pfrederi
Loaner Comes Home
pfrederi
Loaned a Charger 12 to my nephew a year and half ago.  Came home yesterday piston does not go up and down any more.  He didn't hear anything.  Guess I have a new project.  Got the engine off the tractor draining, it no glittery stuff in the oil.  Will be interesting to see inside.
  • Sad 8
squonk
Posted (edited)
Rod broke about an inch under the wrist pin.
Edited by squonk
ebinmaine
Can you push it by hand or hammer?
ri702bill
So it did not "ventilate" the block? No sudden "oil everywhere" bath? You may have gotten lucky.... Maybe...
Retired Wrencher
Looks like a good winter project Paul!
rmaynard
Piston does not move, but does the crankshaft turn at all?
pfrederi
Piston was TDC when I opened it and engine spun freely.  I pushed it down now things don't move.   No vents in the block tonight should be able to flip it over take the oil pan off and look at the damage
Valves are working
  • Sad 1
pfrederi
Good news  no holes in the block
Small chunk chipped out of cylinder end
Obviously oil related failure.  Now do I blame nephew?? How long would an engine have to run to get this bad.  I got her in 2016 and she was on snow plow duty then went to my brother also some snow pow duty (2019).  Came home to me after 4 years when my brother went to long term care.  He didn't use it much and I used to make sure there was oil in it when I visited...But don't think it was changed very often. Nephew got it in spring 2025 mowed half acre that year and this year up until late June.  He say he didn't hear anything.
Sorry but I don't like it when a machine breaks because of an oil issue...
  • Sad 4
Handy Don
I’ve seen two B&S engines with oil pumps fail from low oil. Years apart, but both were mowing sideways on sloped lawns so probably the oil intakes lost contact with the low oil in the sump. My guess in both cases is that from the point where the oil level stopped providing adequate lubrication until part seizure was a minute or so. In both cases I saw, the engines had been running around 10 minutes from startup but had transitioned from level to slope only a minute or so before seizing.
squonk
My "Shelf of Shame."
  • Like 4
  • Sad 2
adsm08
My first k181 did this. I knew it used oil, but it had been about 1/4 qt across the whole of the summer. It apparently got much worse very quickly.
I had it running to warm the oil before a change and had to go deal with some kid thing. It sounded 100% normal when I walked away. The guy across the street said he heard a loud pop, and then it shut off.
tunahead72
This hit really close to home...  My C-105 just did something very similar a couple weeks ago, and I'm still not at all sure exactly what happened.  All I know is the top of the piston blew apart, rings mangled, valves bent, that sort of thing.  I'll know more later, and may post about it separately.
My wife and daughter both question my decision to try to get this engine rebuilt if it's possible.  I just chuckle to myself and try really hard to answer their questions, knowing full well they'll never truly accept it.  Whatever.
Carry on.
  • Sad 2
Rick3478
How much oil was actually in it?
There are other things that can happen besides low oil.  For example: Not running long enough to evaporate all the moisture in the crankcase, a little stays in the rod bearing and rusts the crank, just a little at first.  Next time it runs, the rust smears off a little bit of rod alloy.  Now you have a little groove, which will hold more moisture the next time you don't run it long enough.  You get more rust, which smears more aluminum and makes more grooves, etc.  Keep doing it, at some point enough aluminum builds up that it seizes, breaks off the big end of the rod and throws the piston to top of bore where it stays.
In any case, as they say, you are here.
And you know what needs to be done.
953 nut
The crankshaft should clean up OK with a bit of muriatic acid. A non-running parts tractor I bought twenty some odd years back had a crank looked just like that and a small chip out of the bottom of the cylinder. Honed the cylinder, put a piston and rod kit in it and it ran well. Sold the tractor a few years later and the new owner loved it.
pfrederi
Finally got back to this engine.  Looks to me like the crank has some damage next to the journal .  Thoughts ??? Think it is reusable or will balance be off??
  • Sad 1
ebinmaine
The grinding marks facing us in this picture may be from initial production and balancing. IF the bearing surfaces clean up OK- it could be just fine.
squonk
Never seen balance marks like that. Clean up the journal. Check it good for run out. I would see if a local shop could magnaflux it. I have my doubts it's still usable. I have a couple 321 cranks from broken engines that looked better I saved.
Edited by squonk
squonk
All of that crank grinding happened right next to a bearing. I would be inspecting/replacing that for sure!
Easton Rich
I had this happen on a B-80 I bought about 3 months ago, the exact same thing. Piston was at TDC when I pulled the head and I pushed it down by hand.
ebinmaine
The grinding marks on the end of the crankshaft aren't in line with rotation. They are horizontal or even in a slightly upward & opposite line.
921639169_Screenshot_20261019_075106_Chrome2.jpg.3bc4d45208f4a002dcf1e87a911af949.jpg
1881838793_Screenshot_20261019_073143_Chrome2.jpg.563a0f315db60e259768e4607959c2e5.jpg
Here's a zoom & crop of your pic above.
Notice similar straight lines in the same place.
1700474564_Screenshot_20261019_073045_Chrome2.jpg.d5058ef74e3b369ada432be15330a5f6.jpg
DEFINITELY AGREED.
There's a LOT of damage on the journal.
pfrederi
I am going to take it to my machine shop at some point.  If it is not useable i think the engine is done.  Overhaul Machine shop work plus parts kit $375   add a used crank which seems to run around 100 not sure it is worth it
  • Sad 1
ebinmaine
Situationally dependant.
If I wanted that tractor to last another 50 years and I didn't already have a spare engine - I'd spend $500 (or more) on a Kohler > in a heartbeat < before using a cheapo replacement.
But with extra engines or whole machines available? It'd get shelved...
