pfrederi 21,183 #1 Posted August 25 Loaned a Charger 12 to my nephew a year and half ago. Came home yesterday piston does not go up and down any more. He didn't hear anything. Guess I have a new project. Got the engine off the tractor draining, it no glittery stuff in the oil. Will be interesting to see inside. 1 7 Share this post Link to post Share on other sites
squonk 48,160 #2 Posted August 25 (edited) Rod broke about an inch under the wrist pin. Edited August 25 by squonk 2 Share this post Link to post Share on other sites
ebinmaine 80,767 #3 Posted August 25 1 hour ago, pfrederi said: piston does not go up and down any more. Can you push it by hand or hammer? Share this post Link to post Share on other sites
ri702bill 13,095 #4 Posted August 25 So it did not "ventilate" the block? No sudden "oil everywhere" bath? You may have gotten lucky.... Maybe... 1 Share this post Link to post Share on other sites
Retired Wrencher 6,990 #5 Posted August 26 Looks like a good winter project Paul! Share this post Link to post Share on other sites
rmaynard 17,589 #6 Posted August 26 Piston does not move, but does the crankshaft turn at all? Share this post Link to post Share on other sites
pfrederi 21,183 #7 Posted August 26 Piston was TDC when I opened it and engine spun freely. I pushed it down now things don't move. No vents in the block tonight should be able to flip it over take the oil pan off and look at the damage Valves are working 1 Share this post Link to post Share on other sites
pfrederi 21,183 #8 Posted August 27 Good news no holes in the block Small chunk chipped out of cylinder end Obviously oil related failure. Now do I blame nephew?? How long would an engine have to run to get this bad. I got her in 2016 and she was on snow plow duty then went to my brother also some snow pow duty (2019). Came home to me after 4 years when my brother went to long term care. He didn't use it much and I used to make sure there was oil in it when I visited...But don't think it was changed very often. Nephew got it in spring 2025 mowed half acre that year and this year up until late June. He say he didn't hear anything. Sorry but I don't like it when a machine breaks because of an oil issue... 2 2 Share this post Link to post Share on other sites
Handy Don 17,494 #9 Posted August 27 I’ve seen two B&S engines with oil pumps fail from low oil. Years apart, but both were mowing sideways on sloped lawns so probably the oil intakes lost contact with the low oil in the sump. My guess in both cases is that from the point where the oil level stopped providing adequate lubrication until part seizure was a minute or so. In both cases I saw, the engines had been running around 10 minutes from startup but had transitioned from level to slope only a minute or so before seizing. 3 Share this post Link to post Share on other sites
squonk 48,160 #10 Posted August 27 My "Shelf of Shame." 4 1 1 Share this post Link to post Share on other sites
adsm08 5,159 #11 Posted August 28 8 hours ago, pfrederi said: Good news no holes in the block Small chunk chipped out of cylinder end Obviously oil related failure. Now do I blame nephew?? How long would an engine have to run to get this bad. I got her in 2016 and she was on snow plow duty then went to my brother also some snow pow duty (2019). Came home to me after 4 years when my brother went to long term care. He didn't use it much and I used to make sure there was oil in it when I visited...But don't think it was changed very often. Nephew got it in spring 2025 mowed half acre that year and this year up until late June. He say he didn't hear anything. Sorry but I don't like it when a machine breaks because of an oil issue... My first k181 did this. I knew it used oil, but it had been about 1/4 qt across the whole of the summer. It apparently got much worse very quickly. I had it running to warm the oil before a change and had to go deal with some kid thing. It sounded 100% normal when I walked away. The guy across the street said he heard a loud pop, and then it shut off. 2 Share this post Link to post Share on other sites
tunahead72 2,662 #12 Posted August 28 9 minutes ago, adsm08 said: My first k181 did this. I knew it used oil, but it had been about 1/4 qt across the whole of the summer. It apparently got much worse very quickly. I had it running to warm the oil before a change and had to go deal with some kid thing. It sounded 100% normal when I walked away. The guy across the street said he heard a loud pop, and then it shut off. This hit really close to home... My C-105 just did something very similar a couple weeks ago, and I'm still not at all sure exactly what happened. All I know is the top of the piston blew apart, rings mangled, valves bent, that sort of thing. I'll know more later, and may post about it separately. My wife and daughter both question my decision to try to get this engine rebuilt if it's possible. I just chuckle to myself and try really hard to answer their questions, knowing full well they'll never truly accept it. Whatever. Carry on. 2 Share this post Link to post Share on other sites
Rick3478 469 #13 Posted August 28 How much oil was actually in it? There are other things that can happen besides low oil. For example: Not running long enough to evaporate all the moisture in the crankcase, a little stays in the rod bearing and rusts the crank, just a little at first. Next time it runs, the rust smears off a little bit of rod alloy. Now you have a little groove, which will hold more moisture the next time you don't run it long enough. You get more rust, which smears more aluminum and makes more grooves, etc. Keep doing it, at some point enough aluminum builds up that it seizes, breaks off the big end of the rod and throws the piston to top of bore where it stays. In any case, as they say, you are here. And you know what needs to be done. 2 Share this post Link to post Share on other sites
953 nut 69,557 #14 Posted August 28 The crankshaft should clean up OK with a bit of muriatic acid. A non-running parts tractor I bought twenty some odd years back had a crank looked just like that and a small chip out of the bottom of the cylinder. Honed the cylinder, put a piston and rod kit in it and it ran well. Sold the tractor a few years later and the new owner loved it. 2 Share this post Link to post Share on other sites
pfrederi 21,183 #15 Posted 4 hours ago Finally got back to this engine. Looks to me like the crank has some damage next to the journal . Thoughts ??? Think it is reusable or will balance be off?? 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #16 Posted 4 hours ago 40 minutes ago, pfrederi said: Finally got back to this engine. Looks to me like the crank has some damage next to the journal . Thoughts ??? Think it is reusable or will balance be off?? The grinding marks facing us in this picture may be from initial production and balancing. IF the bearing surfaces clean up OK- it could be just fine. 1 Share this post Link to post Share on other sites
squonk 48,160 #17 Posted 2 hours ago (edited) Never seen balance marks like that. Clean up the journal. Check it good for run out. I would see if a local shop could magnaflux it. I have my doubts it's still usable. I have a couple 321 cranks from broken engines that looked better I saved. Edited 2 hours ago by squonk 1 Share this post Link to post Share on other sites
squonk 48,160 #18 Posted 2 hours ago All of that crank grinding happened right next to a bearing. I would be inspecting/replacing that for sure! Share this post Link to post Share on other sites
