Rob.in.motion 0 #1 Posted August 25 Hello, I have a wheelhorse 110-4 mower with an 900-028 peerless transmission and it goes into gear when started up then shoots forward a couple of centimeters en then does not move anymore and I also cannot move the shifter out of gear. The pully does keep turning but no power is transmitted I hope someone can help me with this issue Share this post Link to post Share on other sites
953 nut 70,262 #2 Posted August 25 Here are links to your transmission's manuals, hope they will help. 1 1 Share this post Link to post Share on other sites
Rob.in.motion 0 #3 Posted August 26 16 hours ago, 953 nut said: Here are links to your transmission's manuals, hope they will help. Thank you for the manuals! but they don’t tell me what I need to know unfortunately, I need an expert opinion to help me further and I hope to get that here Share this post Link to post Share on other sites
8ntruck 9,374 #4 Posted August 26 (edited) If I understand your description of your trouble, the tractor does not move and the shifter acts like it is jammed in place. That sounds to me like the trans is stuck in 2 gears at once. It has been 20, maybe 30 years since I've been into Peerless, so I'm working from memory. If my memory is correct, that transmission is a constant mesh unit that picks what gear it is in with a sliding shaft that has a key that is one gear wide - or something similar. I'd expect that you will need to open the case and see what is jammed. I had to get into mine to replace the bevel gears on the input shaft - my son's were teenagers at the time and they treated the Craftsman mower like a race car. Good luck. Edited August 26 by 8ntruck Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,530 #5 Posted August 28 I recall in the distant past that owners were having a lot of shift key problems but never understood the problem nor have I every seen some. Never hear of it anymore unless that is the problem with this one. Share this post Link to post Share on other sites
Rob.in.motion 0 #6 Posted August 28 On 8/26/2026 at 9:42 PM, 8ntruck said: If I understand your description of your trouble, the tractor does not move and the shifter acts like it is jammed in place. That sounds to me like the trans is stuck in 2 gears at once. It has been 20, maybe 30 years since I've been into Peerless, so I'm working from memory. If my memory is correct, that transmission is a constant mesh unit that picks what gear it is in with a sliding shaft that has a key that is one gear wide - or something similar. I'd expect that you will need to open the case and see what is jammed. I had to get into mine to replace the bevel gears on the input shaft - my son's were teenagers at the time and they treated the Craftsman mower like a race car. Good luck. Can it be that the pin that is on the shiftkey that shifts the collar, is worn out and does not put it in the right gear because it misses the spot by maybe a fey millimeters? Share this post Link to post Share on other sites
8ntruck 9,374 #7 Posted August 28 1 hour ago, Rob.in.motion said: Can it be that the pin that is on the shiftkey that shifts the collar, is worn out and does not put it in the right gear because it misses the spot by maybe a fey millimeters? Possible. Hard to say for sure without seeing. Please consider that I am working from 30 year old memories that aren't crystal clear. Share this post Link to post Share on other sites
