310 no key start
Do any of you do house calls?  LOL
I can start it by jumping solenoid to bat.
Can not start with key.
I tried.
New after market ignition switch and solenoid. And coil (mice chew).
Jumping clutch safety switch two of three prongs. (2 wires to switch).
Jumping seat switch.
Jumping amp gauge.
Cleaning grounds.
Reversing spade connectors on solenoid.
I have not yet messed with.
Fuse block.
PTO safety switch.
Oil safety switch.
Any switches I missed?
A pic of proper solenoid setup?
Any thoughts appreciated.
Just because that's how it was don't make it right.
953 nut
Not all wheel Horses are wired alike and they don't all use the same ignition switch.
What is the model number of your 310?   Once we have the model number we can pull up the correct information for you.
Thee model number is on a tag located under the seat on the left side.
Posted (edited)
3110k801
w-h
13508
0109
Original owner Arnold
That's all I have there.
I did find something hokie with fuses.
New ones are on the way. 25Amp.
I might have the solenoid tabs bass ackwards.
Is that possable?
No markings on solenoid.
Edited by 5151
  • Thanks 1
953 nut
Is that possable?
Solenoids are not polarity sensitive, either way is fine.
We just went through a very similar problem with anot5her member here. I am giving you a link to that thread as well ad the wiring manual for your 310-8, take a close look at the START page (7-70) as yours doesn't have the idiot lights and extra wires that the 314 has.
"Not polarity sensitive"
This reassures me thanks.
One spade takes 1 wire and other 2.
I WILL get to those other 2 reads thanks.
That clutch switch, the belt is long AND/OR the pedal needs adjusted.
Going to pull the fuse block to clean and inspect. So if they blow I can isolate.
Two old ones bad.
This WH has way more hours than my other. We'll call it experience and patina.
I'll update.
953 nut
Rereading your first post now that we know the model number. Did you replace the ignition switch with a 103991 switch?
Jumping clutch safety switch two of three prongs. (2 wires to switch).No harm done there
Jumping seat switch.    Seat switch is in the ignition system kill circuit. It has nothing to do with the starter but with a jumper in place it will prevent the magneto from producing a spark IF the PTO is in the engaged (forward) position
Jumping amp gauge.  Your 310 came with a volt meter, not an amp meter unless it was added by a previous owner. No harm done IF it is an AMP Meter, if it is a volt meter you may have blown the 15 amp fuse.
Cleaning grounds.:handgestures-thumbupright:
Fuse block.       corrosion in the fuse holders can be a problem area.
PTO safety switch.
Oil safety switch. If the oil level is low the starter will not activate with the key. Presuming your oil level is good to test the low oil switch there is a five terminal connector behind the engine, unplug it and see if the starter will turn over from the key. If the engine starts you will need to use the choke to stop it because the kill wire is also in that plug.
Hope this helps.
Ig switch receipt from a2z has several #s and that is one.
10-4 om the meter. You are good.
That explains the recent blown fuse thanks.
Any other fuses or fusible links?
Good info on oil switch, my other tractor must be wired differently. You may have saved me extra head ache there.
I'll get a little more time on it soon.
gwest_ca
If you have to remove the low oil switch in the base of the engine there are special instructions on how to do it without damaging the switch
  • Excellent 1
How do I see these "admin uploaded a file"?
Anything I try, they go hide in this system never to be seen again.
Probably some in there older than a computer science graduate lol.
If proprietary, that is working.
I'll probably have this thing running from key today, big thanks to you folks.
gwest_ca
Click on the fuzzy text picture in the link above. That should take you to the cover page for the file. You should be able to download from there.
I didn't start it but the ignition seems to be working.
Crank case is draining. Would like to leave that oil switch alone.
Fuse block was plugged with crud bad and one mounting ear broken.
Clutch switch had one wire off,,,
and,, solenoid had no spade tabs and 2 small wires from harness were hanging, but had a wire with clip for jumping.
Hence no key start right there "I think".
Fixing the old fixes the hard way.
Couple more I probably forgot to mention.
Going to lube all.
On the radar now, axil seal, shifter boot, of course the seat, those plastic battery hold down wingnuts.
Enough rambling for now. Special thanks to 953 nut and the site.
953 nut
Check your "Downloads File".
I do know right where the chainsaw files are located.
I asked a young I.T. guy if he knew of a good new electro como device I could buy.
Without hesitation he said no lol.
I do need an update.
