1054 Project
1054 Hydraulic Pump Return Spring
1054 Project
For some time now I have needed to manually move the hydraulic lift lever back to neutral. I know there are rebuild kits available. So now that I have the unit on the bench (for a different issue) would you recommend diving into the pump? Is it a complicated process? Should I leave well-enough-alone?988904407_WheelHorse1054withModelA4CCWHHydraulicPump02.PNG.ff7f3fc3740fe62dfab59d848634e4aa.PNG
ri702bill
It is not a big deal to change. I believe Lowell has the Spring & gaskets...
  • Heart 1
adsm08
Change it sooner than later. If it is one of the horse-shoe shaped springs and it broke the remaining piece will dig into the pump head with use, egging out the hole, gouging the surface, and ultimately making it unable to retain a new spring.
Achto
Advise when pulling the pump apart.
1 - The cylinder "#16 in the diagram" has a slight taper to it and has to slide in to be removed.
2 - If you need to remove the belt pulley, DO NOT tap on the shaft with a hammer. You WILL damage the pump gears.
If you note these two things, a rebuild is pretty easy.
  • Heart 1
peter lena
@1054 Project  opportunity ?  regularly see looking for a  cure , but no thought  for  related  , lever / linkage  connections . ENHANCE THAT  SET UP , penetrating oil  , will start a rust run out  , then  like red aerosol grease ,  or super lube , hydraulic oil , read  specs , also  use it all my cabling  , set ups . just an idea , pete
WHX??
And you know this because???? :lol:
  • Haha 4
WHX??
:text-yeahthat:If the spring broke in pieces you don't want those floating around in there and if the handle just flops or left into lift or lower it will pop the relief spring which can cause unnecessary wear and tear on the pump.
1054 Project
OK...I definitely have the 953 style (horseshoe shaped spring) pump on my 1054. Although there is some gouging of the head I am more concerned about the second "mystery" hole on one side of the spool valve.
adsm08
2 hours ago, 1054 Project said:
This is the exact type of damage I was referring to.
The "mystery hole" looks like the spring broke some time ago, the owner at the time was unable to remove the broken section of spring, and and just made a new hole.
adsm08
I have never not had the broken piece be so stuck in the hole that it required some effort to extract, to the point that I am totally unconcerned about that possibility.
1054 Project
Would you advise "filling in" the unwanted hole? If I put the new spring in will I have to be worried that it will migrate over to the adjacent hole?
adsm08
I'm not really sure on that one.
I have had no luck filling them in because the metal becomes so saturated with the hydraulic fluid nothing will stick to it, and welding will warp it. I've also never worked with one that has been redrilled like that.
WHX??
I had one where the spring was broke off flush with the hole and there was no getting it out so yes just a new hole next to it. Just make sure the holes are clean and the new spring legs seat down to the bottom.
