squonk 48,186 #1 Posted August 26 Finally finished Miss Daisy. Parts came under the cover of darkness. New key switch, fuel lines, fuel shutoff and grommet, used ammeter, changed the fluids 3 used tires and the patina treatment. Runs flawless. Didn't have to touch the carb at all, Belt rattles at low engine speed. Thinking of a new belt even though the old one looks ok and an idler pulley. On to the deck to see if I can salvage it and sell it as a unit. 2 12 1 Share this post Link to post Share on other sites
kpinnc 18,996 #2 Posted August 26 33 minutes ago, squonk said: Runs flawless. Yes it does. Very nice machine! 1 Share this post Link to post Share on other sites
CRF857 1,191 #3 Posted August 26 (edited) That kinda sounded like the drive belt idler. I had to out a spring on mine to keep it from rattling. Otherwise sounds good to my ears. Edited August 26 by CRF857 Share this post Link to post Share on other sites
Sparky-(Admin) 26,424 #4 Posted August 27 Nice! Motor sounds great. No smoke at startup? 1 Share this post Link to post Share on other sites
ri702bill 13,123 #5 Posted August 27 Nice! Runs great. The "Baby C81" Share this post Link to post Share on other sites
Retired Wrencher 6,992 #6 Posted August 27 (edited) 13 hours ago, squonk said: Finally finished Miss Daisy. Parts came under the cover of darkness. New key switch, fuel lines, fuel shutoff and grommet, used ammeter, changed the fluids 3 used tires and the patina treatment. Runs flawless. Didn't have to touch the carb at all, Belt rattles at low engine speed. Thinking of a new belt even though the old one looks ok and an idler pulley. On to the deck to see if I can salvage it and sell it as a unit. The old B-80 did well Mike. Did you set the idol @1200? Seem a little low? I have had three in my day 4 speeds and 8`s. I always like them. Nice stout little tractor that has an attitude for work. Edited August 27 by Retired Wrencher Share this post Link to post Share on other sites
Buckeyes 277 #7 Posted August 27 @squonk That sounds and runs amazing! Looks fantastic! Share this post Link to post Share on other sites
squonk 48,186 #8 Posted August 27 2 hours ago, Sparky said: Nice! Motor sounds great. No smoke at startup? None. 23 minutes ago, Retired Wrencher said: The old B-80 did well Mike. Did you set the idol @1200? Seem a little low? I have had three in my day 4 speeds and 8`s. I always like them. Nice stout little tractor that has an attitude for work. The only thing I touched on the carb was look at the air filter. 4 1 Share this post Link to post Share on other sites
sqrlgtr 4,035 #9 Posted August 27 2 hours ago, squonk said: The only thing I touched on the carb was look at the air filter. Ive only had this happen one time, it was on a 73 WH 12-8speed no name. Ive had that tractor for several years now and still have not had to touch carb . Might be according to who the PO was and how mochine was treated before? IDK but this usually doesn't happen. Great looking/sounding tractor @squonk....... I did trade @WHX?? out of a 1257 that didn't require anything either, but it was a running operating tractor when I got it so it doesn't count.. 1 Share this post Link to post Share on other sites
lynnmor 9,042 #10 Posted August 27 I would always adjust the carburetor so that you know the mixture, idle mixture, idle speed and maximum RPM is correct. We had a Cub Cadet dealer that always set for the leanest mixture possible, they ran well till they didn't. I replaced the valves he burned. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,992 #11 Posted August 28 23 hours ago, squonk said: None. The only thing I touched on the carb was look at the air filter. Very nice Mike looks to be a keeper. Share this post Link to post Share on other sites
Retired Wrencher 6,992 #12 Posted September 3 (edited) Mike I keep watching your video. It’s just amazing sometimes you pick these tractors up and there dusty and dirty and you think to yourself what am I getting myself into. But in your case you did well picking that one up. We all wish we could be lucky like that.The B 100 is almost done I will post a video with your wheel weights on it. Edited September 3 by Retired Wrencher Share this post Link to post Share on other sites
