hotajax 284 #1 Posted 6 hours ago I remember one of you gents told me you bot a seat from TS, and it bolted right on. I can't remember who the member was, but the dealer was definitely Tractor Supply. If you can remember some details about the seat, I'd be appreciative. Thanks. Share this post Link to post Share on other sites
MainelyWheelhorse 3,021 #2 Posted 5 hours ago (edited) I have a TS seat on my 308 it was a direct bolt on affair. One of the pre drilled bolt patterns in the seat bottom is the 7.5 x 7 Wheel Horse seat bolt pattern. I’d assume the others in that brand have the same pattern built in. It’s a bit expensive but I haven’t had an issue with the seat. Edited 5 hours ago by MainelyWheelhorse 1 Share this post Link to post Share on other sites
hotajax 284 #3 Posted 3 hours ago 2 hours ago, MainelyWheelhorse said: I have a TS seat on my 308 it was a direct bolt on affair. One of the pre drilled bolt patterns in the seat bottom is the 7.5 x 7 Wheel Horse seat bolt pattern. I’d assume the others in that brand have the same pattern built in. It’s a bit expensive but I haven’t had an issue with the seat. Thanks for putting this up there. Do you have any issues swinging your leg over the higher back? 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,021 #4 Posted 3 hours ago @hotajax No, I usually just step over the shifter, on to the right or left foot board and sit down on the seat. 1 Share this post Link to post Share on other sites
rjg854 13,274 #5 Posted 2 hours ago On some of my tractors I sit on the side of the seat and swing my leg over the steering wheel. Most know I'm vertically challenged 1 2 Share this post Link to post Share on other sites
CRF857 515 #6 Posted 1 hour ago 1 hour ago, rjg854 said: On some of my tractors I sit on the side of the seat and swing my leg over the steering wheel. Most know I'm vertically challenged Heck, I am 5’ 13” (6’-1”) and I do that on most of my tractors. Certainly don’t like kicking it into gear with my big feet while trying to not fall off. 1 Share this post Link to post Share on other sites
953 nut 68,197 #7 Posted 51 minutes ago Never mount or dismount a running garden tractor or anything else. Share this post Link to post Share on other sites
