tuesday at 11:34 PM Change it sooner than later. If it is one of the horse-shoe shaped springs and it broke the remaining piece will dig into the pump head with use, egging out the hole, gouging the surface, and ultimately making it unable to retain a new spring. 2 1 Share this post Link to post Share on other sites
Achto 32,303 #5 Posted Wednesday at 10:31 AM Advise when pulling the pump apart. 1 - The cylinder "#16 in the diagram" has a slight taper to it and has to slide in to be removed. 2 - If you need to remove the belt pulley, DO NOT tap on the shaft with a hammer. You WILL damage the pump gears. If you note these two things, a rebuild is pretty easy. 2 1 1 1 Share this post Link to post Share on other sites
peter lena 10,000 #6 Posted Wednesday at 11:52 AM @1054 Project opportunity ? regularly see looking for a cure , but no thought for related , lever / linkage connections . ENHANCE THAT SET UP , penetrating oil , will start a rust run out , then like red aerosol grease , or super lube , hydraulic oil , read specs , also use it all my cabling , set ups . just an idea , pete Share this post Link to post Share on other sites
WHX?? 57,681 #7 Posted Wednesday at 12:05 PM 1 hour ago, Achto said: DO NOT tap on the shaft with a hammer. You WILL damage the pump gears. And you know this because???? 1 1 4 Share this post Link to post Share on other sites
WHX?? 57,681 #8 Posted Wednesday at 05:11 PM 17 hours ago, adsm08 said: remaining piece will dig into the pump head with use, If the spring broke in pieces you don't want those floating around in there and if the handle just flops or left into lift or lower it will pop the relief spring which can cause unnecessary wear and tear on the pump. 2 Share this post Link to post Share on other sites
1054 Project 63 #9 Posted Wednesday at 06:39 PM OK...I definitely have the 953 style (horseshoe shaped spring) pump on my 1054. Although there is some gouging of the head I am more concerned about the second "mystery" hole on one side of the spool valve. Share this post Link to post Share on other sites
adsm08 4,949 #10 Posted Wednesday at 08:51 PM 2 hours ago, 1054 Project said: This is the exact type of damage I was referring to. The "mystery hole" looks like the spring broke some time ago, the owner at the time was unable to remove the broken section of spring, and and just made a new hole. 2 Share this post Link to post Share on other sites
adsm08 4,949 #11 Posted Wednesday at 08:52 PM 3 hours ago, WHX?? said: If the spring broke in pieces you don't want those floating around in there and if the handle just flops or left into lift or lower it will pop the relief spring which can cause unnecessary wear and tear on the pump. I have never not had the broken piece be so stuck in the hole that it required some effort to extract, to the point that I am totally unconcerned about that possibility. Share this post Link to post Share on other sites
1054 Project 63 #12 Posted 18 hours ago 16 hours ago, adsm08 said: This is the exact type of damage I was referring to. The "mystery hole" looks like the spring broke some time ago, the owner at the time was unable to remove the broken section of spring, and and just made a new hole. Would you advise "filling in" the unwanted hole? If I put the new spring in will I have to be worried that it will migrate over to the adjacent hole? Share this post Link to post Share on other sites
adsm08 4,949 #13 Posted 7 hours ago 11 hours ago, 1054 Project said: Would you advise "filling in" the unwanted hole? If I put the new spring in will I have to be worried that it will migrate over to the adjacent hole? I'm not really sure on that one. I have had no luck filling them in because the metal becomes so saturated with the hydraulic fluid nothing will stick to it, and welding will warp it. I've also never worked with one that has been redrilled like that. Share this post Link to post Share on other sites
WHX?? 57,681 #14 Posted 6 hours ago I had one where the spring was broke off flush with the hole and there was no getting it out so yes just a new hole next to it. Just make sure the holes are clean and the new spring legs seat down to the bottom. Share this post Link to post Share on other sites
