MowerGuy21 1 #1 Posted Saturday at 08:54 PM Hi all, I’m brand new to the forum. I’ve got a Wheel Horse 108-5 mower. She starts up real nice and drives around well. However, I can’t get the belts quite right. The drive belt is fine, as is the belt that heads to the mower deck itself. But the belt that goes from the driveshaft pulley to the pulley that connects to the deck belt pulley is giving me fits. I can’t seem to get it tensioned up right. I have the #112114 belt and it will go on. But even when I “engage,” it still has a lot of play. If I try to go mow, the belt just slips and smokes. Any chance the belt is wrong? There’s a long piece of flexible metal that runs along the belt path. What is that for? Does it have to do with tensioning the belt or something else? Thank you for the help! Share this post Link to post Share on other sites
ri702bill 12,682 #2 Posted Saturday at 10:00 PM Welcome! Pictures of the area in question are needed to better understand the actual issue.. Share this post Link to post Share on other sites
MowerGuy21 1 #3 Posted Saturday at 10:16 PM 14 minutes ago, ri702bill said: Welcome! Pictures of the area in question are needed to better understand the actual issue.. Thanks for the welcome! I’m out this evening but I’ll try to post some pictures of the underside tomorrow. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,414 #4 Posted Saturday at 10:47 PM Welcome to Red Square This may help 25 search results for the 108-5 https://www.wheelhorseforum.com/search/?q=108-5&quick=1&type=downloads_file Share this post Link to post Share on other sites
Ed Kennell 46,786 #5 Posted Saturday at 11:23 PM to the 1 Share this post Link to post Share on other sites
953 nut 68,096 #6 Posted Saturday at 11:39 PM The manuals that Gary linked will probably answer your questions. 1 Share this post Link to post Share on other sites
ineedanother 2,749 #7 Posted yesterday at 02:47 AM (edited) 5 hours ago, MowerGuy21 said: Hi all, I’m brand new to the forum. Butler, PA? Lots of great folks here with volumes of knowledge. You can introduce yourself here and : https://www.wheelhorseforum.com/forum/47-introductions/ Edited yesterday at 02:49 AM by ineedanother 1 Share this post Link to post Share on other sites
MowerGuy21 1 #8 Posted 15 hours ago 15 hours ago, gwest_ca said: Welcome to Red Square This may help 25 search results for the 108-5 https://www.wheelhorseforum.com/search/?q=108-5&quick=1&type=downloads_file Thanks for these, Gary! Definitely a help with learning more about this mower! Share this post Link to post Share on other sites
MowerGuy21 1 #9 Posted 15 hours ago 14 hours ago, 953 nut said: The manuals that Gary linked will probably answer your questions. Thanks for these welcome! While Gary’s manuals were enlightening about quite a few aspects of the mower, they didn’t seem to include much about the PTO belt which is my problem-area. Share this post Link to post Share on other sites
MowerGuy21 1 #10 Posted 14 hours ago 11 hours ago, ineedanother said: Butler, PA? Lots of great folks here with volumes of knowledge. You can introduce yourself here and : https://www.wheelhorseforum.com/forum/47-introductions/ Yes, Butler PA. I’ll head over to that introduction page and introduce myself when I have some time Thank you! Share this post Link to post Share on other sites
ineedanother 2,749 #11 Posted 12 hours ago 2 hours ago, MowerGuy21 said: Yes, Butler PA. I’ll head over to that introduction page and introduce myself when I have some time Thank you! Cool. There's more than one so I figured I'd ask. I was born there and get back there occasionally. 1 Share this post Link to post Share on other sites
MowerGuy21 1 #12 Posted 7 hours ago Hopefully this works… pictures of the belt on the mower. It’s in “engage” mode. There’s still plenty of play on the belt even though I’ve got the PTO adjusted to take up as much slack as possible. Is it supposed to be this loose? You can see the slack especially well in the third picture. I was given the mower last summer and had this same issue. Put it away for a while and now I’m banging my head against a wall again. Fires right up and runs well, but it shredded/smoked two of this belt last summer. Share this post Link to post Share on other sites
Ed Kennell 46,786 #13 Posted 5 hours ago Do you have the correct PTO tension spring and is it adjusted to the 1 3/4 " length to apply the correct tension to the belt? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,414 #14 Posted 2 hours ago Those grooves look very rusty. Nothing wrong with rust but it has to be smooth. A wide flat file works good - knock off the high spots. A belt constantly slides into the groove and back out of it so smooth is required to prevent wear. Share this post Link to post Share on other sites
