MainelyWheelhorse 3,145 #26 Posted August 29 2 hours ago, adsm08 said: Alcohol in the gas has basically nothing to do with emissions. It does not impact 4 of the 5 gasses directly, may reduce Nox some as it burns cooler, and if the whole life-cycle is looked at is a net carbon producer vs straight gas. It is partially to try and reduce fuel prices as it is cheaper, but it is largely a give-away to corn farmers. That was supposed to be part of a Dr Seussian rhyme like what Sylvan did. I wasn’t commenting on emissions. I’d go back and try to fit something in about cheaper gas but that doesn’t seem to flow as well in the context of the rest of the rhyme. 1 Share this post Link to post Share on other sites
John c 224 #27 Posted August 29 Around here we have R90, recreational fuel, boats, motorcycles, lawn mowers etc, 90 octane. I add standard sta-bil to mine to help preserve the octane a bit longer I've found it runs better than not after it's set for a while. 3 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #28 Posted August 29 21 hours ago, ebinmaine said: Every single Small Engine piece of equipment we have gets non-ethanol fuel. To the best of my knowledge there is not one additive that negates the effects of ethanol such as grabbing extra water and rusting lines, degrading rubber, and possibly eating aluminum parts. Regular gas around here is just below $4 this week. I believe non ethanol can be had for around $5.70. Eric that is not a bad price for what you’re getting. I am getting ready to make a N/H run my self. 2 Share this post Link to post Share on other sites
ebinmaine 80,881 #29 Posted August 29 6 hours ago, John c said: R90, recreational fuel Yep. That's what's here. 90. 91. Depends on the station. I guess it's good to be in a very high traffic tourist economy even though we don't participate in those. 1 Share this post Link to post Share on other sites
Bill D 3,166 #30 Posted August 29 (edited) I'm lucky to have a couple of stations across the Hudson from me that sell it. About 8 miles each way. Typically in the $5+ dollar range these days. Cheap piece of mind in my opinion. It's nice to have something with two year old gas that starts on the first pull. I put 1 oz of marine formula stabil in each 5 gallon can before I fill up. Edited August 29 by Bill D 3 Share this post Link to post Share on other sites
peter lena 10,082 #31 Posted August 29 @ebinmaineNO REAL testing ? thats a BASE LINE TO A PROBLEM ELIMINATION ! years back , went thru EVERY STAGE OF PROBLEM AREA , cleaned out tank , replaced fuel valve , then set up an assurance of IMPROVEMENT , fuel filter ,immediately shows , clean / clear flow, then fresh line , good spot for a 1/4 or 5/16 metal brake line , totally eliminating all that hose , tucks right into inside upper frame corner , easily secured , like a fuel check valve / filter , clear fuel rated hose up to carb? SHOWING YOU WHATS THERE ! YEARS IN USE , no problems , consistent operational function , combine that with lubricated , spring pull assisted , choke / throttle cables , basically broke down every stage , sta bil , is a no brainer for me , regular leaded gas , just my experiment , pete 1 Share this post Link to post Share on other sites
lynnmor 9,049 #32 Posted August 29 32 minutes ago, peter lena said: @sta bil , is a no brainer for me , regular leaded gas , just my experiment , pete Hasn't been any leaded gas for many years except possibly aviation fuel. 1 1 Share this post Link to post Share on other sites
rjg854 13,398 #33 Posted August 29 I have 2 tractors that are only used in the winter, other than that they sit. I add nothing to the non-ethanol fuel and never have a problem starting them. I do put a maintainer on them every couple of months to keep them charged but that is usually only for a day, at most. They crank a bit at start up because I always shut of the fuel at the tank and run them until they run out of gas. 1 Share this post Link to post Share on other sites
ebinmaine 80,881 #34 Posted August 29 2 hours ago, peter lena said: @ebinmaineNO REAL testing ? I mean no real testing of STABIL I have no science lab here. 2 hours ago, peter lena said: thats a BASE LINE TO A PROBLEM ELIMINATION ! years back , went thru EVERY STAGE OF PROBLEM AREA , cleaned out tank , replaced fuel valve , then set up an assurance of IMPROVEMENT , fuel filter ,immediately shows , clean / clear flow, then fresh line , good spot for a 1/4 or 5/16 metal brake line , totally eliminating all that hose , tucks right into inside upper frame corner , easily secured , like a fuel check valve / filter , clear fuel rated hose up to carb? SHOWING YOU WHATS THERE ! YEARS IN USE , no problems , consistent operational function , combine that with lubricated , spring pull assisted , choke / throttle cables , basically broke down every stage , sta bil , is a no brainer for me , regular leaded gas , just my experiment , pete My elimination of problems is to replace the part properly. No farmer fixes. No mickey mousing. No hack jobs. Repair. Replace. Maintenance. Lubrication. Good quality parts. All add up to a winning combination. 4 Share this post Link to post Share on other sites
Brockport Bill 2,478 #35 Posted August 29 speaking of gas -- i have read there is advantage to occasionally putting a splash or more of the 50-1 or 40-1 fuel from the premixed cans into the tractor tank ? Yes/no ??? Any thoughts Share this post Link to post Share on other sites
ri702bill 13,162 #36 Posted August 29 Fogging for mosquitoes?? 3 Share this post Link to post Share on other sites
lynnmor 9,049 #37 Posted August 29 41 minutes ago, ri702bill said: Fogging for mosquitoes?? I sold an old Sears 16 HP Onan tractor and only had my chainsaw mix to fire it up. To my surprise it didn't smoke a bit 1 Share this post Link to post Share on other sites
adsm08 5,186 #38 Posted August 29 22 hours ago, 953 nut said: Are you telling me that the anti-petroleum "I'm from the Government and I'm here to help you" crowd is showing favoritism to the corn farmers even though it ended up driving up gas prices? Say it isn't so. Yes. It lower the cost per gallon at the pump, but increased the cost per mile as it goes out the exhaust, and you pay extra taxes for the subsidies. But by the time everyone realized it was a bad deal any politician that tried to walk it back was going to loose their next re-election bid. What was that saying? "There is nothing as permanent as a temporary government program"? 3 1 Share this post Link to post Share on other sites
ebinmaine 80,881 #39 Posted August 30 18 hours ago, Brockport Bill said: speaking of gas -- i have read there is advantage to occasionally putting a splash or more of the 50-1 or 40-1 fuel from the premixed cans into the tractor tank ? Yes/no ??? Any thoughts Bill I did a quick search on the all knowing interwebs and couldn't really find a specific positive impact. Some say it'll smoke a little but not hurt anything. Share this post Link to post Share on other sites
peter lena 10,082 #40 Posted August 30 @hotajax @Beap52 , my regular references to to trials / experiments are the final stage of CHANGE I made to a REPEDITIVE ISSUE ? base line , clean out tank , eliminating all trapped fuel debris / breakdown , new fuel valve , then all related hose , change out , ELIMINATING HOSE BREAKDOWN STAGES , MAKE SENSE ? ??? , now fresh hose , and fuel filters , then add STA BIL , ounce or two to every top off , also never let my tank go empty , since going over to this year s ago , I have had zero fuel related issues , realise this is a very contentious issue , personally love , ERADICATING PROBLEMS ? if something is kicking your a-- , you want to stop it ,right ? also never burned out a pto drive clutch disc , thats another multi stage mess, its staring right at you , good luck with your maintenance . pete 1 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #41 Posted August 31 On 8/29/2026 at 7:34 AM, Bill D said: I'm lucky to have a couple of stations across the Hudson from me that sell it. About 8 miles each way. Typically in the $5+ dollar range these days. Cheap piece of mind in my opinion. It's nice to have something with two year old gas that starts on the first pull. I put 1 oz of marine formula stabil in each 5 gallon can before I fill up. I’ve been told you don’t have to do that Bill. But I am with you on this. In my mind if you go through it quickly like six months I don’t think you have to do it, but I have some under the porch. That is a couple years old so that’s why I put it in there. I usually use this. A cap full treats, 1.5 gallons. Share this post Link to post Share on other sites
peter lena 10,082 #42 Posted August 31 @Retired Wrencher glad you are trying something ? my stand by generator , sits for months , with instant starts , my reference to fuel line replace ment , was after I cleaned out entire set up , verifying a fresh clean start, your star tron / my sta bil , do the same thing, most important proof ? zero / no debris / fuel hose break down at all . when I go at any problem , go after EVERY STAGE , NOT JUST THE MOST OBVIOUS , EX ? frayed belts , WHY? its not the belt , its , INCREMENTAL BEARING LUBRICATION FAILURE , the bearing hangs up / stops for a second , that led me to , cleaning out and regreasing , every wide seal bearing , with https://www.landmsupply.com/lucas-oil-x-tra-heavy-duty-grease-14-5-oz?g, all my decks , pto / mule drive , engage / spin up with total ease. , BTH that pto lever set up is a gold mine , for improvement , pete 1 Share this post Link to post Share on other sites
CasaytheMann 278 #43 Posted August 31 (edited) Just got back from the local Maverick gas station. Bought 4 gallons of ethanol free for $5.79 a gallon. Edited August 31 by CasaytheMann 2 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #44 Posted September 1 11 hours ago, CasaytheMann said: Just got back from the local Maverick gas station. Bought 4 gallons of ethanol free for $5.79 a gallon. That is not bad price in today’s market. 1 Share this post Link to post Share on other sites
rjg854 13,398 #45 Posted September 1 $4.79 two miles down the road from me, it's an Indian owned station. And that's the only grade of gas they sell. 2 1 Share this post Link to post Share on other sites
